[snappyHexMesh] Inverted Castellation - Geometry Subtracted From Domain |
June 11, 2024, 11:26 |
Rep Power: 2 |
Hello all,
Very new to snappyHexMesh, but I have been following some tutorials (Wolf Dynamics etc). During the castellation step, instead of the blockmesh domain 'sticking' to my geometry, it's like the geometry is substracted from the domain. Any ideas as to what's going wrong? I have attached a picture and the snappyHexMeshDict. Let me know if you need more info Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap false; addLayers false; // Geometry. Definition of all surfaces. All surfaces are of class // searchableSurface. // Surfaces are used // - to specify refinement for any mesh cell intersecting it // - to specify refinement for any mesh cell inside/outside/near // - to 'snap' the mesh boundary to the surface geometry { elbowSnappyGeo.stl { type triSurfaceMesh; name elbow; regions { inlet1 { name inlet1; } inlet2 { name inlet2; } outlet { name outlet; } walls { name walls; } symmetry_plane { name symmetry_plane; } } } } // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ maxLocalCells 50000; maxGlobalCells 1000000; minRefinementCells 0; maxLoadUnbalance 0.10; nCellsBetweenLevels 1; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ features ( /*{ file "elbowSnappyGeo.eMesh"; level 4; }*/ ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ refinementSurfaces { elbow { level (4 4); // default regions { inlet1 { level (4 4); patchInfo { type patch; } } inlet2 { level (4 4); patchInfo { type patch; } } outlet { level (4 4); patchInfo { type patch; } } symmetry_plane { level (4 4); patchInfo { type symmetry; } } walls { level (4 4); patchInfo { type wall; } } } } } // Resolve sharp angles resolveFeatureAngle 30; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ refinementRegions { // Define any refinement regions here if needed /*elbow { mode distance; levels ((1e2 2)); }*/ }; // Mesh selection // ~~~~~~~~~~~~~~ locationInMesh (-0.0429496835859303 0.00771134940190549 -0.0425954894548383); allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { nSmoothPatch 3; tolerance 2.0; nSolveIter 30; nRelaxIter 5; // Feature snapping nFeatureSnapIter 10; implicitFeatureSnap false; explicitFeatureSnap true; multiRegionFeatureSnap true; } // Settings for the layer addition. addLayersControls { relativeSizes true; layers { walls { nSurfaceLayers 6; } } expansionRatio 1.2; finalLayerThickness 0.008; minThickness 0.001; nGrow 0; featureAngle 5; slipFeatureAngle 30; nRelaxIter 3; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 10; maxFaceThicknessRatio 0.5; maxThicknessToMedialRatio 0.3; minMedialAxisAngle 90; nBufferCellsNoExtrude 0; nLayerIter 50; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { maxNonOrtho 65; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; minVol 1e-13; minTetQuality 1e-30; minArea -1; minTwist 0.02; minDeterminant 0.001; minFaceWeight 0.02; minVolRatio 0.01; minTriangleTwist -1; // Advanced nSmoothScale 4; errorReduction 0.75; } // Advanced // Flags for optional output debug 0; // Merge tolerance. Is fraction of overall bounding box of initial mesh. mergeTolerance 1e-6; // ************************************************************************* / |
June 11, 2024, 11:57 |
Yann
Rep Power: 29 |
Most probably this: Code:
locationInMesh (-0.0429496835859303 0.00771134940190549 -0.0425954894548383); If you intend to mesh the inside of the pipe, this point should be inside it too. (you can check in ParaView to make sure there is no mistake. For instance, scaling issue) Yann |
Sudden increase the residual of Maxwell's equations | hsezsz | CFX | 2 | October 13, 2016 07:58 |
Closed Domain Buoyancy Flow Problem | Madhatter92 | CFX | 6 | June 20, 2016 22:05 |
Create domain in Hexpress by importing geometry from CATIA V5R21 | PeiSan | Fidelity CFD | 1 | June 30, 2014 05:10 |
vertices coordinates of a geometry domain | dikra | Main CFD Forum | 2 | December 20, 2007 17:26 |
block geometry inside fluid domain | jeff | Main CFD Forum | 18 | April 12, 2004 12:37 |
