April 30, 2024, 07:14 |
Multi region snappy hex mesh
Boris
Rep Power: 9 |
Hi everyone!
I have trouble understanding how snappyhexmesh works for multi regions. Attached is a drawing of what I am trying to do. Basically, I am trying to mesh a 3 region mesh. I prepared the domain limits as well as each interface. Something odd is that the mesher refines the mesh at the surfaces .stl, but does not create region. Am I doing something wrong? Currently, my "rock" cellzone for example is "open", in the sense that the interface fluid-rock defines its shape via stl, but to close it, it would need to have the interface rock-ground. Do I have to merge them somehow? Here is my snappy file : Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2006 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; classdictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true;//false;//true; addLayers false;//true; // Geometry. Definition of all surfaces. All surfaces are of class // searchableSurface. // Surfaces are used // - to specify refinement for any mesh cell intersecting it // - to specify refinement for any mesh cell inside/outside/near // - to 'snap' the mesh boundary to the surface geometry { fluid { type triSurfaceMesh; file "domain_total.stl"; regions { domain_bottom {name domain_bottom; } domain_side_air {name domain_side_air; } domain_side_ground {name domain_side_ground; } domain_top {name domain_top; } } } interface_air_rocks { type triSurfaceMesh; file "interface_air_rocks.stl"; } interface_air_ground { type triSurfaceMesh; file "interface_air_ground.stl"; } interface_ground_rock { type triSurfaceMesh; file "interface_ground_rock.stl"; } } // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 100000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 10000000; // The surface refinement loop might spend lots of iterations refining just a // few cells. This setting will cause refinement to stop if <= minimumRefine // are selected for refinement. Note: it will at least do one iteration // (unless the number of cells to refine is 0) minRefinementCells 10; // Allow a certain level of imbalance during refining // (since balancing is quite expensive) // Expressed as fraction of perfect balance (= overall number of cells / // nProcs). 0=balance always. maxLoadUnbalance 0.10; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. nCellsBetweenLevels 1; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. features ( ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that 'see' multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { fluid { // Surface-wise min and max refinement level level (11); regions { domain_bottom { level (11); patchInfo { type wall ; } } domain_side_air { level (11); patchInfo { type patch ; } } domain_side_ground { level (11); patchInfo { type wall ; } } domain_top { level (11); patchInfo { type patch ; } } } } interface_air_rocks { level (45); faceZone interface_air_rocks; cellZone rocks; cellZoneInside insidePoint; insidePoint (17-18164); } interface_air_ground { level (23); faceZone interface_air_ground; cellZone ground; cellZoneInside insidePoint; insidePoint (00-20); } interface_ground_rock { level (23); faceZone interface_ground_rock; cellZone ground; cellZoneInside insidePoint; insidePoint (00-20); } } // Resolve sharp angles resolveFeatureAngle 30; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions { // // refinement_Region_2 // { // mode inside; // levels ((1e14 2)); //((1E15 4)); // } // } // Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (150150150.01); // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces false; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 3; //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 2.0; //- Number of mesh displacement relaxation iterations. nSolveIter 30; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; // Feature snapping //- Number of feature edge snapping iterations. // Leave out altogether to disable. nFeatureSnapIter 10; //- Detect (geometric only) features by sampling the surface // (default=false). implicitFeatureSnap false; //- Use castellatedMeshControls::features (default = true) explicitFeatureSnap true; //- Detect points on multiple surfaces (only for explicitFeatureSnap) multiRegionFeatureSnap false; } // Settings for the layer addition. addLayersControls { } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { #include"meshQualityDict" // Advanced //- Number of error distribution iterations nSmoothScale 4; //- Amount to scale back displacement at error points errorReduction 0.75; } // Advanced // Write flags writeFlags ( scalarLevels layerSets layerFields // write volScalarField for layer coverage ); // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1e-6; // ************************************************************************* // WhatsApp Image 2024-04-30 at 12.08.10.jpg https://imgur.com/wcFIPPo |
April 30, 2024, 09:18 |
Yann
Rep Power: 29 |
Hello Boris,
I don't know if I properly understood your issue. Snappy's job will be to mesh your whole domain and define a cellZone for each region. The resulting mesh will contain all the regions (which are still only cellZones at this point). Then you need to use the splitMeshRegions utility to split the mesh into regions and create the interfaces. For instance: Code:
splitMeshRegions -cellZonesOnly -overwrite Yann |
April 30, 2024, 11:51 |
#3 | |
Boris
Rep Power: 9 |
I am trying to do a very simple case, where a cylinder is englobing a cube, and I want to mesh both volumes and have two different zones. The very simple example can be found here : test_multi_region.zip Even with this, I can't seem to understand how to create different region, can you see what I am missing? My sHM is as such : Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2006 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; classdictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true;//false;//true; addLayers true;//true; // Geometry. Definition of all surfaces. All surfaces are of class // searchableSurface. // Surfaces are used // - to specify refinement for any mesh cell intersecting it // - to specify refinement for any mesh cell inside/outside/near // - to 'snap' the mesh boundary to the surface geometry { fluid { type triSurfaceMesh; file "cylinder.stl"; } block { type triSurfaceMesh; file "cube.stl"; } } // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 100000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 10000000; // The surface refinement loop might spend lots of iterations refining just a // few cells. This setting will cause refinement to stop if <= minimumRefine // are selected for refinement. Note: it will at least do one iteration // (unless the number of cells to refine is 0) minRefinementCells 10; // Allow a certain level of imbalance during refining // (since balancing is quite expensive) // Expressed as fraction of perfect balance (= overall number of cells / // nProcs). 0=balance always. maxLoadUnbalance 0.10; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. nCellsBetweenLevels 1; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. features ( ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that 'see' multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { fluid { // Surface-wise min and max refinement level level (11); cellZone fluid; cellZoneInside insidePoint; insidePoint (003); } block { // Surface-wise min and max refinement level level (11); faceZone block_to_fluid; cellZone block; cellZoneInside insidePoint; insidePoint (001); } } // Resolve sharp angles resolveFeatureAngle 30; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions { // // refinement_Region_2 // { // mode inside; // levels ((1e14 2)); //((1E15 4)); // } // } // Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (003); // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces false; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 3; //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 2.0; //- Number of mesh displacement relaxation iterations. nSolveIter 30; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; // Feature snapping //- Number of feature edge snapping iterations. // Leave out altogether to disable. nFeatureSnapIter 10; //- Detect (geometric only) features by sampling the surface // (default=false). implicitFeatureSnap false; //- Use castellatedMeshControls::features (default = true) explicitFeatureSnap true; //- Detect points on multiple surfaces (only for explicitFeatureSnap) multiRegionFeatureSnap false; } // Settings for the layer addition. addLayersControls { } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { #include"meshQualityDict" // Advanced //- Number of error distribution iterations nSmoothScale 4; //- Amount to scale back displacement at error points errorReduction 0.75; } // Advanced // Write flags writeFlags ( scalarLevels layerSets layerFields // write volScalarField for layer coverage ); // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1e-6; // ************************************************************************* // |
April 30, 2024, 12:10 |
Yann
Rep Power: 29 |
Which OpenFOAM version are you using?
May 3, 2024, 04:57 |
Boris
Rep Power: 9 |
May 3, 2024, 06:21 |
Yann
Rep Power: 29 |
Alright, glad to know you solved your issue!
In the example your posted before, the fluid cellZone was not properly defined, I think because it was missing a faceZone definition: Code:
fluid { // Surface-wise min and max refinement level level (1 1); faceZone fluid; cellZone fluid; cellZoneInside insidePoint; insidePoint (0 0 3); } Using topoSet to fix the cellZones before running splitMeshRegions might do the trick. There are also some resources here: https://openfoamwiki.net/index.php/S...-region_meshes (but everything might not be up to date) I was asking about the version you are using, because in the OpenCFD branch (openfoam.com), there is another way to define cellZones since OpenFOAM-v1612+. Instead of defining cellZones in the refinementSurfaces section, you can use the locationsInMesh parameter to define a point and a name in each region. So your refinementSurfaces section would be like this: Code:
refinementSurfaces { fluid { level (1 1); } block { level (1 1); } } Code:
locationsInMesh ( ((0 0 3) fluid) ((0 0 1) block) ); You will just need to run splitMeshRegions -cellZones -overwrite afterward to split the mesh into regions meshes. It also allows to easily define layers on the fluid side. (check this post SnappyHexMesh do not add layers) For other users who might read this thread, please note this feature is not available in the foundation branch (openfoam.org) I hope this will be helpful! Yann |
May 3, 2024, 06:26 |
#7 | |
Boris
Rep Power: 9 |
Indeed, I forgot to mention I also fixed the faceZone mistake. Regarding the locationsInMesh, it seems indeed quite a simpler way to do things! That also explains why I saw several methods around on the internet. |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 13:38 |
[snappyHexMesh] Multi Region Mesh of a car filter | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 3 | September 11, 2019 20:34 |
[Other] preserveFaceZones constraint on a multi region mesh | ViktorKL | OpenFOAM Meshing & Mesh Conversion | 5 | May 21, 2019 12:45 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 05:17 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
