[snappyHexMesh] what does feature edge/line mean in snappyHexMesh documents? |
April 11, 2024, 21:28 |
Ali B.
Rep Power: 6 |
The title says it all. I see this in many documentation and tutorials but not sure what does it exactly mean. Edit: Also not sure what surface features are? |
April 12, 2024, 04:49 |
Yann
Rep Power: 29 |
surface features are basically the edges of the surface. For instance on the the motorbike geometry, feature lines in red: In snappyHexMesh you can specify refinement levels on these lines. Feature lines can be extracted from a stl/obj file using the surfaceFeatureExtract (OpenCFD branch: openfoam.com) or surfaceFeatures (foundation branch: openfoam.org) utilities. Yann |
April 12, 2024, 15:32 |
Ali B.
Rep Power: 6 |
Got it. Thank you Yann for your reply.
snappyhexmesh |
[snappyHexMesh] stringing of feature edges | Hr_kules | OpenFOAM Meshing & Mesh Conversion | 0 | July 22, 2022 09:30 |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 02:37 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
[snappyHexMesh] snappyHexMesh: Feature snapping of thin membrane edge | gooofy | OpenFOAM Meshing & Mesh Conversion | 7 | September 19, 2016 05:29 |
[snappyHexMesh] snappyHexMesh doesn't do feature edge snapping | wc34071209 | OpenFOAM Meshing & Mesh Conversion | 1 | May 7, 2014 17:47 |
