[snappyHexMesh] SHM does not snap if I increase cells in blockMesh or increase maxNumbercells in SHM |
January 29, 2024, 18:20 |
Aarib Irfan
Rep Power: 6 |
I am trying to simulate propeller in OpenFoam using the SHM. The meshing runs file if I use the default files from the propeller tutorial however the mesh is too coarse for my simulation. But if I try to increase the cells in blockMesh then the SHM does not snap the mesh to propeller and just give me blockMesh with inlet and outlet.
But if I use less cells in blockMesh then SHM works fine and snaps the mesh to the propeller. I don't understand why its doing this. The same thing happens when I try to increase refinement level and maximum number of cells in SHM. Everything else remains the same. Can someone tell me why this happens? |
January 30, 2024, 02:28 |
M
Rep Power: 13 |
I have not done this tutorial, but if the number of cells/levels (higher spatial resolution) is really the only parameter that is changing, there might be an issue with the STL file itself. If the input stl is not closed and your cell size is able to resolve the gap, snappy will stop working and just hand you back your blockMesh which is what you described.
You can navigate to your folder and run Code:
surfaceCheck propeller.stl |
openfoam, shm, snap, snappyhexmesh |
[snappyHexMesh] snappyHexMesh does not detect highly skewed faces? | ptpacheco | OpenFOAM Meshing & Mesh Conversion | 1 | January 4, 2022 13:37 |
[snappyHexMesh] SHM doesn't snap the boundary between two surfaces on same plane | decanter | OpenFOAM Meshing & Mesh Conversion | 4 | November 17, 2020 16:32 |
[snappyHexMesh] SHM not snapping to some surfaces | Swift | OpenFOAM Meshing & Mesh Conversion | 13 | January 4, 2016 02:56 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 01:32 |
