October 25, 2023, 06:37 |
OpenFoam snappyHexMesh killed
A. Alminnawi
Rep Power: 3 |
I am creating stl models from CT scans then running CFD simulations on them. I split the mesh into sections per CPU "decomposePar" then I run the analysis using "mpirun -np 8 snappyHexMesh -overwrite -parallel" at one point it gives me the following issue and I am not sure if it is related to memory or an actual problem and I would appreciate your input: Surface refinement iteration 1 ------------------------------ Marked for refinement due to surface intersection : 737438 cells. Determined cells to refine in = 0.9 s Selected for refinement : 805539 cells (out of 1806561) Edge intersection testing: Number of edges : 24387267 Number of edges to retest : 23405550 -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun noticed that process rank 0 with PID 0 on node MED81341 exited on signal 9 (Killed). thanks you |
October 27, 2023, 09:20 |
Lucky
Rep Power: 66 |
Nothing you write makes sense.
snappyHexMesh is the meshing utility, not the analysis. |
October 30, 2023, 06:37 |
A. Alminnawi
Rep Power: 3 |
I write a bash code for the entire thing, the analysis is preceded by meshing using snappyHexMesh, and since the issue occurred at snappyHexMesh level, I mentioned it specifically. I guess that confused you so much so maybe this is better for you to understand:
Before running the analysis I used "mpirun -np 8 snappyHexMesh -overwrite -parallel" to mesh it |
October 30, 2023, 08:33 |
M
Rep Power: 13 |
Lucky knows very well what you meant, I think between the lines he/she is telling you, that this is very little information to go with.
If you suspect it to be a memory issue, why don't you run again and monitor your memory load? If it is anything else, there is very little information to make an educated guess. It could be a lot of things ... |
October 30, 2023, 09:26 |
A. Alminnawi
Rep Power: 3 |
it was indeed a memory issue. I reduced the stl file and then it worked fine.
thank you. |
OPENFOAM - SnappyHexMesh - Internal Mesh is empty after SHM | Adityasanu | OpenFOAM Running, Solving & CFD | 0 | April 17, 2021 06:35 |
[OpenFOAM.com] Openfoam solvers and snappyHexMesh stopped working in parallel after update | KTG | OpenFOAM Installation | 9 | February 14, 2021 03:14 |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 16:54 |
[snappyHexMesh] OpenFoam FATAL ERROR SnappyHexMesh search lines never written | enginpower | OpenFOAM Meshing & Mesh Conversion | 8 | December 30, 2016 09:19 |
[snappyHexMesh] snappyHexMesh "killed" | Bob | OpenFOAM Meshing & Mesh Conversion | 4 | December 1, 2011 17:48 |
