[blockMesh] Changing the calculated field to a new mesh |
Dasha
Rep Power: 2 ![]() |
Dear All,
I heard that this is possible, but I can't find the information: I need to change the velocity field calculated in OpenFoam for a new mesh and the same geometry. I calculated the velocity field using the SIMPLE solver and now I want to calculate heat transfer. However, the mesh that I made to calculate the momentum is too dense. I don’t need such precision for heat transfer and I would like to change the mesh to a wider one, but retain the result of the field calculated earlier. Please tell me how can I do this? thanks in advance for your answer ![]() |
Yann
Rep Power: 27 ![]() |
You can use the mapFields utility to map fields on different meshes. Regards, Yann |
Dasha
Thanks Yann!
mesh changing, velocity field |
parallel run in foam extend | CRI_CFD | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 5 | March 28, 2024 08:36 |
GeometricField -> mesh() Function | Tobi | OpenFOAM Programming & Development | 10 | November 19, 2020 11:33 |
[Other] dynamicTopoFVMesh and pointDisplacement | RandomUser | OpenFOAM Meshing & Mesh Conversion | 6 | April 26, 2018 07:30 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
