[blockMesh] blockMesh edit file with custom variables not working |
September 25, 2023, 14:56 |
Debarchan Das
Rep Power: 3 |
I am working on the openFOAM lid cavity tutorial.This is my blockMesh file where I have edited and placed my variables to construct the mesh. But smehow i run into an error which I have posted below. IS there anyone who can help me regarding this on where I am going wrong. I am also new in learning openFOAM. Anyone who has solved similar issue?? *--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 10 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.1; xmin 0; xmax 1; ymin 0; ymax 1; zmin 0; zmax 0.1; vertices( ($xmin $ymin $zmin) //0 ($xmax $ymin $zmin) //1 ($xmax $ymax $zmin) //2 ($xmin $ymax $zmin) //3 ($xmin $ymin $zmax) //4 ($xmax $ymin $zmax) //5 ($xmax $ymax $zmax) //6 ($xmin $ymax $zmax) //7 ); deltax 0.05; //spacing along x direction deltay 0.05; //spaceing along y diretcion deltaz 0.05; //spacing along z direction lx #calc "$xmax - $xmin"; //length along x-axix ly #calc "$ymax - $ymin"; //length along y-axis lz #calc "$zmax - $zmin"; //length along z-axis xcells #calc "(round($lx / $deltax))"; //no of cells in x direction ycells #calc "(round($ly / $deltay))"; //no of cells in y direction zcells #calc "(round($lz / $deltaz))"; //no of cells in z direction blocks ( hex (0 1 2 3 4 5 6 7) ($xcells $ycells $zcells) simpleGrading( //x direction (0.2 0.25 8) (0.6 0.50 1) (0.2 0.25 0.125) ) ( //y direction (0.2 0.25 8) (0.6 0.50 1) (0.2 0.25 0.125) ) ( //z direction 1 ) ); boundary ( movingWall { type wall; faces ( (3 7 6 2) ); } fixedWalls { type wall; faces ( (0 4 7 3) (2 6 5 1) (1 5 4 0) ); } frontAndBack { type empty; faces ( (0 3 2 1) (4 5 6 7) ); } ); // ************************************************** *********************** // ************************************************** ************************************************** * The error messege I get after running blockMesh command is here as follows: *---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 10 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 10-e450dce21ea5 Exec : blockMesh Date : Sep 25 2023 Time : 17:35:26 Host : "ml" PID : 31731 I/O : uncollated Case : /home/ml/OpenFOAM/ml-10/run/cavity/cavity nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Reading "blockMeshDict" Creating block mesh from "system/blockMeshDict" Using #calcEntry at line 40 in file "/home/ml/OpenFOAM/ml-10/run/cavity/cavity/system/blockMeshDict" Using #codeStream with "/home/ml/OpenFOAM/ml-10/run/cavity/cavity/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_55901ee8754faa7266ca8fc7a65319beb51c d312.so" codeStream : dictionary:"/home/ml/OpenFOAM/ml-10/run/cavity/cavity/system/blockMeshDict" master-only-reading:1 Using #calcEntry at line 41 in file "/home/ml/OpenFOAM/ml-10/run/cavity/cavity/system/blockMeshDict" codeStream : dictionary:"/home/ml/OpenFOAM/ml-10/run/cavity/cavity/system/blockMeshDict" master-only-reading:1 Using #calcEntry at line 42 in file "/home/ml/OpenFOAM/ml-10/run/cavity/cavity/system/blockMeshDict" Using #codeStream with "/home/ml/OpenFOAM/ml-10/run/cavity/cavity/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_45420be29fe5b8345c57c4b92e41092313d1 37b2.so" codeStream : dictionary:"/home/ml/OpenFOAM/ml-10/run/cavity/cavity/system/blockMeshDict" master-only-reading:1 Using #calcEntry at line 44 in file "/home/ml/OpenFOAM/ml-10/run/cavity/cavity/system/blockMeshDict" Using #codeStream with "/home/ml/OpenFOAM/ml-10/run/cavity/cavity/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_0d6337e7391cbfcb6fc07e564888683c9301 a5e9.so" Invoking "wmake -s libso /home/ml/OpenFOAM/ml-10/run/cavity/cavity/dynamicCode/_0d6337e7391cbfcb6fc07e564888683c9301a5e9" wmake libso /home/ml/OpenFOAM/ml-10/run/cavity/cavity/dynamicCode/_0d6337e7391cbfcb6fc07e564888683c9301a5e9 Ctoo: codeStreamTemplate.C /home/ml/OpenFOAM/ml-10/run/cavity/cavity/system/blockMeshDict: In function ‘void Foam::codeStream_0d6337e7391cbfcb6fc07e564888683c9 301a5e9(Foam::Ostream&, const Foam::dictionary&)’: /home/ml/OpenFOAM/ml-10/run/cavity/cavity/system/blockMeshDict:1:15: error: ‘$lx’ was not declared in this scope /*--------------------------------*- C++ -*----------------------------------*\ ^~~ /home/ml/OpenFOAM/ml-10/run/cavity/cavity/system/blockMeshDict:1:21: error: ‘$deltax’ was not declared in this scope /*--------------------------------*- C++ -*----------------------------------*\ ^~~~~~~ /home/ml/OpenFOAM/ml-10/run/cavity/cavity/system/blockMeshDict:1:21: note: suggested alternative: ‘labelMax’ /*--------------------------------*- C++ -*----------------------------------*\ ^~~~~~~ labelMax /opt/openfoam10/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/codeStreamTemplate.o' failed make: *** [Make/linux64GccDPInt32Opt/codeStreamTemplate.o] Error 1 --> FOAM FATAL IO ERROR: Failed wmake "dynamicCode/_0d6337e7391cbfcb6fc07e564888683c9301a5e9/platforms/linux64GccDPInt32Opt/lib/libcodeStream_0d6337e7391cbfcb6fc07e564888683c9301 a5e9.so" file: /home/ml/OpenFOAM/ml-10/run/cavity/cavity/system/blockMeshDict from line 16 to line 23. From function static void (* Foam::functionEntries::codeStream::getFunction(con st Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&) in file db/dictionary/functionEntries/codeStream/codeStream.C at line 175. FOAM exiting |
September 26, 2023, 09:22 |
M
Rep Power: 13 |
a toughy, the error is quite misleading. I pushed some things around to get clearer error messages.
1) you have some syntax errors. "vertices" is not found, because there is no whitespace between the keyword and the "(" 2) your grading definition in the block is weird, I switched it to something easier and now it works ... you can work from there. 3) edges () was missing, not sure if this was critical or not. The below runs withouit errors for me. Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.1; xmin 0; xmax 1; ymin 0; ymax 1; zmin 0; zmax 0.1; deltax 0.05; //spacing along x direction deltay 0.05; //spaceing along y diretcion deltaz 0.05; //spacing along z direction lx #calc "$xmax - $xmin"; //length along x-axix ly #calc "$ymax - $ymin"; //length along y-axis lz #calc "$zmax - $zmin"; //length along z-axis xcells #calc "(round($lx / $deltax))"; //no of cells in x direction ycells #calc "(round($ly / $deltay))"; //no of cells in y direction zcells #calc "(round($lz / $deltaz))"; //no of cells in z direction vertices ( ($xmin $ymin $zmin) //0 ($xmax $ymin $zmin) //1 ($xmax $ymax $zmin) //2 ($xmin $ymax $zmin) //3 ($xmin $ymin $zmax) //4 ($xmax $ymin $zmax) //5 ($xmax $ymax $zmax) //6 ($xmin $ymax $zmax) //7 ); blocks ( hex (0 1 2 3 4 5 6 7) ($xcells $ycells $zcells) simpleGrading (1 1 1) ); edges ( ); boundary ( movingWall { type wall; faces ( (3 7 6 2) ); } fixedWalls { type wall; faces ( (0 4 7 3) (2 6 5 1) (1 5 4 0) ); } frontAndBack { type empty; faces ( (0 3 2 1) (4 5 6 7) ); } ); // ************************************************************************* // |
September 26, 2023, 10:11 |
Issue solved!
Debarchan Das
Rep Power: 3 |
Hello AtoHM ,
Thank you so much for you reply. I pasted the code and ran it, polymesh got created. The spcaing tip and the edges were really a good points which I had missed. I wanted to ask if there are any ways of actually putting gradient in the x and y direction and in that case how does the code works. In that case how will the simpleGradient will look like. Any examples or leads you can send me would be really helpful. |
September 26, 2023, 10:45 |
M
Rep Power: 13 |
You are welcome.
There are examples here http://www.wolfdynamics.com/wiki/mes..._blockmesh.pdf that look suspiciously like what you did above. You probably have a missing or exceeding brackets, maybe these? Code:
simpleGrading ( ( // <-- missing? ... ... ( // <-- too much? //z direction |
September 26, 2023, 11:10 |
Debarchan Das
Rep Power: 3 |
Thanks for the blockMesh tutorial link. Looking for some similar material. it's a huge help.
#blockmeshdict |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 02:22 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 22:03 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 13:41 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 12:44 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
