[mesh manipulation] Details on setSet/topoSet usage
Like Tree7Likes
  • 3 Post By Yann
  • 2 Post By Yann
  • 1 Post By Yann
  • 1 Post By Florian Mlehliw
Old   August 8, 2023, 11:37
Question Details on setSet/topoSet usage
Wilhelm Furian
Florian Mlehliw is on a distinguished road
Hello everyone!
TL;DR:
I'm not very experienced with openFoam. I'm searching for pointers on how to create cellZones in v2112. Can anyone point me to an explanation/tutorial/video on how to create a cellZone from my own geometry?
What I've done:
In snappyHexMeshDict, I've created a geometry like this:
geometry
    Dam
    type distributedTriSurfaceMesh;
    file "dam.stl";
refinementSurfaces
        Dam
            level (6 7);
            patchInfo
            type wall;
I then created my dynamicMeshDict like this:
dynamicFvMesh   dynamicMotionSolverFvMesh;
motionSolverLibs (fvMotionSolvers);
motionSolver    solidBody;
cellZone        Dam;
solidBodyMotionFunction  linearMotion;
velocity        (0.0 0.0 -100);
But when I run interFoam, it does not find the cellZone Dam, because apparently that's not the way to go.
Create time
Create mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: solidBody
Applying solid body motion to cellZone Dam
--> FOAM FATAL ERROR: (openfoam-2112)
Unable to find cellZone Dam.  Valid cellZones are:0()
    From Foam::zoneMotion::zoneMotion(const Foam::dictionary &, const Foam::polyMesh &)
    in file motionSolvers/displacement/displacement/zoneMotion.C at line 70.
FOAM exiting
I then tried using cellSet and topoSet but since I did not find a current wiki on this, I failed. When I use cellSet to create a new set I get this error.
setSet
readline>cellSet fluidSet Dam
     Set:fluidSet  Size:0  Action:new
   Bad token - could not get word
Apparently there is something wrong with my data, but what should I have done before that?
What I have looked at:
The wiki articles seem to mainly concern v2.1, and the advice there is not compatible with 2112.
I've looked at this, too, but they work with preexisting geometries and don't show how to implement my own https://www.cfdsupport.com/OpenFOAM-...t/node161.html
On this forum, there are some unanswered questions dealing with this. Also, this post sounded promising, but there are no details on how it worked ways to create cellZones and faceZones
Florian Mlehliw is offline   Reply With Quote
Old   August 8, 2023, 12:09
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hello Florian,
You can define a cellZone directly into snappyHexMeshDict:
faceZone sphere;
cellZone sphere;
cellZoneInside inside;    // outside/insidePoint
insidePoint    (1 1 1);   // if (cellZoneInside == insidePoint)
Source: https://doc.openfoam.com/2306/tools/...nementSurfaces
You can also define it afterward using topoSet: https://doc.openfoam.com/2306/tools/...ation/topoSet/
Note: OpenCFD recently reworked its OpenFOAM documentation, so only v2212 and v2306 are available in the new documentation. But it should work for v2112 too, I don't think there were major changes on the specific point you are looking for.
I hope this helps,
Yann
Yann is offline   Reply With Quote
Old   August 8, 2023, 13:26
Wilhelm Furian
Hi Yann,
thanks a lot for your answer, but I'm not sure I understand. Should my snappyHexMeshDict look like this:
geometry
{     dam
      {     type distributedTriSurfaceMesh;
             file "dam.stl";
      refinementSurfaces
            dam
                    level (6 7);
                    patchInfo
                          type wall;
                     faceZone sphere;
                     cellZone sphere;
                     insidePoint    (4000 3455 4671);
I'm not sure what "sphere" means here, but in the end my cellZone should be a block^^ But I guess, my types are not correct, because if I run snappyHexMesh, I now get this error:
--> FOAM FATAL IO ERROR: (openfoam-2112)
Entry 'type' has 2 excess tokens in stream
    3(distributedTriSurfaceMesh file "dam.stl")
file: system/snappyHexMeshDict.geometry.dam at line 41.
FOAM exiting
Could you maybe take my hand a little more through this jungle?
Best regards - Wilhelm
Old   August 9, 2023, 04:28
Yann
Hello Wilhelm,
sphere is just the example in the documentation. It defines the name of the faceZone and cellZone. But you can name it dam or whatever name you like. You will just have to update your dynamicMeshDict with the name of the cellZone you defined in snappyHexMeshDict.
Regarding your error, it seems you are missing a closing bracket in the geometry section:
geometry
	dam
		file "dam.stl";
Regards,
Yann
hogsonik and Florian Mlehliw like this.
Old   August 10, 2023, 04:24
Wilhelm Furian
Hi Yann,
thank you so much for guiding me a bit further!!
Unfortunately, the error message stays the same - the missing closing bracket just got lost during copy and paste, in the file is was correct.
From googling I know that this means that there are errors in my dict files, but I have no idea on how to solve them, because line 41 in my snappyHexMeshDict seems okay to me:
40 {
41  type distributedTriSurfaceMesh
42  file "dam.stl";
43 }
Or can this point somewhere else?
Thanks!
Last edited by Florian Mlehliw; August 10, 2023 at 04:24. Reason: visual clarity of code part
Old   August 10, 2023, 04:49
Yann
Hello Wilhelm,
It looks like there is a semicolon missing:
40 {
41  type distributedTriSurfaceMesh;
42  file "dam.stl";
43 }
Yann
Florian Mlehliw likes this.
Old   August 10, 2023, 05:04
Default That was it!
Wilhelm Furian
Thank you! That was a bit embarrassing^^
But now snappy is running. It still does not produce what I want but I need to understand the problem first.
Thanks again!
Yann likes this.
cellzones, toposetdict
CPUs vs GPUs for CFD? hami11 Hardware 22 July 23, 2024 16:59
OpenFOAM Solver/BC usage description murrayjc OpenFOAM 3 August 25, 2009 05:48
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
user defined function cfduser CFX 0 April 29, 2006 11:58
Fluent 5.5. What the differences with fluent 5.3?? confused FLUENT 2 July 29, 2001 22:58
