[snappyHexMesh] SnappyHexMesh creates the complementary mesh |
July 31, 2023, 08:09 |
Stefano
Dear everyone,
I'm getting a strange behaviour with snappyHexMesh. I've an obj file that describe a village environment, including a ground mesh, 3d buildings and some trees. I want to build a mesh above the obj and simulate the wind over the city. The problem is that sometime (not always, depends maybe on some parameters?) the mesh is not cut above the obj but below, it's like the mesh is the complementary of what i want. (where there is empty space the mesh should be built and viceversa) Has anyone got in the past similar results? |
July 31, 2023, 08:58 |
Yann
Rep Power: 29 |
Sounds like your locationInMesh is not always properly defined. The coordinate should point to the volume you want to mesh. Regards, Yann |
July 31, 2023, 10:31 |
Stefano
It is exactly how you said, locationInMesh was set in (1,1,1)
In a lot of cases this point was above the ground, therefore i never faced the problem. In this particular case the ground in (0,0,0) starts with an hard slope, thus (1,1,1) was below the obj Solved, thank you! |
[snappyHexMesh] snappyHexMesh stuck when snap is turned on | yukuns | OpenFOAM Meshing & Mesh Conversion | 3 | February 2, 2021 14:05 |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 15:41 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[OpenFOAM] snappyHexMesh - can't open mesh in ParaView | tfigueiro | ParaView | 0 | June 11, 2015 20:05 |
[snappyHexMesh] snappyHexMesh & Mesh around a missile | sasanghomi | OpenFOAM Meshing & Mesh Conversion | 2 | October 15, 2014 20:54 |
