[blockMesh] Extra patch with 'zero' faces being generated |
LyLy
Rep Power: 7 ![]() |
Hello forum members,
I'm facing an issue while generating a wedge mesh and I would appreciate your insights to help me resolve it. In my blockMeshDict file, I have defined the mesh configuration as shown below: blockMeshDict file: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2212 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // R 0.15; L 1; X #eval{$R*cos(pi()*0.00625)}; Y #eval{$R*sin(pi()*0.00625)}; XNEG #eval{-$R*cos(pi()*0.00625)}; YNEG #eval{-$R*sin(pi()*0.00625)}; vertices ( (0 0 0) //0 ($X $YNEG 0) //1 ($X $Y 0) //2 (0 0 $L) //3 ($X $YNEG $L) //4 ($X $Y $L) //5 ); blocks ( hex (1 4 5 2 0 3 3 0) (600 1 80) simpleGrading (1 1 1) ); edges ( arc 4 5 (#eval{$R*cos(pi()*0.00625*0.5)} #eval{$R*cos(pi()*0.25)} $L) arc 1 2 (#eval{$R*cos(pi()*0.00625*0.5)} #eval{$R*cos(pi()*0.25)} 0) ); boundary ( inlet { type patch; faces ( (0 1 2 0) ); } outlet { type patch; faces ( (3 5 4 3) ); } walls { type wall; faces ( (2 1 4 5) ); } wedgeX { type wedge; faces ( (0 2 5 3) ); } wedgeY { type wedge; faces ( (0 3 4 1) ); } ); Old boundary file: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2212 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; arch "LSB;label=32;scalar=64"; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 6 ( inlet { type patch; nFaces 80; startFace 95320; } outlet { type patch; nFaces 80; startFace 95400; } walls { type wall; inGroups 1(wall); nFaces 600; startFace 95480; } wedgeX { type wedge; inGroups 1(wedge); nFaces 48000; startFace 96080; } wedgeY { type wedge; inGroups 1(wedge); nFaces 48000; startFace 144080; } defaultFaces { type empty; inGroups 1(empty); nFaces 0; startFace 192080; } ) // ************************************************************************* // Could you help me understand the possible reasons behind it? Your assistance would be much appreciated. I have attached the relevant files for reference. Please note that the current case is not fully built, so the simulation won't run at this stage. Thank you in advance for your time. Case Link (Google Drive) Last edited by harshabose; July 5, 2023 at 10:57. |
Rep Power: 5 ![]() |
Hey!
Not sure why defaultPatches is created, but I remember a trick to properly delete patches with 0 faces. You can use an empty createPatchDict and use the associated command. It will simply delete the unecessary patches (but if it works with a manuel deletion, all the better ![]() |
LyLy
Hey, Alczem,
Not solved yet. I am just going to manually delete it and hope for the best. I should see if this will create any problem while solving. Thank you for your input. Appreciate it. |
LyLy
Update:
Did not figure out the reasoning for the extra patch but seems that axisymmetric meshes with pyramid cells along the axis produce this. To overcome this, making a square section encompassing the axis seems to solve the issue. See below image for reference: FIG1.jpg |
blockmesh dict, default patches |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] layer not added | Rasmusiwersen | OpenFOAM Meshing & Mesh Conversion | 1 | January 2, 2020 09:43 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
Problem with cyclic boundaries in Openfoam 1.5 | fs82 | OpenFOAM | 36 | January 7, 2015 00:31 |
