[blockMesh] Cannot find file "points" in directory "polyMesh" in times "0" down to con |
July 3, 2023, 13:27 |
Rep Power: 14 |
I've been trying to run this tutorial (pimpleFoam, flies enclosed). Not sure why I'm getting this error:
--> FOAM FATAL ERROR: Cannot find file "points" in directory "polyMesh" in times "0" down to constant From function virtual Foam::IOobject Foam::fileOperation::findInstance(const Foam::IOobject&, Foam::scalar, const Foam::word&) const in file global/fileOperations/fileOperation/fileOperation.C at line 866. FOAM exiting I have run this command: ./Allrun, I also tried blockMesh directly, but I keep getting the same error. Any help will be greatly appreciated. Thanks |
July 4, 2023, 04:36 |
Yann
Rep Power: 29 |
This error is basically telling you the solver cannot find any mesh. What is the output when running blockMesh? Yann |
July 4, 2023, 12:12 |
Rep Power: 14 |
Yann, I found the problem. Thanks
July 4, 2023, 12:13 |
Yann
Rep Power: 29 |
Good news!
Can you elaborate on what was the problem? It might be useful for user others facing the same issue. Regards, Yann |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 04:50 |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 17:18 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 18:34 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 11:59 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
