[mesh manipulation] Extra Points and Cells are being created
Like Tree2Likes
  • 1 Post By Yann
  • 1 Post By harshabose
Old   June 28, 2023, 17:50
Default Extra Points and Cells are being created
LyLy
harshabose is on a distinguished road
I am currently facing an issue with my mesh generation process. I have developed a C++ code that generates polyMesh files (points, faces, cells, owners etc) to create a purely hexahedral mesh. The code functions correctly, and the polyMesh files are created as expected. However, when I open these polyMesh files in paraView, I notice the presence of additional points and cells.
According to my C++ code, the mesh should consist of exactly 36,080 points and 17,550 cells. However, upon inspection in paraView, I observe 36,158 points and 17,940 cells. This discrepancy is perplexing, as the generated polyMesh files clearly indicate the correct number of points and cells. Furthermore, the additional points seem to be created at coordinates (X, Y, Z) = (..., ..., 0.00025), while my intended coordinates only include (X, Y, Z) values of (..., ..., 0) or (..., ..., 0.0005).
I have also checked the results from the "checkMesh" command, which report the correct number of points and cells. However, even in the "checkMesh" output, I notice the presence of polyhedra cells and points at coordinates (X, Y, Z) = (..., ..., 0.00025).
Mesh stats
    internal points:  0
    faces:            70689
    internal faces:   34611
    cells:            17550
    faces per cell:   6
    boundary patches: 10
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     17472
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     78
    Breakdown of polyhedra by number of faces:
        faces   number of cells
            5   39
            7   39
I checked my code, even manually checked the polyMesh files. Was not able to find the problem. I need to know why these extra points and cells are being created. I am including few images and my files below.
Please find attached a few images and my mesh files for reference.
I would greatly appreciate any assistance or insights into resolving this issue.
Thank you in advance for your help
Extra Points
Extra Cells
Case File Link (Google Drive)
harshabose is offline   Reply With Quote
Old   June 29, 2023, 04:07
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hello Lyly,
Everything seems fine to me! (cf screenshot)
In paraView, just uncheck "Decompose polyhedra" when loading your case.
Cheers,
Yann
harshabose likes this.
Yann is offline   Reply With Quote
Old   June 29, 2023, 15:45
LyLy
Hello Yann,
That works. Thank you for the help. Really appreciate it.😊
There was still the problem of polyhedral cells appearing for some reason.
Face Count
I was able to convert these polyhedra to hexahedra using the "Convert Polyhedral Cells" filter. Seems to work fine.
Yann likes this.
[snappyHexMesh] layer not added Rasmusiwersen OpenFOAM Meshing & Mesh Conversion 1 January 2, 2020 10:43
SimpleFoam & Theater jipai OpenFOAM Running, Solving & CFD 3 June 18, 2019 11:11
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
