[blockMesh] Blockmesh Spline usage strange simpleGrading behavior
Like Tree2Likes
  • 1 Post By snak
  • 1 Post By exnihilo
Old   June 9, 2023, 06:40
Post Blockmesh Spline usage strange simpleGrading behavior
Andrea
exnihilo is on a distinguished road
I am trying to make a "smart" mesh for a laminar flame, but I cant get why blockMesh is subdividing the blocks like that (look at the image I linked). I have tried both wiht simplegrading and edgegrading. The problem is on the blocks on the west side, near to the blocks boundaries the mesh goes from fine to course, but this is not specified. The only thing that works is not using any Spline/polyLine. If you have any suggestion/solution I would be happy to hear it.
Thanks in advance.
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  10
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.001;
vertices
   (0     0                    -15)   // 0
   (8  -0.13962634015954636  -30)   // 1
   (8   0.13962634015954636  -30)   // 2
   (0     0                     15)     // 3
   (8  -0.13962634015954636   0)     // 4
   (8   0.13962634015954636   0)     // 5
   (45  -0.7853981633974483     0)     // 6
   (45   0.7853981633974483     0)     // 7
   (0     0                     90)   // 8
   (8  -0.13962634015954636   75)   // 9
   (8   0.13962634015954636   75)   // 10
   (45  -0.7853981633974483     75)   // 11
   (45   0.7853981633974483     75)   // 12
   (8.5  0.14835298641951802 0) // 13
   (8.5 -0.14835298641951802 75) // 14
   (8.5  0.14835298641951802 75) // 15
   (8.5 -0.14835298641951802 0) // 16
   (0 0 17) // 17
   (8  -0.13962634015954636 2) // 18
   (8  0.13962634015954636 2) // 19
   (8.5 -0.14835298641951802 2) // 20
   (8.5 0.14835298641951802 2) // 21
   (45 -0.7853981633974483 2) // 22
   (45 0.7853981633974483 2) // 23
blocks
   hex ( 0 1 2 0 3 4 5 3 )   (40 1 40)   edgeGrading (1 1 1 1 1 1 1 1 1 1 1 1) //(0.7 1 0.15) //sw
   hex ( 3 4 5 3 17 18 19 17 )   (40 1 33)   edgeGrading (1 1 1 1 1 1 1 1 1 1 1 1) //(0.7 1 0.7) // cw
   hex ( 17 18 19 17 8 9 10 8 ) (40 1 133) edgeGrading  (1 1 1 1 1 1 1 1 1 1 1 1)//(0.7 1 22) // nw
   hex ( 5 4 16 13 19 18 20 21 )   (1 30 33)   simpleGrading  (1 1 1)//(1 1 0.7) // cc
   hex ( 19 18 20 21 10 9 14 15 ) (1 30 133) simpleGrading  (1 1 1)//(1 1 22) // cn
   hex ( 13 16 6 7 21 20 22 23 ) (1 40 33) simpleGrading  (1 1 1)//(1 3 0.7) // ce
   hex ( 21 20 22 23 15 14 11 12 ) (1 40 133) simpleGrading  (1 1 1)//(1 3 22) // ne
boundary
    inletFuel
        type patch;
        faces
            (0 1 2 0)
    wallOutside
        type wall;
        faces
            (7 6 23 22)
            (23 22 12 11)
    wallTube
        type wall;
        faces
            (2 1 5 4)
            (5 4 16 13)
    inletN
        type patch;
        faces
            (13 16 6 7)
    outlet
        type patch;
        faces
            (8 9 10 8)
            (10 9 14 15)
            ( 15 14 11 12 )
    axis
        type empty;
        faces
            (0 3 3 0)
            (3 17 17 3)
            (17 8 8 17)
    frontAndBack_pos
        type wedge;
        faces
            (0 2 3 5)
            (3 5 17 19)
            (17 19 8 10)
            (5 13 19 21)
            (19 21 10 15)
            (13 7 21 23)
            (21 23 15 12)
    frontAndBack_neg
        type wedge;
        faces
            (0 1 3 4)
            (3 4 17 18)
            (17 18 8 9)
            (4 16 18 20)
            (18 20 9 14)
            (16 6 20 22)
            (20 22 14 11)
edges
    BSpline 17 19 ((0.2 0.003490658503988659 17) (1 0.017453292519943295 16.7) (7 0.12217304763960307 2.3) (7.8 0.1361356816555577 2))
    BSpline 17 18 ((0.2 -0.003490658503988659 17) (1 -0.017453292519943295 16.7) (7 -0.12217304763960307 2.3) (7.8 -0.1361356816555577 2))
    BSpline 3 4 ((0.2 -0.003490658503988659 15) (1 -0.017453292519943295 14.7) (7 -0.12217304763960307 0.3) (7.8 -0.1361356816555577 0))
    BSpline 3 5 ((0.2 0.003490658503988659 15) (1 0.017453292519943295 14.7) (7 0.12217304763960307 0.3) (7.8 0.1361356816555577 0))
    BSpline 0 1 ((0.2 -0.003490658503988659 -15) (1 -0.017453292519943295 -15.3) (7 -0.12217304763960307 -29.7) (7.8 -0.1361356816555577 -30))
    BSpline 0 2 ((0.2 0.003490658503988659 -15) (1 0.017453292519943295 -15.3) (7 0.12217304763960307 -29.7) (7.8 0.1361356816555577 -30))
    BSpline 8 9 ((0.2 -0.003490658503988659 90) (1 -0.017453292519943295 89.7) (7 -0.12217304763960307 75.3) (7.8 -0.1361356816555577 75))
    BSpline 8 10 ((0.2 0.003490658503988659 90) (1 0.017453292519943295 89.7) (7 0.12217304763960307 75.3) (7.8 0.1361356816555577 75))
exnihilo is offline   Reply With Quote
Old   June 10, 2023, 05:32
shinji nakagawa
snak is on a distinguished road
Hi exnihilo,
Thank you for sharing interesting problem.
It looks like that positions given in spline edges prevents grading.
I cannot suggest a direct solution unfortunately.
To avoid the problem, we may use geometry and projection in blockMesh dict. With this method grading instruction works. I modified your dict as follows. Curves is obtained from spheres created in geometry sub-dict. Your can use arbitrary shape (stl files and others) instead of sphere.
https://develop.openfoam.com/Develop.../blockMeshDict
https://www.openfoam.com/documentati...-geometry.html
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
// OpenFOAM v2212
scale 0.001;
// Geometric parameters
outerRadius 8;
geometry
    sphere0
        type    sphere;
        origin  (0 0 -30);
        radius  $outerRadius;
    sphere1
        type    sphere;
        origin  (0 0 0);
    sphere2
        type    sphere;
        origin  (0 0 2);
    sphere3
        type    sphere;
        origin  (0 0 75);
vertices
   (0     0                  -22) // -15)   // 0
   //project (0 0 -15) (sphere)  // 0
   //project (8  -0.13962634015954636 -30) (sphere)  // 1
   //project (8   0.13962634015954636  -30) (sphere)  // 2
   (0     0                   8) //  15)     // 3
   (0     0                   83) //  90)   // 8
   (0 0 10) //17) // 17
blocks
   hex ( 0 1 2 0         3 4 5 3 ) (40 1  40) simpleGrading (0.25 1 1) // block 0  //(0.7 1 0.15) //sw
   hex ( 3 4 5 3     17 18 19 17 ) (40 1  33) simpleGrading (0.25 1 1) //block 1 //(0.7 1 0.7) // cw
   hex ( 17 18 19 17    8 9 10 8 ) (40 1 133) simpleGrading  (0.25 1 1) // block 2 //(0.7 1 22) // nw
boundary
    inletFuel
        type patch;
        faces
            (0 1 2 0)
    wallOutside
        type wall;
        faces
            (7 6 23 22)
            (23 22 12 11)
    wallTube
        type wall;
        faces
            (2 1 5 4)
            (5 4 16 13)
    inletN
        type patch;
        faces
            (13 16 6 7)
    outlet
        type patch;
        faces
            (8 9 10 8)
            (10 9 14 15)
            ( 15 14 11 12 )
    axis
        type empty;
        faces
            (0 3 3 0)
            (3 17 17 3)
            (17 8 8 17)
    frontAndBack_pos
        type wedge;
        faces
            (0 2 3 5)
            (3 5 17 19)
            (17 19 8 10)
            (5 13 19 21)
            (19 21 10 15)
            (13 7 21 23)
            (21 23 15 12)
    frontAndBack_neg
        type wedge;
        faces
            (0 1 3 4)
            (3 4 17 18)
            (17 18 8 9)
            (4 16 18 20)
            (18 20 9 14)
            (16 6 20 22)
            (20 22 14 11)
edges
    //BSpline 17 19 ((0.2 0.003490658503988659 17) (1 0.017453292519943295 16.7) (7 0.12217304763960307 2.3) (7.8 0.1361356816555577 2))
    //BSpline 17 18 ((0.2 -0.003490658503988659 17) (1 -0.017453292519943295 16.7) (7 -0.12217304763960307 2.3) (7.8 -0.1361356816555577 2))
    project 17 19 (sphere2) // block 1-0 block 2-
    project 17 18 (sphere2) // block 1-1 block 2-
    //BSpline 3 4 ((0.2 -0.003490658503988659 15) (1 -0.017453292519943295 14.7) (7 -0.12217304763960307 0.3) (7.8 -0.1361356816555577 0))
    //BSpline 3 5 ((0.2 0.003490658503988659 15) (1 0.017453292519943295 14.7) (7 0.12217304763960307 0.3) (7.8 0.1361356816555577 0))
    project 3 4 (sphere1) // block 0-3
    project 3 5 (sphere1) // block 0-2
    // BSpline
    simpleSpline 0 1
    //BSpline
    simpleSpline 0 2 ((0.2 0.003490658503988659 -15) (1 0.017453292519943295 -15.3) (7 0.12217304763960307 -29.7) (7.8 0.1361356816555577 -30))
    project 0 1 (sphere0) // block 0-0
    project 0 2 (sphere0) // block 0-1
    //BSpline 8 9 ((0.2 -0.003490658503988659 90) (1 -0.017453292519943295 89.7) (7 -0.12217304763960307 75.3) (7.8 -0.1361356816555577 75))
    //BSpline 8 10 ((0.2 0.003490658503988659 90) (1 0.017453292519943295 89.7) (7 0.12217304763960307 75.3) (7.8 0.1361356816555577 75))
    project 8 9 (sphere3) // block 2-0
    project 8 10 (sphere3) // block 2-1
    // https://develop.openfoam.com/Development/openfoam/-/blob/master/tutorials/mesh/blockMesh/sphere7ProjectedEdges/system/blockMeshDict
faces
    project (0 4) sphere0 // block 1: z-min
    project (0 5) sphere1 // block 1: z-max
    project (1 4) sphere1 // block 2: z-min
    project (1 5) sphere2 // block 2: z-max
    project (2 4) sphere2 // block ?: z-min
    project (2 5) sphere3 // block ?: z-max
exnihilo likes this.
snak is offline   Reply With Quote
Old   June 10, 2023, 05:42
Wink
Andrea
Thank you very much! I thought spline was a good instrument since I could have made the flame on a super coarse mesh with a 1/2 step reaction mechanism and then I could have easily fitted the flame front on the spline. This would result in a super fine mesh where needed, but I think I can do something similar with a sphere, just fitting the sphere or with a generated .stl file. Thank you very much again for the suggestions, I will probably add this to the issues on openfoam site.
snak likes this.
blockmesh, edgegrading, simplegrading
cannot converge a pimpleFoam simulation iper88 OpenFOAM Running, Solving & CFD 1 November 26, 2015 09:04
[blockMesh] External flow around cube with blockMesh Woody8 OpenFOAM Meshing & Mesh Conversion 0 March 31, 2015 15:54
error messages about blockmeshing and solving cramsdead OpenFOAM Pre-Processing 2 November 11, 2014 11:53
[OpenFOAM] ParaView shows bad cells, checkMesh doesn't seem to notice. CoolHand ParaView 2 August 21, 2014 16:58
[blockMesh] Blockmesh error - 2D scramjet ishaninair OpenFOAM Meshing & Mesh Conversion 7 March 18, 2011 01:14
