[snappyHexMesh] SnappyHexMesh surfaces intersection refinement
Like Tree3Likes
  • 3 Post By Yann
Old   May 13, 2023, 07:29
Default SnappyHexMesh surfaces intersection refinement
Paolo Baj
PaoloBaj is on a distinguished road
Goodmorning,
for my thesys I have to run some simulations on a rubber screw extruder. It is composed by a long screw which rotates inside a cylinder. I am creating the mesh using SnappyHexMesh, it is a single region mesh.
In the radially most external parts the screw intersects the cylinder (this is correct because I don't want to simulate the clearance between the screw and the cylinder). I would like to get an higher refinement on the intersection between the screw and the cylinder, do you have any suggestions about how could I do it?
Maybe is possible to extract the intersection between the two surfaces? I was also thinking about importing an additional stl surface/volume to use to define the refinement zone but I don't want this surface imported for the refinement to be snapped
PaoloBaj is offline   Reply With Quote
Old   May 14, 2023, 07:40
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hello Paolo,
You could use surfaceFeatureExtract to extract the intersection features between your surfaces and use it for refinement in snappyHexMesh:
outputName1
    extractionMethod    none;
    surfaces            (surface1.stl surface2.stl);
    // Generate additional intersection features (none | self | region)
    intersectionMethod  self;
source: https://develop.openfoam.com/Develop...ureExtractDict
Since you didn't specify which OpenFOAM version you are using, this is for the OpenCFD branch (openfoam.com). I didn't check if it is also possible in the foundation branch (openfoam.org) with surfaceFeatures.
Regards,
Yann
lourencosm, hogsonik and cibanez like this.
Yann is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 10:12
[snappyHexMesh] SnappyHexMesh Problem 96faizizzuddin OpenFOAM Meshing & Mesh Conversion 10 October 10, 2022 07:45
[snappyHexMesh] Edge Refinement fracasce OpenFOAM Meshing & Mesh Conversion 3 December 2, 2017 14:30
[snappyHexMesh] SnappyHexMesh not enough refinement simplefoam OpenFOAM Meshing & Mesh Conversion 2 August 30, 2013 04:37
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh Elise OpenFOAM Meshing & Mesh Conversion 1 April 22, 2013 03:32
