[snappyHexMesh] SnappyHexMesh stuck at "Introducing baffles..."
Like Tree1Likes
  • 1 Post By Rojj
Old   April 9, 2023, 16:49
Default SnappyHexMesh stuck at "Introducing baffles..."
Ruggiero Guida
Rojj is on a distinguished road
I hope someone can provide some advice...
I am meshing a large city geometry with snappyHexMesh and it keeps getting stuck at
Splitting mesh at surface intersections
Introducing baffles for 18354934 faces that are intersected by the surface.
There is no error and the CPUs are all running at 100%.
Honestly, I am a bit lost and I am not sure what to check.
I have been waiting for around an hour. The coarser version of the mesh for the same geometry goes through this part in a few minutes.
If helpful, this is the snappyHexMeshDict
// -*- C++ -*-
// File generated by PyFoam - sorry for the ugliness
FoamFile
 version 2.0;
 format ascii;
 class dictionary;
 object snappyHexMeshDict;
castellatedMesh yes;
snap yes;
addLayers no;
geometry
  refinement_1H
    type searchableCylinder;
    point1 (-10.712 413.668 -109.993);
    point2 (-10.712 413.668 42.916);
    radius 204.29628787216436;
  refinement_3H
    point2 (-10.712 413.668 37.9068);
    radius 306.4444318082466;
  refinement_5H
    point2 (-10.712 413.668 32.9068);
    radius 408.5925757443287;
  refinement_regions
    type triSurfaceMesh;
    file "refinement_regions.stl";
  mct-terrain.stl
    name mct-terrain;
  fixed_surroundings.stl
    name fixed_surroundings;
  far_buildings.stl
    name far_buildings;
  boundary.stl
    name boundary;
    regions
      Bottom
        name Bottom;
      InletOutlet_0
        name InletOutlet_0;
      InletOutlet_1
        name InletOutlet_1;
      InletOutlet_2
        name InletOutlet_2;
      InletOutlet_3
        name InletOutlet_3;
      InletOutlet_4
        name InletOutlet_4;
      InletOutlet_5
        name InletOutlet_5;
      InletOutlet_6
        name InletOutlet_6;
      InletOutlet_7
        name InletOutlet_7;
      Top
        name Top;
}     // Settings for the castellatedMesh generation.
castellatedMeshControls
  maxLocalCells 3859376;
  maxGlobalCells 247000000;     // Refinement parameters// ~~~~~~~~~~~~~~~~~~~~~// If local number of cells is >= maxLocalCells on any processor// switches from from refinement followed by balancing// (current method) to (weighted) balancing before refinement.// Overall cell limit (approximately). Refinement will stop immediately// upon reaching this number so a refinement level might not complete.// Note that this is the number of cells before removing the part which// is not 'visible' from the keepPoint. The final number of cells might// actually be a lot less.  // The surface refinement loop might spend lots of iterations refining just a// few cells. This setting will cause refinement to stop if <= minimumRefine// are selected for refinement. Note: it will at least do one iteration// (unless the number of cells to refine is 0)
  minRefinementCells 4;     // Allow a certain level of imbalance during refining// (since balancing is quite expensive)// Expressed as fraction of perfect balance (= overall number of cells /// nProcs). 0=balance always.
  maxLoadUnbalance 0.1;     // Number of buffer layers between different levels.// 1 means normal 2:1 refinement restriction, larger means slower// refinement.
  nCellsBetweenLevels 1;     // Explicit feature edge refinement// ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~// Specifies a level for any cell intersected by explicitly provided// edges.// This is a featureEdgeMesh, read from constant/triSurface for now.// Specify 'levels' in the same way as the 'distance' mode in the// refinementRegions (see below). The old specification//      level   2;// is equivalent to//      levels  ((0 2));
  features
    );     // Surface based refinement// ~~~~~~~~~~~~~~~~~~~~~~~~// Specifies two levels for every surface. The first is the minimum level,// every cell intersecting a surface gets refined up to the minimum level.// The second level is the maximum level. Cells that 'see' multiple// intersections where the intersections make an// angle > resolveFeatureAngle get refined up to the maximum level.// Surface-wise min and max refinement level
  refinementSurfaces
    mct-terrain
      level
          2
          4
    boundary
      level
          2
          4
    fixed_surroundings
      level
          2
          3
    far_buildings
      level
          1
          2
    }     //- Optional increment (on top of max level) in small gaps//gapLevelIncrement 2;//- Optional angle to detect small-large cell situation//  perpendicular to the surface. Is the angle of face w.r.t.//  the local surface normal. Use on flat(ish) surfaces only.//  Otherwise leave out or set to negative number.//perpendicularAngle 10;//- Optional faceZone and (for closed surface) cellZone with//  how to select the cells that are in the cellZone//  (inside / outside / specified insidePoint)//  The orientation of the faceZone is//  - if on cellZone(s) : point out of (maximum) cellZone//  - if freestanding   : oriented according to surface//faceZone sphere;//cellZone sphere;//cellZoneInside inside;  //outside/insidePoint//- Optional specification of what to do with faceZone faces://      internal : keep them as internal faces (default)//      baffle   : create baffles from them. This gives more//                 freedom in mesh motion//      boundary : create free-standing boundary faces (baffles//                 but without the shared points)//faceType baffle;
  }     // Feature angle:// - used if min and max refinement level of a surface differ// - used if feature snapping (see snapControls below) is used
  resolveFeatureAngle 30;     //- Optional increment (on top of max level) in small gaps//gapLevelIncrement 2;// Planar angle:// - used to determine if surface normals//   are roughly the same or opposite. Used//      - in proximity refinement//      - to decide when to merge free-standing baffles//        (if e.g. running in surfaceSimplify mode set this to 180 to//         merge all baffles)//      - in snapping to avoid snapping to nearest on 'wrong' side//        of thin gap//// If not specified same as resolveFeatureAngle
  planarAngle 30;     // Region-wise refinement// ~~~~~~~~~~~~~~~~~~~~~~// Specifies refinement level for cells in relation to a surface. One of// three modes// - distance. 'levels' specifies per distance to the surface the//   wanted refinement level. The distances need to be specified in//   increasing order.// - inside. 'levels' is only one entry and only the level is used. All//   cells inside the surface get refined up to the level. The surface//   needs to be closed for this to be possible.// - outside. Same but cells outside.
  refinementRegions
    refinement_1H
      mode inside;
      levels
            1000000000000000.0
            3
    refinement_3H
      mode inside;
      levels
            1000000000000000.0
            2
    refinement_5H
      mode inside;
      levels
            1000000000000000.0
            1
    mct-terrain
      mode distance;
      levels
            2.0
            3
    fixed_surroundings
      mode distance;
      levels
            1.0
            3
            4.0
            2
    far_buildings
      mode distance;
      levels
            1.0
            1
            4.0
            1
  }     // Mesh selection// ~~~~~~~~~~~~~~// After refinement patches get added for all refinementSurfaces and// all cells intersecting the surfaces get put into these patches. The// section reachable from the locationInMesh is kept.// NOTE: This point should never be on a face, always inside a cell, even// after refinement.
  locationInMesh (-10.712045025920519 413.66830664447565 929.9970092773438);     // Whether any faceZones (as specified in the refinementSurfaces)// are only on the boundary of corresponding cellZones or also allow// free-standing zone faces. Not used if there are no faceZones.
  allowFreeStandingZoneFaces no;
}     // Settings for the snapping.
snapControls
  nSmoothPatch 3;
  tolerance 2.0;     // Number of patch smoothing iterations before finding correspondence// to surface// Maximum relative distance for points to be attracted by surface.// True distance is this factor times local maximum edge length.// Note: changed(corrected) w.r.t 17x! (17x used 2* tolerance)  // Number of mesh displacement relaxation iterations.
  nSolveIter 300;     // Maximum number of snapping relaxation iterations. Should stop// before upon reaching a correct mesh.
  nRelaxIter 10;     // Feature snapping// Number of feature edge snapping iterations.// Leave out altogether to disable.
  nFeatureSnapIter 15;     // Detect (geometric only) features by sampling the surface// (default=false).
  implicitFeatureSnap yes;
  explicitFeatureSnap no;
  multiRegionFeatureSnap no;
}     // Settings for the layer addition.
addLayersControls
  relativeSizes no;
  expansionRatio 1.05;     // Are the thickness parameters below relative to the undistorted// size of the refined cell outside layer (true) or absolute sizes (false).// Layer thickness specification. This can be specified in one of following// ways:// - expansionRatio and finalLayerThickness (cell nearest internal mesh)// - expansionRatio and firstLayerThickness (cell on surface)// - overall thickness and firstLayerThickness// - overall thickness and finalLayerThickness// - overall thickness and expansionRatio//// Note: the mode thus selected is global, i.e. one cannot override the//       mode on a per-patch basis (only the values can be overridden)// Expansion factor for layer mesh// Wanted thickness of the layer furthest away from the wall.// If relativeSizes this is relative to undistorted size of cell// outside layer.
  finalLayerThickness 0.25;     // Wanted overall thickness of layers.// If relativeSizes this is relative to undistorted size of cell// outside layer.//thickness 0.5// Minimum overall thickness of total layers. If for any reason layer// cannot be above minThickness do not add layer.// If relativeSizes this is relative to undistorted size of cell// outside layer..
  minThickness 0.1;     // Per final patch (so not geometry!) the layer information// Note: This behaviour changed after 21x. Any non-mentioned patches//       now slide unless://          - nSurfaceLayers is explicitly mentioned to be 0.//          - angle to nearest surface < slipFeatureAngle (see below)
  layers
    mct-terrain
      nSurfaceLayers 4;
    fixed_surroundings
      nSurfaceLayers 0;
    far_buildings
      nSurfaceLayers 0;
  }     // If points get not extruded do nGrow layers of connected faces that are// also not grown. This helps convergence of the layer addition process// close to features.// Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
  nGrow 0;     // Advanced settings// Static analysis of starting mesh// When not to extrude surface. 0 is flat surface, 90 is when two faces// are perpendicular
  featureAngle 310;     // Stop layer growth on highly warped cells
  maxFaceThicknessRatio 1.0;     // Patch displacement// Number of smoothing iterations of surface normals
  nSmoothSurfaceNormals 1;     // Smooth layer thickness over surface patches
  nSmoothThickness 10;     // Medial axis analysis// Angle used to pick up medial axis points// Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130// in 17x.
  minMedianAxisAngle 5;     // Reduce layer growth where ratio thickness to medial// distance is large
  maxThicknessToMedialRatio 0.3;     // Number of smoothing iterations of interior mesh movement direction
  nSmoothNormals 3;     // Optional: limit the number of steps walking away from the surface.// Default is unlimited.//nMedialAxisIter 10;// Optional: smooth displacement after medial axis determination.// default is 0.//nSmoothDisplacement 90;// (wip)Optional: do not extrude a point if none of the surrounding points is// not extruded. Default is false.//detectExtrusionIsland true;        // Mesh shrinking        // Optional: at non-patched sides allow mesh to slip if extrusion// direction makes angle larger than slipFeatureAngle. Default is// 0.5*featureAngle.
  slipFeatureAngle 80;     // Maximum number of snapping relaxation iterations. Should stop// before upon reaching a correct mesh.
  nRelaxIter 3;     // Create buffer region for new layer terminations
  nBufferCellsNoExtrude 0;     // Overall max number of layer addition iterations. The mesher will// exit if it reaches this number of iterations; possibly with an// illegal mesh.
  nLayerIter 10;     // Max number of iterations after which relaxed meshQuality controls// get used. Up to nRelaxedIter it uses the settings in// meshQualityControls,// after nRelaxedIter it uses the values in// meshQualityControls::relaxed.
  nRelaxedIter 20;     // Additional reporting: if there are just a few faces where there// are mesh errors (after adding the layers) print their face centres.// This helps in tracking down problematic mesh areas.//additionalReporting true;
}     // Generic mesh quality settings. At any undoable phase these determine// where to undo.
meshQualityControls
#include "meshQualityDict"
  relaxed
    maxNonOrtho 75;
  }     // Specify mesh quality constraints in separate dictionary so can// be reused (e.g. checkMesh -meshQuality)// Optional : some meshing phases allow usage of relaxed rules.// See e.g. addLayersControls::nRelaxedIter.// Maximum non-orthogonality allowed. Set to 180 to disable.// Advanced// Number of error distribution iterations
  nSmoothScale 4;     // amount to scale back displacement at error points
  errorReduction 0.75;
}     // Advanced//// Debug flags//debugFlags//(//    mesh            // write intermediate meshes//    intersections   // write current mesh intersections as .obj files//    featureSeeds    // write information about explicit feature edge//                    // refinement//    attraction      // write attraction as .obj files//    layerInfo       // write information about layers//);//
writeFlags
    scalarLevels
    layerSets
    layerFields
  );     // write volScalarField with cellLevel for postprocessing// write cellSets, faceSets of faces in layer// write volScalarField for layer coverage// Merge tolerance. Is fraction of overall bounding box of initial mesh.// Note: the write tolerance needs to be higher than this.
mergeTolerance 1e-06;     // ************************************************************************* //
EDIT
The "problem" seems to go away by setting the levels in the fixed_surrounding refinement surfaces to a value of (3 3) rather than (2 3).
    fixed_surroundings
      level
          3 (instead of 2)
          3
I made this change based on a suggestion of a colleague, but I do not really understand why it works.
Rojj is offline   Reply With Quote
Old   June 30, 2023, 09:14
Ruggiero Guida
Just in case it helps. It seems that improving the quality of the STL triSurfaces also solves the problem.
I am using MeshLab to re-triangulate. The filter I use is called Remeshing: Isotropic Explicit Remeshing
arezayan87 likes this.
snappyhesmesh
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 10:12
[snappyHexMesh] weird results with snappyHexMesh probably produced by (unrecognized) internal baffles jango OpenFOAM Meshing & Mesh Conversion 2 October 7, 2020 05:41
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 18:16
[snappyHexMesh] creating baffles using snappyHexMesh (for given random shaped surfaces) ashish.svm OpenFOAM Meshing & Mesh Conversion 1 January 17, 2018 02:24
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
