[Other] foam (com version) to any format compatible with Code_Saturne
Like Tree1Likes
  • 1 Post By finzeo
Old   March 30, 2023, 13:27
Default foam (com version) to any format compatible with Code_Saturne
LordKelvin94 is on a distinguished road
Hi all,
Until recently I was managing to use meshes created in OF 7 (blockMesh + snappy) in Code_Saturne (version 7), using the foamMeshToMED utility compiled for OF 4, but working for OF 7. Due to difficulties, and wanting to take advantage of the possibilities of the com version, I switched from OF 7 to OF 1812 and later (specifically, because I wanted to use the displacementMotionSolver algorithm for addLayers, only available in the com version). But doing this, the foamMeshToMED utility gives me problems (specifically, topology problems that arise during the CS run, whereas with checkMesh I don't get any errors). The specific question is if you know of any tool to go from an OF mesh to one of the following CS-compatible formats:
.case (Ensight) (I already tried this, and as I see in CS forum, it does not copy the patches)
.ccm (Star-CCM+) (I couldn't export the mesh as .ccm, but with .ccmg, but the latter is not recognized by CS)
.cgns
.des (Simail NOPO)
.med
.msh (Gmsh)
.neu (GAMBIT neutral)
.unv (I-deas universal)
LordKelvin94 is offline   Reply With Quote
Old   June 11, 2024, 15:13
Behradskn is on a distinguished road
Could you find any solution for your problem?
Behradskn is offline   Reply With Quote
Old   June 11, 2024, 16:15
Facundo
finzeo is on a distinguished road
I was able to partially resolve it by conveniently choosing which version of OF and which version of foamMeshToMED to use. A GitHub user uploaded a version of foamMeshToMED compatible with v2106 (https://github.com/oseen/foamMeshToM...OpenFOAM-v2106), which works well for me with Code_Saturne v8.0.1. You must compile it manually. For some complex meshes, for some reason, it fails unless you check the "fix mesh" option in the Code_Saturne GUI.
Behradskn likes this.
finzeo is offline   Reply With Quote
Old   June 24, 2024, 02:54
Default About the tool foamMeshToMED
cxr
xiran cao
cxr is on a distinguished road
Could the tool foamMeshToMED convert the mesh from openfoam to the type that gmsh could read in?
cxr is offline   Reply With Quote
code_saturne, foammeshtomed, med, of.com
twoPhaseEulerFoam confined plunging jet simulation failed ves OpenFOAM Running, Solving & CFD 2 June 17, 2020 06:08
Foam::error::printStack(Foam::Ostream&) at ??:? mdhfiz OpenFOAM Running, Solving & CFD 1 September 19, 2019 10:46
[Gmsh] Version 20 of the bmshb file format to FOAM converter 7islands OpenFOAM Meshing & Mesh Conversion 36 February 9, 2019 23:47
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
