[Commercial meshers] Axisymmetric mesh generation in Pointwise like hollow cylinder geometry |
March 28, 2023, 03:44 |
Rep Power: 9 |
Hi guys,
I am trying to create a mesh in pointwise for openfoam. I have hollow cylinder like geometry, so my axis of rotation is not on mesh surface, my inner face must be wall and not axis. I generate 2D axisymmetric (I hope) structured mesh (choosing 3D option and extruding around x axis by 5 deg and 1 cell long). Then I have three questions; 1) which axis must be rotation axis? is there a restriction in openfoam? 2) if there is no restriction, how can i tell to OF my rotation axis? is there a specific input file and option to define it? 3) Suppose I give the face boundary conditions correctly, but i couldn't figure out volume conditions in Pointwise. which volume condition do i have to choose in pointwise (ie. volumetocell, volumetoface etc. there are bunch of options)? |
March 28, 2023, 08:12 |
Gerhard Holzinger
Rep Power: 28 |
ad 1)
There is no requirement to use a specific axis as your axis of rotation. It can be any of the three principal axes. If you create an axi-symmetric mesh, it needs to straddle a principal plane, see the image attached. Furthermore, you need to create two distinct wedge-type patches, since each wedge-type patch needs to be planar. |
March 28, 2023, 08:16 |
[snappyHexMesh] Hollow Cylinder mesh region | tskmf | OpenFOAM Meshing & Mesh Conversion | 0 | May 28, 2021 12:48 |
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh | czhongrong | OpenFOAM Meshing & Mesh Conversion | 1 | January 20, 2016 05:26 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Geometry and mesh generation in OpenFoam | pokeng | OpenFOAM Pre-Processing | 1 | October 28, 2011 21:40 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
