[Gmsh] How can I fix mesh size in GMSH?
Like Tree1Likes
  • 1 Post By Hr_kules
Old   March 15, 2023, 22:14
Default How can I fix mesh size in GMSH?
Nazmul Islam
nazmulislam is on a distinguished road
I have constructed geometry for an axisymmetric periodic tube and have made unstructured mesh in GMSH.
However, I am not sure how can I fix the mesh size (what will be mesh size) to get a convergent solution?
I really appreciate your help in this regard.
nazmulislam is offline   Reply With Quote
Old   March 16, 2023, 07:05
Nico
Hr_kules is on a distinguished road
what exactly do you mean by fixing?
Hr_kules is offline   Reply With Quote
Old   March 16, 2023, 07:14
Nazmul Islam
By fixing I meant the mesh size to get the convergent solution.
That is, what mesh size should i consider for the convergent solution.
Old   March 16, 2023, 07:33
Nico
There is, to my knowledge, no answer to this but to run multiple simulations with different mesh sizes and see wether the results change with the mesh size or not. (Grind inpedendent solution)
If your mesh already fails to converge changing the mesh size won't magically fix all your problems. Consider the checkMesh utility of openFoam, if this is without errors you still don't have the guarantee that your simulation will converge. Your boundary conditions could be wrong, the solver not suited for your case or the numerical schemes (fvSolution/fvSchemes) could be wrong.
nazmulislam likes this.
Old   March 17, 2023, 03:08
Nazmul Islam
Thanks for providing your suggestions in this regard.
I am solving unsteady laminar, incompressible flow and I am using icoFoam solver to do this.
Cheers
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
