Rep Power: 4 ![]() |
I've been attempting to add new points to geometry for an existing case file, does it matter what order the points are listed in within the vertices section of blockMeshDict? At the moment I'm guessing that as long as the index of the point in the vertices section is used in the blocks section, then it's fine, but I'm not sure about this
#2 | |
Mark Olesen
Rep Power: 40 ![]() ![]() |
Using the quick help from blockMesh -help: Code:
The ordering of vertex and face labels within a block as shown below. For the local vertex numbering in the sequence 0 to 7: Faces 0, 1 (x-direction) are left, right. Faces 2, 3 (y-direction) are front, back. Faces 4, 5 (z-direction) are bottom, top. 7 ---- 6 f5 |\ :\ f3 | | 4 ---- 5 \ | 3.|....2 | \ | \| \| f2 f4 0 ---- 1 Y Z \ | f0 ------ f1 \| o--- X Code:
boundary ( walls { type wall; faces ( (0 0) // x-min (0 1) // x-max (0 2) // y-min (0 3) // y-max (0 4) // z-min (0 5) // z-max ); } ); |
block mesh, blockmeshdict |
blockMesh - two blocks with different vertices | Rojj | OpenFOAM Pre-Processing | 3 | March 21, 2023 20:39 |
blockMesh error: ill defined primitiveEntry starting at keyword 'vertices' | mgab | OpenFOAM Pre-Processing | 3 | January 24, 2017 03:03 |
[blockMesh] blockMesh - numbering of vertices with multiple blocks | AmRo | OpenFOAM Meshing & Mesh Conversion | 6 | May 16, 2016 05:05 |
[blockMesh] blockMesh problem with blocks with vertices | adrieno | OpenFOAM Meshing & Mesh Conversion | 3 | March 23, 2016 03:35 |
[Technical] how to order the vertices in blockMesh? | andrei.cimpoeru | OpenFOAM Meshing & Mesh Conversion | 2 | December 11, 2012 13:17 |
