[snappyHexMesh] did not determine new position of face |
November 29, 2022, 05:22 |
Vijay
Rep Power: 6 |
Hello everybody,
I am trying to do meshing with snappyHexMesh. After some time of running this command, system stops executing giving me the error - Code:
Overview X GM Terminal --> FOAM FATAL ERROR: (openfoam-2012) Did not determine new position for face 16564641 owner 4710458 neighbour -1 region -1 This is usually caused by not specifying a patch for a boundary face. Switch on the polyTopoChange::debug flag to catch this error earlier. points (removed points marked with (1e+300 1e+300 1e+300)) 4((3.61303e-26 32.6333 1.002 32) (3.3462e-25 32.6411 1.00232) (-7.32146e-27 32.6411 1) (-7.86327e-28 32.6333 1)) From void Foam::polyTopoChange::getFaceOrder(Foam::label, const labelUList&, const labelUList&, Foam::labelList&, Foam::labelList&, Foam::labelList&) const in file polyTopoChange/polyTopoChange.0 at line 835. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::exitOrAbort(int, boot) at ??:? #2 Foam::polyTopoChange::getFaceOrder(int, Foam::UList<int> const&, Foam::UList<int> c onst&, Foam::List<int>&, Foam::List<int>&, Foam::List<int>&) const at ??:? #3 Foam::polyTopoChange::compact(bool, boot, int&, Foam::List<intA, Foam::List<int>&) at ??:? "EVijay_01.txt" 25L, 2320C 1,0-1 Top |
April 21, 2023, 05:13 |
Alessandro Chiodi
Thank you so much for posting it, I am facing exactly the same problem in tryin' to add Boundary Layers to a domain provided by cyclic patches: I know this is a really old post but, please, if someone has some hints share them with us.
meshing, patchbc, polytopochange, snappyhesmesh |
[snappyHexMesh] Invalid Normals for source face to target face while making AMI? | Sorabh | OpenFOAM Meshing & Mesh Conversion | 1 | August 3, 2021 06:35 |
createPatch Segmentation Fault (CORE DUMPED) | sam.ho | OpenFOAM Pre-Processing | 2 | April 21, 2014 02:01 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
