[snappyHexMesh] Partial coarse mesh
Like Tree7Likes
  • 2 Post By AtoHM
  • 3 Post By linnemann
  • 2 Post By linnemann
Old   November 22, 2022, 03:02
Default Partial coarse mesh
Marius
Counterdoc is on a distinguished road
I tried to mesh a car with snappyHexMesh and at the first look it came out quite well. But as I checked some parts of it I found that they are super coarse and I don't know why. Additionally I found that the bottom of the tyres are not closed? I put them exactly on z 0.0.
What could cause this? Would addLayers solve it?
|  \\    /   O peration     | Version:  v2206                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            true;
addLayers       false;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
    clio3rs.stl
        type triSurfaceMesh;
        name clio3rs;
    refinementBox
        type box;
        min  (-0.8027 -0.8881 0.0);
        max  (3.1784 0.8883 1.465);
// Settings for the castellatedMesh generation.
castellatedMeshControls
    // Refinement parameters
    // If local number of cells is >= maxLocalCells on any processor
    // switches from from refinement followed by balancing
    // (current method) to (weighted) balancing before refinement.
    maxLocalCells 10000000;
    // Overall cell limit (approximately). Refinement will stop immediately
    // upon reaching this number so a refinement level might not complete.
    // Note that this is the number of cells before removing the part which
    // is not 'visible' from the keepPoint. The final number of cells might
    // actually be a lot less.
    maxGlobalCells 10000000;
    // The surface refinement loop might spend lots of iterations refining just a
    // few cells. This setting will cause refinement to stop if <= minimumRefine
    // are selected for refinement. Note: it will at least do one iteration
    // (unless the number of cells to refine is 0)
    minRefinementCells 0;
    // Allow a certain level of imbalance during refining
    // (since balancing is quite expensive)
    // Expressed as fraction of perfect balance (= overall number of cells /
    // nProcs). 0=balance always.
    maxLoadUnbalance 0.10;
    // Number of buffer layers between different levels.
    // 1 means normal 2:1 refinement restriction, larger means slower
    // refinement.
    nCellsBetweenLevels 3;
    // Explicit feature edge refinement
    // Specifies a level for any cell intersected by its edges.
    // This is a featureEdgeMesh, read from constant/triSurface for now.
    features
            file "clio3rs.eMesh";
            level 6;
    // Surface based refinement
    // Specifies two levels for every surface. The first is the minimum level,
    // every cell intersecting a surface gets refined up to the minimum level.
    // The second level is the maximum level. Cells that 'see' multiple
    // intersections where the intersections make an
    // angle > resolveFeatureAngle get refined up to the maximum level.
    refinementSurfaces
        clio3rs
            // Surface-wise min and max refinement level
            level (4 6);
    // Resolve sharp angles
    resolveFeatureAngle 30;
    // Region-wise refinement
    // Specifies refinement level for cells in relation to a surface. One of
    // three modes
    // - distance. 'levels' specifies per distance to the surface the
    //   wanted refinement level. The distances need to be specified in
    //   descending order.
    // - inside. 'levels' is only one entry and only the level is used. All
    //   cells inside the surface get refined up to the level. The surface
    //   needs to be closed for this to be possible.
    // - outside. Same but cells outside.
    refinementRegions
        //refinementBox
        //    mode inside;
        //    levels ((1E15 6));
    // Mesh selection
    // After refinement patches get added for all refinementSurfaces and
    // all cells intersecting the surfaces get put into these patches. The
    // section reachable from the locationInMesh is kept.
    // NOTE: This point should never be on a face, always inside a cell, even
    // after refinement.
    locationInMesh (-1.95 1.45 0.01);
    // Whether any faceZones (as specified in the refinementSurfaces)
    // are only on the boundary of corresponding cellZones or also allow
    // free-standing zone faces. Not used if there are no faceZones.
    allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
    //- Number of patch smoothing iterations before finding correspondence
    //  to surface
    nSmoothPatch 8;
    //- Relative distance for points to be attracted by surface feature point
    //  or edge. True distance is this factor times local
    //  maximum edge length.
    tolerance 1.0;
    //- Number of mesh displacement relaxation iterations.
    nSolveIter 80;
    //- Maximum number of snapping relaxation iterations. Should stop
    //  before upon reaching a correct mesh.
    nRelaxIter 8;
    // Feature snapping
    //- Number of feature edge snapping iterations.
    //  Leave out altogether to disable.
    nFeatureSnapIter 20;
    //- Detect (geometric only) features by sampling the surface
    //  (default=false).
    implicitFeatureSnap false;
    //- Use castellatedMeshControls::features (default = true)
    explicitFeatureSnap true;
    //- Detect points on multiple surfaces (only for explicitFeatureSnap)
    multiRegionFeatureSnap false;
// Settings for the layer addition.
addLayersControls
    // Are the thickness parameters below relative to the undistorted
    // size of the refined cell outside layer (true) or absolute sizes (false).
    relativeSizes true;
    // Per final patch (so not geometry!) the layer information
    layers
        clio3rs
            nSurfaceLayers 3;
    // Expansion factor for layer mesh
    expansionRatio 1.0;
    // Wanted thickness of final added cell layer. If multiple layers
    // is the thickness of the layer furthest away from the wall.
    // Relative to undistorted size of cell outside layer.
    // See relativeSizes parameter.
    finalLayerThickness 0.3;
    // Minimum thickness of cell layer. If for any reason layer
    // cannot be above minThickness do not add layer.
    minThickness 0.1;
    // If points get not extruded do nGrow layers of connected faces that are
    // also not grown. This helps convergence of the layer addition process
    // close to features.
    // Note: changed(corrected) w.r.t 1.7.x! (didn't do anything in 1.7.x)
    nGrow 0;
    // Advanced settings
    // When not to extrude surface. 0 is flat surface, 90 is when two faces
    // are perpendicular
    featureAngle 130;
    // At non-patched sides allow mesh to slip if extrusion direction makes
    // angle larger than slipFeatureAngle.
    slipFeatureAngle 30;
    // Maximum number of snapping relaxation iterations. Should stop
    nRelaxIter 8;
    // Number of smoothing iterations of surface normals
    nSmoothSurfaceNormals 1;
    // Number of smoothing iterations of interior mesh movement direction
    nSmoothNormals 3;
    // Smooth layer thickness over surface patches
    nSmoothThickness 10;
    // Stop layer growth on highly warped cells
    maxFaceThicknessRatio 0.5;
    // Reduce layer growth where ratio thickness to medial
    // distance is large
    maxThicknessToMedialRatio 0.3;
    // Angle used to pick up medial axis points
    // Note: changed(corrected) w.r.t 1.7.x! 90 degrees corresponds to 130
    // in 1.7.x.
    minMedialAxisAngle 90;
    // Create buffer region for new layer terminations
    nBufferCellsNoExtrude 0;
    // Overall max number of layer addition iterations. The mesher will exit
    // if it reaches this number of iterations; possibly with an illegal
    // mesh.
    nLayerIter 60;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    #include "meshQualityDict"
    // Advanced
    //- Number of error distribution iterations
    nSmoothScale 4;
    //- Amount to scale back displacement at error points
    errorReduction 0.75;
// Advanced
// Write flags
writeFlags
    scalarLevels
    layerSets
    layerFields     // write volScalarField for layer coverage
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1e-6;
Thank you!
Best,
Marius
File Type: jpg Screenshot from 2022-11-22 07-45-34.jpg (122.8 KB, 33 views)
File Type: jpg Screenshot from 2022-11-22 07-53-51.jpg (146.0 KB, 32 views)
Counterdoc is offline   Reply With Quote
Old   November 24, 2022, 03:59
M
AtoHM is on a distinguished road
I see nothing unusual, so just some thoughts:
1) try minRefinementCells > 0 (1?)
2) try surfaceRefinement with min and max level 5 6 or 4 5 and not two levels apart
3) do you reach 10M cells in the process? Then increase maxGlobalCells.
Regarding the wheel: Does the blockMesh really cover the geometry completely?
Counterdoc and PedroS like this.
AtoHM is offline   Reply With Quote
Old   November 24, 2022, 11:22
Marius
Thanks for the help.
I just increased minRefinementCells to 10 and also adjusted surfaceRefinement to 5 6.
Regarding 3)
I reach 10M cells, yes. But as soon as I increase the value for maxGlobalCells snappyHexMesh just crashes and closes the terminal window. I have no idea why. I started with 8 cores in parallel meshing and reduced it to 4, but no luck.
Setup is:
Ryzen 7 3800X - 8 physical cores at 4.7 GHz
32 GB DDR4 3200 RAM
I can see that the RAM hits the 32 GB while meshing and uses the swap partition.
Oh and regarding the blockMesh. The car is at Z 0.0 and the blockMesh also ends at Z 0.0. I just set Z to -1.0E-4
Old   November 24, 2022, 13:52
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
You could scale the mesh/geometry to mm so that snappy has larger numbers to work with.
Precission is better when 1 is 1.0 and not 0.001
It does not always help, but I've found it genereally performs a bit better.
Sometimes I wonder if Snappy were to be faster if everything internally was integers. just scale the mesh geometry so 1mm is 1000 then precission could still be ok when converting to m again.
AtoHM, reverseila and Counterdoc like this.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   November 25, 2022, 03:02
M
Ok, so the cell cap is most likely the reason you have these big cells, once snappy hits the cap, it just stops refinement.
Regarding blockMesh: indeed, I always provide a slightly bigger blockMesh than the bounding box of the stl to avoid such effects. So, this should be fixed now as well?
But it appears to be a memory issue now and I don't know how to resolve that other than getting more resources.
Interesting remarks from linnemann, will there be an influence on the memory there?
Old   November 25, 2022, 03:30
Marius
Currently snappyHexMesh is running with 40M cells and it still reaches that limit. But I guess that is normal for a whole car that should have a fine mesh. I have seen a bachelor thesis from an Audi student with a 70M cells mesh.
Regarding memory I think I will upgrade the RAM to 64 GB. For more I would have to build a new PC or switch the whole calculations to a server with big resources.
Old   November 25, 2022, 07:31
linnemann's Avatar
Niels Nielsen
Rule of thumb, 1GB of memory per 1mil cells.
Linnemann
Old   November 25, 2022, 07:38
Marius
Good tip, thank you! I will upgrade the RAM :-)
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 06:02
[snappyHexMesh] non uniform mesh near the stl object vava10 OpenFOAM Meshing & Mesh Conversion 0 January 31, 2021 15:41
Can I just use a coarse mesh as my final mesh size? cfdnewb123 Main CFD Forum 8 January 17, 2021 06:11
Grid transformation to computational space mech_eng_gr Main CFD Forum 1 May 31, 2020 22:17
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
