[snappyHexMesh] On refinement limits
Like Tree1Likes
  • 1 Post By AtoHM
Old   October 16, 2022, 16:34
Smile On refinement limits
F
fran.cesc is on a distinguished road
Good day,
I am having a problem with creating a mesh.
I am using snappyHexMesh. I had maxGlobalCells set to 2 millions, but then I had this message:
Shell refinement iteration 3
No cells marked for refinement since reached limit 2000000
snappyHexMesh runs until the end, but I get a mesh without the level of refinement I have set.
So I increased the maxGlobalCells, but then when I do that, snappyHexMesh does not run. I get:
Marked for refinement due to distance to explicit features: 0 cells
Marked for refinement due to refinement shells: 3353488 cells
Determined cells to refine in : 1.53s
Selected for internal refinement: 3353488 cells (out of 7700908)
Killed
Something similar happens also when I try to extrudeMesh. If I have a small number of faces to extrude then it is fine. As soon as the number of faces to extrude raises to a 3 or 4 millions then the process is killed.
Do you have any idea why this happens?
Thanks and have a great day
fran.cesc is offline   Reply With Quote
Old   October 17, 2022, 02:54
M
AtoHM is on a distinguished road
Appears like a memory issue to me, maybe these help?
killed "snappyHexMesh"
solved issue of running out of virtual memory crashes
fran.cesc likes this.
AtoHM is offline   Reply With Quote
maxglobalcells, mesh, open foam, refinement, snappyhexmesh
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 02:37
problem with parallel calculations OF8 mpirun otaolafr OpenFOAM Programming & Development 0 January 5, 2021 08:33
SimpleFoam & Theater jipai OpenFOAM Running, Solving & CFD 3 June 18, 2019 11:11
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 18:12
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
