[snappyHexMesh] cells between layers not added when using expansion ratio in blockMesh
Like Tree2Likes
  • 1 Post By AtoHM
  • 1 Post By AtoHM
Old   September 21, 2022, 11:23
Default cells between layers not added when using expansion ratio in blockMesh
Marcelo Ruiz
CFDavatar is on a distinguished road
Dear All,
I have tried to reproduce some experiments in a flume of a fish. In this sense, I would like to solve the boundary layer of the walls of the channel and try to reproduce it. But when I used expansion ratio in blockMesh no layers are added to the fish in snappyHexMesh. The refinement in the fish works when I use expnasion ratio 1 in blockMeshDict You can see it in the images attached.
I have also attached my snappyHexMeshDict.
|  \\    /   O peration     | Version:  2206                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            true;
addLayers       false;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
    fish.stl
        type triSurfaceMesh;
        name fish;
// Settings for the castellatedMesh generation.
castellatedMeshControls
    // Refinement parameters
    // If local number of cells is >= maxLocalCells on any processor
    // switches from from refinement followed by balancing
    // (current method) to (weighted) balancing before refinement.
    maxLocalCells 5000000;
    // Overall cell limit (approximately). Refinement will stop immediately
    // upon reaching this number so a refinement level might not complete.
    // Note that this is the number of cells before removing the part which
    // is not 'visible' from the keepPoint. The final number of cells might
    // actually be a lot less.
    maxGlobalCells 30000000;
    // The surface refinement loop might spend lots of iterations refining just a
    // few cells. This setting will cause refinement to stop if <= minimumRefine
    // are selected for refinement. Note: it will at least do one iteration
    // (unless the number of cells to refine is 0)
    minRefinementCells 4;//2;
    // Number of buffer layers between different levels.
    // 1 means normal 2:1 refinement restriction, larger means slower
    // refinement.
    nCellsBetweenLevels 6; //7;
    // Explicit feature edge refinement
    // Specifies a level for any cell intersected by its edges.
    // This is a featureEdgeMesh, read from constant/triSurface for now.
    features
            file "fish.eMesh";
            level 4;
    // Surface based refinement
    // Specifies two levels for every surface. The first is the minimum level,
    // every cell intersecting a surface gets refined up to the minimum level.
    // The second level is the maximum level. Cells that 'see' multiple
    // intersections where the intersections make an
    // angle > resolveFeatureAngle get refined up to the maximum level.
    refinementSurfaces
        fish
            // Surface-wise min and max refinement level
            level (2 4);
    resolveFeatureAngle 20;
    // Region-wise refinement
    // Specifies refinement level for cells in relation to a surface. One of
    // three modes
    // - distance. 'levels' specifies per distance to the surface the
    //   wanted refinement level. The distances need to be specified in
    //   descending order.
    // - inside. 'levels' is only one entry and only the level is used. All
    //   cells inside the surface get refined up to the level. The surface
    //   needs to be closed for this to be possible.
    // - outside. Same but cells outside.
    refinementRegions
        fish
            mode inside;
            levels ((2 4));
    // Mesh selection
    // After refinement patches get added for all refinementSurfaces and
    // all cells intersecting the surfaces get put into these patches. The
    // section reachable from the locationInMesh is kept.
    // NOTE: This point should never be on a face, always inside a cell, even
    // after refinement.
    // This is an outside point locationInMesh (-0.033 -0.033 0.0033);
    //locationInMesh (6.00 1.10 1.0); // Inside point
    locationInMesh (-475.351 0 0); // Inside point
    // Whether any faceZones (as specified in the refinementSurfaces)
    // are only on the boundary of corresponding cellZones or also allow
    // free-standing zone faces. Not used if there are no faceZones.
    allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
    //- Number of patch smoothing iterations before finding correspondence
    //  to surface
    nSmoothPatch 8;
    //- Relative distance for points to be attracted by surface feature point
    //  or edge. True distance is this factor times local
    //  maximum edge length.
    tolerance 4;
    //- Number of mesh displacement relaxation iterations.
    nSolveIter 5;
    //- Maximum number of snapping relaxation iterations. Should stop
    //  before upon reaching a correct mesh.
    nRelaxIter 5;
    // Feature snapping
        //- Number of feature edge snapping iterations.
        //  Leave out altogether to disable.
        nFeatureSnapIter 5;
        //- Detect (geometric) features by sampling the surface
        implicitFeatureSnap true;
        //- Use castellatedMeshControls::features
        explicitFeatureSnap false;
        //- Detect features between multiple surfaces
        //  (only for explicitFeatureSnap, default = false)
        multiRegionFeatureSnap false;
// Settings for the layer addition.
addLayersControls
    // Are the thickness parameters below relative to the undistorted
    // size of the refined cell outside layer (true) or absolute sizes (false).
    relativeSizes true;
    // Per final patch (so not geometry!) the layer information
    layers
        "fish_*"
            nSurfaceLayers 4;
    // Expansion factor for layer mesh
    expansionRatio 1.75; //1.1
    // Wanted thickness of final added cell layer. If multiple layers
    // is the thickness of the layer furthest away from the wall.
    // See relativeSizes parameter.
    finalLayerThickness 5; //0.9;
    // Minimum thickness of cell layer. If for any reason layer
    // cannot be above minThickness do not add layer.
    minThickness 0.01;
    // If points get not extruded do nGrow layers of connected faces that are
    // also not grown. This helps convergence of the layer addition process
    // close to features.
    nGrow 0;
    // Advanced settings
    // When not to extrude surface. 0 is flat surface, 90 is when two faces
    // are perpendicular
    featureAngle 30;
    // Maximum number of snapping relaxation iterations. Should stop
    nRelaxIter 5;
    // Number of smoothing iterations of surface normals
    nSmoothSurfaceNormals 1;
    // Number of smoothing iterations of interior mesh movement direction
    nSmoothNormals 3;
    // Smooth layer thickness over surface patches
    nSmoothThickness 4;
    // Stop layer growth on highly warped cells
    maxFaceThicknessRatio 0.5;
    // Reduce layer growth where ratio thickness to medial
    // distance is large
    maxThicknessToMedialRatio 0.3;
    // Angle used to pick up medial axis points
    minMedianAxisAngle 90;
    // Create buffer region for new layer terminations
    nBufferCellsNoExtrude 0;
    // Overall max number of layer addition iterations. The mesher will exit
    // if it reaches this number of iterations; possibly with an illegal
    // mesh.
    nLayerIter 30;
    // Max number of iterations after which relaxed meshQuality controls
    // get used. Up to nRelaxIter it uses the settings in meshQualityControls,
    // after nRelaxIter it uses the values in meshQualityControls::relaxed.
    nRelaxedIter 10;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    //- Maximum non-orthogonality allowed. Set to 180 to disable.
    maxNonOrtho 65;
    //- Max skewness allowed. Set to <0 to disable.
    maxBoundarySkewness 1;//20;
    maxInternalSkewness 1;
    //- Max concaveness allowed. Is angle (in degrees) below which concavity
    //  is allowed. 0 is straight face, <0 would be convex face.
    //  Set to 180 to disable.
    maxConcave 80;
    //- Minimum pyramid volume. Is absolute volume of cell pyramid.
    //  Set to a sensible fraction of the smallest cell volume expected.
    //  Set to very negative number (e.g. -1E30) to disable.
    minVol 1e-13;
    //- Minimum quality of the tet formed by the face-centre
    //  and variable base point minimum decomposition triangles and
    //  the cell centre.  Set to very negative number (e.g. -1E30) to
    //  disable.
    //     <0 = inside out tet,
    //      0 = flat tet
    //      1 = regular tet
    minTetQuality 1e-9;
    //- Minimum face area. Set to <0 to disable.
    minArea -1;
    //- Minimum face twist. Set to <-1 to disable. dot product of face normal
    //- and face centre triangles normal
    minTwist 0.05;
    //- minimum normalised cell determinant
    //- 1 = hex, <= 0 = folded or flattened illegal cell
    minDeterminant 0.001;
    //- minFaceWeight (0 -> 0.5)
    minFaceWeight 0.05;
    //- minVolRatio (0 -> 1)
    minVolRatio 0.01;
    //must be >0 for Fluent compatibility
    minTriangleTwist -1;
    //- if >0 : preserve single cells with all points on the surface if the
    //  resulting volume after snapping (by approximation) is larger than
    //  minVolCollapseRatio times old volume (i.e. not collapsed to flat cell).
    //  If <0 : delete always.
    //minVolCollapseRatio 0.5;
    // Advanced
    //- Number of error distribution iterations
    nSmoothScale 4;
    //- amount to scale back displacement at error points
    errorReduction 0.75;
    // Optional : some meshing phases allow usage of relaxed rules.
    // See e.g. addLayersControls::nRelaxedIter.
    relaxed
        maxNonOrtho 70; //75;
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1E-6;
I have tried to change "minThickness" and "finalLayerThickness"
Please letme know how to solve this issue, if there is a solution.
Kind regards,
Marcelo
CFDavatar is offline   Reply With Quote
Old   September 21, 2022, 12:05
M
AtoHM is on a distinguished road
Try with
addLayers    true;
Furthermore, you might want to change finalLayerThickness to something <1. You are using relativeSizes and this is going to give you bad layers if it creates them at all.
CFDavatar likes this.
AtoHM is offline   Reply With Quote
Old   September 22, 2022, 12:08
Marcelo Ruiz
Dear AtoHM
I have changed to
addLayers    true;
It did not fix the issue, would it be helpfull to change the "relativeSizes false;" ?
The cellSize furthest away from the fish close to the channel wall, is very small 0.7 when the verage cellsize is 7.5. Is this impacting my meshing?
I realized the levels of refinement worked, but not the "nCellsBetweenLevels".
Thank you very much,
regards,
Marcelo
Old   September 23, 2022, 02:18
M
AFAIK, the relativeSizes switch causes the following. With relativeSizes true,
finalLayerThickness is actually a finalLayerThicknessRatio, same applies for firstLayerThickness which becomes a firstLayerThicknessRatio.
That being said - a value of 5 (with relativeSizes = true) means, it tries to add cells of 5 times the thickness of the boundary cell at the wall before layers are applied, so I think it would help, yes.The spacing at the outer walls should not influence layer creation at the fish surface. It looks like you have an aspect ratio around 1 there, which is a good start. Expansion ratio of 1.75 seems a bit high as well, maybe 1.1 ... 1.5 might work better, but in general I think the finalLayerThickness is messing it up.
Yann likes this.
Old   September 26, 2022, 07:12
Marcelo Ruiz
Dear AtoHM
I changed my snappyHexMeshDict to:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
snap            true;
addLayers       true;
geometry
    fish.stl
        name fish;
    // refinement.
    features
            file "fish.eMesh";
            level 4;
    refinementSurfaces
        fish
            level (2 4);
    // three modes
    refinementRegions
        fish
            mode inside;
            levels ((2 4));
    // Mesh selection
snapControls
    //  to surface
    nSmoothPatch 8;
    tolerance 4;
    nSolveIter 5;
    nRelaxIter 5;
    // Feature snapping
        nFeatureSnapIter 5;
addLayersControls
    layers
        "fish_*"
            nSurfaceLayers 4;
    finalLayerThickness 7.5; //0.9;
    minThickness 1e-26;
    nGrow 0;
    featureAngle 30;
    nRelaxIter 5;
    nSmoothNormals 3;
    nSmoothThickness 4;
    // mesh.
    nLayerIter 30;
    nRelaxedIter 10;
// where to undo.
meshQualityControls
    maxNonOrtho 65;
    maxConcave 80;
    minVol 1e-13;
    //  disable.
    //      0 = flat tet
    //      1 = regular tet
    minTetQuality 1e-9;
    minArea -1;
    minTwist 0.05;
    minFaceWeight 0.05;
    minVolRatio 0.01;
    // Advanced
    nSmoothScale 4;
    relaxed
// Advanced
debug 0;
Sadly, I was not able to run the code. I am struggling to find a solution I have attached the log of snappyHexMesh for furgther details.
I also tried to use cfMesh, but only the last cell splits spliting next to the wall so it can cause problems with my velocity gradients.
This is my meshDict:
|  \\    /   O peration     | Version:  v2206                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
	  location   	"system";
    object      meshDict;
surfaceFile "combined.fms"
minCellSize			0.5;
maxCellSize			7.5;
boundaryCellSize	7.5;
//boundaryCellSizeRefinementThickness 1;
localRefinement
	"fish"
		//cellSize 0.1;
		refinementThickness 3.5;
		additionalRefinementLevels 4;
objectRefinements //copied from text in official manual
    box1
		type		box; //shape of zone
		cellSize	3.5; //wake cell size
		centre		(-0.35285 -0.00525 0.7726); // xyz centre of box
		lengthX		425;
		lengthY		120;
		lengthZ		120;
	box2
		lengthX		300;
		lengthY		120;
		lengthZ		120;
boundaryLayers
	/*nLayers 3;
	thicknessRatio	1.7;
	maxFirstLayerThickness 3;*/
	patchBoundaryLayers
		"fish"
			nlayers					  7;
			thicknessRatio			1.75;
			//maxFirstLayerThickness	20;
			allowDiscontinutity 	  1;
		"walls"
			nLayers 7;
			thicknessRatio	1.1;
			maxFirstLayerThickness 0.75;
			allowDiscontinutity 	  0;
I also have attached a screenshot of this last mesh. If anyone could helpme to solve this problem I really appreciate it.
Kind regards,
Marcelo
Old   September 27, 2022, 02:16
M
I have no experience with cfMesh, so can't help there, sorry.
Regarding snappy: my best guess is you remove the stuff set in meshQualityControls, at least everything that is non-default: https://github.com/OpenFOAM/OpenFOAM...ppyHexMeshDict
With too tight a set of controls, snappy might not perform certain actions at all, because it introduces "bad" cells. Just use the default settings and try to improve from there. A log file of your snappy run might be helpful to troubleshoot further.
/edit: have I missed the log initially, or have you added it after my reply? Anyways, it appears the layers are actually added now:
patch faces    layers avg thickness[m]
                     near-wall overall
fish 181953   4      6.12      21.3
.. but after that, something seems to kill the execution before it writes the mesh out ... hmmm ...
Old   December 12, 2022, 07:14
Default Possible solutions
Marcelo Ruiz
Dear All,
Sorry for the late reply. I have figure out a way to build the mesh and might help you.
I have divided the domain which is a hexaedron in 12 zones in my blockMeshDict (see attachment) and then create a master mesh and a slave mesh. The fish is in the centered zone, which I mesh in the slave mesh. The I use de command line as follows:
# Commands to create the fish model
cd masterMeshCase
blockMesh
cd ..
cd slaveMeshCase
blockMesh
topoSet
refineMesh -overwrite
snappyHexMesh -overwrite
mergeMeshes masterMeshCase  slaveMeshCase -overwrite
cd masterMeshCase
stitchMesh -perfect ami0 ami1 -overwrite #important to define "ami" in the stitch faces
gedit constant/polyMesh/boundary # erase ami0 & ami1 change boundaries from 7 --> 5
The stitch faces must have the same points, thats why I used the same blockMeshDict to prepare it.
I hope you all find it useful.
Kind regards,
Marcelo
cell between layers, snappyhexmesh 3d
chtMultiRegionFoam speed up qwertz OpenFOAM Running, Solving & CFD 8 September 18, 2021 07:16
[snappyHexMesh] Boundary layers on complex curves with good tetQuality MikeWorth OpenFOAM Meshing & Mesh Conversion 0 August 4, 2020 08:03
[snappyHexMesh] Layers not growing at all zonda OpenFOAM Meshing & Mesh Conversion 12 June 6, 2020 12:28
cellZone not taking all the cells inside rahulksoni OpenFOAM 0 January 16, 2019 02:16
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
