[snappyHexMesh] Append new object and not mesh everything
Like Tree1Likes
  • 1 Post By kandelabr
Old   August 5, 2022, 09:56
Default Append new object and not mesh everything
kokicar vesolja is on a distinguished road
Hello!
I already did my fair share of googling and now I ran out of word phrases to search.
I have a plane made out of 3 separate parts: fuselage (body with wings), ailerons and elevators in wind tunnel - they do not touch i.e do not have any shared edges or faces. Since mesh is pretty detailed and it needs to be for accurate results, it takes a lot of time to snappyHexMesh.
Is it possible to snappyHexMesh a plane, do the foaming and then snappyHexMesh just the elevators under different angle to already existing mesh of a plane and not the whole plane again with elevators under different angle?
Or in other words: if I had snappyHexMesh-ed a sphere and wanted to add another sphere somewhere in the mesh, would I have to snappyHexMesh the whole thing or can I just "append" the sphere to already existing mesh?
Thank you for your answers.
kokicar vesolja is offline   Reply With Quote
Old   August 6, 2022, 03:05
kandelabr's Avatar
Nejc
kandelabr is on a distinguished road
This would be possible with mesh movement, that is AMI or overset mesh. The first is possible if you're able to put the moving parts in a cylinder without touching the stationary part of the mesh so you can rotate them freely. The other does not have this requirement but is a bit more exotic. Neither of those two methods require any remeshing.
kokicar vesolja likes this.
www.damogranlabs.com
kandelabr is offline   Reply With Quote
Old   August 8, 2022, 03:24
If I understand correctly, I'd move the elevators to a different angle during the simulation?
To do something like: have a plane with elevators at 10°, snappyHexMesh, run the solver and then remesh just the elevators at 20°, and again run the solver, this wouldn't be possible?
Old   August 8, 2022, 07:14
kandelabr's Avatar
Nejc
It's perfectly possible.
Imagine you're simulating a pump, there's a fixed part and a rotating part. Those are separate meshes connected via AMI/NCC.
You can make a simulation where impeller rotates during simulation itself or you can prepare a frozen rotor simulation where impeller is fixed.
Your case would be the latter, fixed domain/fuselage/wings and a separately meshed elevators. You'd connect those two parts into a single mesh, set the angle in advance, then run the simulation. For a different angle, just rotate the elevators - not remesh - and run again.
#newobject, #partialsnappyhexmesh, #plane, #snappyhexmesh, #sphere
