August 2, 2022, 02:10 |
Very Basic Meshing Query
Amal Chummar
Rep Power: 5 |
Hi ,
I have made a blockMeshDict file consisitng of a cube with 10 meter length, breadth and height. I have written a line like this : hex (0 1 2 3 4 5 6 7) (20 20 20) simpleGrading (1 1 1); Is there any way of increasing the cell count. My total cell count now is 20*20*20 = 8000. Is there any way of increasing it to a much larger number like, for example : hex (0 1 2 3 4 5 6 7) (1000 1000 1000) simpleGrading (1 1 1); I tried editing like this but it wont run. blockMeshDict file : /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 10 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) (10 0 0) (10 10 0) (0 10 0) (0 0 10) (10 0 10) (10 10 10) (0 10 10) ); blocks ( hex (0 1 2 3 4 5 6 7) (20 20 20) simpleGrading (1 1 1) ); boundary ( hotwall { type wall; faces ( (0 4 7 3) ); } coldwall { type wall; faces ( (2 6 5 1) ); } bottom { type wall; faces ( (1 5 4 0) ); } top { type wall; faces ( (3 7 6 2) ); } front { type wall; faces ( (6 7 4 5) ); } back { type wall; faces ( (0 3 2 1) ); } ); // ************************************************** *********************** // After running blockMesh and then checkMesh *---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 10 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 10-2c6a80318abb Exec : checkMesh Date : Aug 02 2022 Time : 11:38:08 Host : "amalchummar-GL553VE" PID : 12623 I/O : uncollated Case : /home/amalchummar/OpenFOAM/amalchummar-10/run/Turbcube nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0s Mesh stats points: 9261 faces: 25200 internal faces: 22800 cells: 8000 faces per cell: 6 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 8000 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology hotwall 400 441 ok (non-closed singly connected) coldwall 400 441 ok (non-closed singly connected) bottom 400 441 ok (non-closed singly connected) top 400 441 ok (non-closed singly connected) front 400 441 ok (non-closed singly connected) back 400 441 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 0 0) (10 10 10) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (0 0 0) OK. Max cell openness = 0 OK. Max aspect ratio = 1 OK. Minimum face area = 0.25. Maximum face area = 0.25. Face area magnitudes OK. Min volume = 0.125. Max volume = 0.125. Total volume = 1000. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0 OK. Coupled point location match (average 0) OK. Mesh OK. End Thank you so very much |
August 2, 2022, 08:54 |
Yann
Rep Power: 27 |
Hi Amal,
Yes you can increase the cell number in blockMeshDict but blockMesh generates mesh on a single core. Running this setup: hex (0 1 2 3 4 5 6 7) (1000 1000 1000) simpleGrading (1 1 1); means you are creating a 1 billion cells mesh on a single core:
As a workaround, you could create a coarse mesh with blockMesh and then use utilities such as refineMesh or refineHexMesh to refine your mesh in parallel. Another way around would be to use volume refinement in snappyHexMesh. Regards, Yann |
August 2, 2022, 19:15 |
Salome as Mesher
Amal Chummar
Rep Power: 5 |
Thank you Yann,
I came across a tool called Salome to deal with the meshing. Is this easier than snappyHexMesh. Will using Salome be equally efficient as snappyHexMesh for meshing and then implement it somehow into the solving part |
August 4, 2022, 03:37 |
Yann
Rep Power: 27 |
Hi Amal,
Both have pros and cons. You can create your volume mesh in Salome and convert it to use in OpenFOAM but since I never used Salome myself I'm probably not the best person to advise you about it. I would say it also depends on the geometry you need to mesh and the expectations you have regarding the mesh, for instance for boundary layer meshing (which is a bit annoying to deal with in snappyHexMesh) Yann |
blockmesh dict, cell count |
Map of this Meshing (sub-)Forum | wyldckat | OpenFOAM Meshing & Mesh Conversion | 0 | April 27, 2019 09:33 |
Meshing Query | AVINASH CHANDRA | Mesh Generation & Pre-Processing | 0 | October 29, 2013 06:00 |
Basic steps meshing an airfoil [ICEM] | peterputer111 | ANSYS Meshing & Geometry | 4 | April 19, 2010 12:08 |
Question on Basic Meshing Rule | Huygen | Main CFD Forum | 0 | January 15, 2009 12:20 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
