[blockMesh] Merging of multiple patch pairs
Like Tree1Likes
  • 1 Post By Zena27
Old   June 30, 2022, 05:35
Default Merging of multiple patch pairs
Lennart
levoCFD is on a distinguished road
I am trying to build a mesh consisting of 4 blocks. For simplicity we can assume that they are cubic and of uniform size (see attached sketch).
Block 0 and 1 share an interface with the same number of cells on each side. However, block 2 and 3 have different cell numbers, so they need to be merged with the other blocks. Therefore, I have included double vertices for block 2 and 3.
Now I am using mergePatchPairs to connect the patches with the double vertices. I am able to connect block 0 & 2 and block 1 & 3, but when I also want to connect block 2 & 3, I get the following error message from blockMesh:
--> FOAM FATAL ERROR:
Face 14502 reduced to less than 3 points.  Topological/cutting error A.
Old face: 2(6350 6366) new face: 2(6350 6366)
Does anyone know where this error is coming from and how to work around it?
This is my blockMeshDict:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  8
     \\/     M anipulation  |
FoamFile
    version         2.0;
    format          ascii;
    note            "x";
    class           dictionary;
    object          blockMeshDict;
convertToMeters 1;
vertices
    // front
    (0 1 0)            // 0
    (1 1 0)            // 1
    (1 0 0)            // 2
    (0 0 0)             // 3
    (1 -1 0)            // 4
    (0 -1 0)            // 5
    (1 1 0)            // 6
    (2 1 0)            // 7
    (2 0 0)            // 8
    (1 0 0)             // 9
    (1 0 0)            // 10
    (2 0 0)            // 11
    (2 -1 0)            // 12
    (1 -1 0)             // 13
    // back
    (0 1 -1)            // 14
    (1 1 -1)            // 15
    (1 0 -1)            // 16
    (0 0 -1)             // 17
    (1 -1 -1)            // 18
    (0 -1 -1)            // 19
    (1 1 -1)            // 20
    (2 1 -1)            // 21
    (2 0 -1)            // 22
    (1 0 -1)             // 23
    (1 0 -1)            // 24
    (2 0 -1)            // 25
    (2 -1 -1)            // 26
    (1 -1 -1)             // 27
blocks
    // block 0
    hex (0 1 2 3 14 15 16 17)
    (10 10 10)
    edgeGrading
         1 1 1 1
         1 1 1 1
         1 1 1 1
    // block 1
    hex (3 2 4 5 17 16 18 19)
    (10 10 10)
    edgeGrading
         1 1 1 1
         1 1 1 1
         1 1 1 1
    // block 2
    hex (6 7 8 9 20 21 22 23)
    (15 15 15)
    edgeGrading
         1 1 1 1
         1 1 1 1
         1 1 1 1
    // block 3
    hex (10 11 12 13 24 25 26 27)
    (20 20 20)
    edgeGrading
         1 1 1 1
         1 1 1 1
         1 1 1 1
defaultPatch
    name walls;
    type wall;
boundary
    back
        type symmetryPlane;
        faces
            (0 1 2 3)
            (3 2 4 5)
            (6 7 8 9)
            (10 11 12 13)
    front
        type symmetryPlane;
        faces
            (14 15 16 17)
            (17 16 18 19)
            (20 21 22 23)
            (24 25 26 27)
    inlet
        type patch;
        faces
            (0 14 17 3)
            (3 17 19 5)
    outlet
        type patch;
        faces
            (7 8 22 21)
            (11 12 26 25)
    b0left
        type patch;
        faces
            (1 2 16 15)
    b2right
        type patch;
        faces
            (9 6 20 23)
    b1left
        type patch;
        faces
            (2 4 18 16)
    b3right
        type patch;
        faces
            (13 10 24 27)
    b2bottom
        type patch;
        faces
            (8 9 23 22)
    b3top
        type patch;
        faces
            (10 11 25 24)
mergePatchPairs
    ( b0left b2right )
    ( b1left b3right )
    ( b2bottom b3top )
levoCFD is offline   Reply With Quote
Old   May 24, 2023, 19:38
Edoardo
Edoardo1993 is on a distinguished road
I am having the same issue. Did you solve it?
Edoardo1993 is offline   Reply With Quote
Old   May 26, 2023, 06:25
Zeinab
Zena27 is on a distinguished road
you can not use stitchMesh/mergePatchPairs twice on the same edge, because stitchMesh converts the interface cells to polyhedral cells, and stitchMesh can not work on polyhedra cells itself. So, that's what create the problem.
Personally I'll try to use snappy, or I will put a cyclic BC on the patches that cannot be merged.
Also, I will try different order of merging but I think it won't work in this case if all the blocks have the same dimensions.
Edoardo1993 likes this.
Zena27 is offline   Reply With Quote
Old   June 1, 2023, 11:32
Edoardo
I am trying to merge those 3 blocks (See image) but I have an error, though mergePatchPairs does not have to merge the same edge twice:
|  \\    /   O peration     | Version:  v2012                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
Build  : _7bdb509494-20201222 OPENFOAM=2012
Arch   : "LSB;label=32;scalar=64"
Exec   : blockMesh
Date   : Jun 01 2023
Time   : 16:29:49
Host   : DESKTOP-R70FIVH
PID    : 3664
I/O    : uncollated
Case   : /mnt/c/Users/demar/desktop/provamesh
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Creating block mesh from "system/blockMeshDict"
Creating block edges
No non-planar block faces defined
Creating topology blocks
Creating topology patches
Creating block mesh topology
Check topology
        Basic statistics
                Number of internal faces : 0
                Number of boundary faces : 18
                Number of defined boundary faces : 18
                Number of undefined boundary faces : 0
        Checking patch -> block consistency
Creating block offsets
Creating merge list (topological search)...
Creating polyMesh from blockMesh
Creating patches
Creating cells
Creating points with scale 1
    Block 0 cell size :
        i : 0.15 .. 0.15
        j : 0.1 .. 0.1
        k : 0.25 .. 0.25
    Block 1 cell size :
        i : 0.35 .. 0.35
        j : 0.1 .. 0.1
        k : 0.25 .. 0.25
    Block 2 cell size :
        i : 0.15 .. 0.15
        j : 0.3 .. 0.3
        k : 0.25 .. 0.25
Creating merge patch pairs
Adding point and face zones
Creating attachPolyTopoChanger
--> FOAM FATAL ERROR: (openfoam-2012)
Face 73739 reduced to less than 3 points.  Topological/cutting error A.
Old face: 0() new face: 0()
    From void Foam::slidingInterface::coupleInterface(Foam::polyTopoChange&) const
    in file slidingInterface/coupleSlidingInterface.C at line 1450.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::exitOrAbort(int, bool) at ??:?
#2  Foam::slidingInterface::coupleInterface(Foam::polyTopoChange&) const at ??:?
#3  Foam::slidingInterface::setRefinement(Foam::polyTopoChange&) const at ??:?
#4  Foam::polyTopoChanger::topoChangeRequest() const at ??:?
#5  Foam::polyTopoChanger::changeMesh(bool, bool, bool, bool) at ??:?
#6  Foam::attachPolyTopoChanger::attach(bool) at ??:?
#7  ? at ??:?
#8  ? in /lib/x86_64-linux-gnu/libc.so.6
#9  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
#10  ? at ??:?
Aborted (core dumped)
Old   June 6, 2023, 06:16
Zeinab
Okay I'll let you know how does stitchMesh/mergePatchPairs work as far as I know. They work on hexagonal mesh cells, merge them, and convert them to polyhedral cells. So, any non-hexagonal cells can not be merged by the previous utilities.
So think about your case and see what happens when you merge the first two blocks, you will see that you have created a polyhedra cell that needs to be merged with the face in the third block. You can check it actually using check mesh. Merge two cells, and use checkMesh to see the type of the cells.
You can always merge the blocks automatically by using equal number of cells at the common face between the two blocks, and also by using the same vertices of the face at the interface.
Else, you can use cyclic BC.
Old   June 7, 2023, 00:58
shinji nakagawa
snak is on a distinguished road
3 blocks you showed does not need mergePatchPairs.
An attached image and case is the most simple mesh with 3 blocks.
If you share a simplified working case, we could easily solve problems.
snak is offline   Reply With Quote
Old   June 7, 2023, 07:15
Edoardo
Originally Posted by snak View Post
Hi, snak. The case you shared is like mine, but blocks have to have different grading and number of cells. Block1 has to have a fine mesh while block2 and block3 a really coarse mesh.
Hi Zena, thank you for the answer. Unfortunately I can not merge the faces automatically by matching number of cells because I need different number of cells and different grading on each block. I'll take your tip and I am going to understand what BC is, hoping I can create the right mesh with it.
Old   June 7, 2023, 08:18
shinji nakagawa
Hi Edoardo1993,
What you want is something like this?
Old   June 7, 2023, 08:43
Edoardo
Hi Edoardo1993,
Exactly! But when I lunch your blockMesh I get the same error (probably for the reason that Zena27 explained):
Exec   : blockMesh
Date   : Jun 07 2023
Time   : 13:40:20
PID    : 460
I/O    : uncollated
Case   : /mnt/c/Users/demar/desktop/canecllami
nProcs : 1
Create time
--> FOAM Warning :
    From Foam::polyMesh::polyMesh(const Foam::IOobject&, Foam::pointField&&, const cellShapeList&, const faceListList&, const wordList&, const Foam::PtrList<Foam::dictionary>&, const Foam::word&, const Foam::word&, bool)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 919
    Found 6 undefined faces in mesh; adding to default patch frontAndBack
Check topology
        Basic statistics
Creating patches
Creating cells
    Block 0 cell size :
        i : 1 .. 1
        j : 1 .. 1
        k : 1 .. 1
    Block 1 cell size :
        i : 0.5 .. 0.5
        j : 0.5 .. 0.5
        k : 1 .. 1
    Block 2 cell size :
        i : 0.3333333333 .. 0.3333333333
        j : 0.3333333333 .. 0.3333333333
        k : 1 .. 1
Face 43 reduced to less than 3 points.  Topological/cutting error A.
Old face: 2(15 12) new face: 2(15 12)
FOAM aborting
#7  ? at ??:?
#10  ? at ??:?
Old   June 7, 2023, 08:53
shinji nakagawa
Hi
Oops, you got the error with OpenFOAM v2012...
I am using OpenFOAM v2212. The same Warning appears but no errors there.
Log looks like this
Merging 3 patch pairs
    Merging with attachPolyTopoChanger
Removed 6 empty merged patches:
    (b0xMax b0yMax b1xMin b1yMax b2xMax b2yMin)
Removed 6 empty merged face zones:
    (b0xMaxb1xMin0Side0Zone b0xMaxb1xMin0Side1Zone b0yMaxb2yMin1Side0Zone b0yMaxb2yMin1Side1Zone b1yMaxb2xMax2Side0Zone b1yMaxb2xMax2Side1Zone)
I confirmed the same error with OpenFOAM v2106.
--addition
possible related commit
https://develop.openfoam.com/Develop...e3d5f68046b95a
Old   June 7, 2023, 09:02
Edoardo
Hi
Log looks like this
Though the warning, is the mesh generated totally usable? Could you please attach the polyMesh directory? I want to try if it works properly and therefore I will maybe switch to v2212.
Thank you
Old   June 7, 2023, 09:07
shinji nakagawa
This is the case with polyMesh directory. There is no 0 directory. Could you please create initial and boundary conditions.
Old   June 7, 2023, 09:33
Edoardo
Thank you.
What if I want different grading in the z direction too? Need to merge further interfaces?
Old   June 8, 2023, 07:32
shinji nakagawa
Hi Edoardo1993,
When you just grading the mesh, there is no need to merge interfaces. If you add blocks, you have to merge additional interfaces.
Attached is a test case including results. It is derived from the standard cavity case.
The case is just a demonstration of blockMesh.It is preferable to avoid a sudden change in mesh.
File Type: png VirtualBox_Q4OS4Basic-ofv-dev-01_08_06_2023_19_14_36.png (155.8 KB, 26 views)
blockmesh, mergepatchpairs
steadyUniversalMRFFoam Tutorial fails in MixingPlane HenrikJohansson OpenFOAM Bugs 0 February 14, 2019 05:48
mapField error rvl565 OpenFOAM Pre-Processing 1 September 6, 2018 17:13
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 08:30
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 03:01
chtMultiRegionFoam Tutorial m.nichols19 OpenFOAM 12 September 9, 2010 12:56
