[mesh manipulation] refineMesh in parallel - cut on coupled patch
Like Tree1Likes
  • 1 Post By huazhongdk@gmail.com
Old   June 24, 2022, 05:24
Default refineMesh in parallel - cut on coupled patch
Marius
Muerio is on a distinguished road
I'm currently trying to run refineMesh in parallel after completing the castellated mesh step in snappyHexMesh.
My goal is to refine the mesh in the x direction only.
My refineMeshDict_xRefine looks like this:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  8
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      refineMeshDict;
set xRefine;
globalCoeffs
    tan1 (1 0 0);
    tan2 (0 1 0);
    tan1
useHexTopology  true;
geometricCut    false;
writeMesh       false;
When running
runParallel refineMesh -overwrite -noFunctionObjects -dict system/refineMeshDict_xRefine
it results in errors like this one for every processor:
[1]
[1]
[1] --> FOAM FATAL ERROR:
[1] Cut (8143888 2468835) on face (0.055919118 0.18161516 0.0017083333) of coupled patch procBoundary1to0 is not consistent with coupled cut (1860044 8143888)
[1]
[1]     From function void Foam::cellCuts::syncProc()
[1]     in file meshCut/cellCuts/cellCuts.C at line 256.
[1]
FOAM parallel run exiting
Changing the switches for useHexTopology and geometricCut results in the same errors.
Does anyone know how to prevent this error?
Muerio is offline   Reply With Quote
Old   October 21, 2024, 10:34
huazhongdk@gmail.com is on a distinguished road
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
set xRefine;
globalCoeffs
    tan1 (1 0 0);
    tan2 (0 1 0);
    tan1
geometricCut    false;
writeMesh       false;
When running
[1]
[1]
[1]
[1]
hi Muerio,
you can try to run snappyHexMesh with only setting castellatedMesh as true, then use refineMesh to refine the mesh. After that, remove the cellLevel and pointLevel files in constant/polyMesh, and run snappyHexMesh again with snap as true. I solve the similar problem by doing these steps, hope it will help you.
1. blockMesh -dict ./system/blockMeshDict
2. snappyHexMesh -dict ./system/snappyHexMeshDict -overwrite
3. topoSet -dict ./system/topoSetDict
4. refineMesh -dict ./system/refineMeshDict -overwrite
5. cd ./constant/polyMesh && rm cellLevel && rm pointLevel
6. snappyHexMesh -dict ./system/snappyHexMeshDict.snappy -overwrite
Muerio likes this.
huazhongdk@gmail.com is offline   Reply With Quote
refinemesh -parallel
[Commercial meshers] Fluent msh and cyclic boundary cfdengineering OpenFOAM Meshing & Mesh Conversion 49 November 29, 2024 22:16
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 12:58
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing Regis_ OpenFOAM Meshing & Mesh Conversion 2 June 4, 2015 14:44
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
