[snappyHexMesh] Adding layers refinement moves regions - snappyHexMesh
Like Tree1Likes
  • 1 Post By AtoHM
Old   June 14, 2022, 06:12
Default Adding layers refinement moves regions - snappyHexMesh
genus is on a distinguished road
Hi to all!
I'm working with snappyHexMesh (OpenFOAM v1812) and I would like to generate a mesh for a ALM simulation of a wind turbine.
I have subdivided my domain, which is a box, in regions, which are cylinders. I would like to add layers on the bottom of my domanin which should be the same for all the bottom region of the box. The problem is that each time I generate the grid with the addlayerscontrols it moves in vertical direction the regions (which have to be centered in the origin) by lenght equal to the total height of the added layers.
Any ideas?
genus is offline   Reply With Quote
Old   June 15, 2022, 11:07
M
AtoHM is on a distinguished road
This is how most (I dont know of any exception, but maybe there is?) meshers insert boundary layers. They generate an initial mesh, push inside the outer cells to insert the BL.
If you want to avoid that, in your simple case you could try to define the layers already in blockMesh.
genus likes this.
AtoHM is offline   Reply With Quote
Old   June 15, 2022, 11:14
Already done that but thanks anyway. Does not looks as the most elegant solution but seems working.
1812, addlayercontrols, mesh, openfoam, snappyhexmesh
[snappyHexMesh] SnappyHexMesh with local refinement of ONE STLfile wolle1982 OpenFOAM Meshing & Mesh Conversion 32 November 21, 2024 06:32
[snappyHexMesh] snappyHexMesh can't create refimenet region clktp OpenFOAM Meshing & Mesh Conversion 3 February 27, 2022 10:26
[snappyHexMesh] snappyHexMesh fails adding layers biscarri OpenFOAM Meshing & Mesh Conversion 13 March 21, 2020 13:40
SimpleFoam & Theater jipai OpenFOAM Running, Solving & CFD 3 June 18, 2019 11:11
[snappyHexMesh] snappyHexMesh ignores refinement regions kilroy OpenFOAM Meshing & Mesh Conversion 2 June 10, 2013 15:02
