[snappyHexMesh] Unable to capture very small nozzle while meshing
Like Tree2Likes
  • 1 Post By surajkvs
  • 1 Post By Yann
Old   May 5, 2022, 03:53
Default Unable to capture very small nozzle while meshing
SURAJ
surajkvs is on a distinguished road
Dear all,
I have a geometry of order 10m and have 12 nozzles (small patches on walls)of diameter 6mm.
When I am performing snappyHexMesh, then nFaces for nozzles is coming "zero". Although I have given very high surfaceRefinement level for nozzles. I am unable to capture it.
Can anybody guide me what should I do to capture nozzles while meshing.
neelcfd likes this.
surajkvs is offline   Reply With Quote
Old   May 5, 2022, 04:33
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hi Suraj,
In order to help you, we would need more information about your case : screenshots of your geometry and mesh, blockMesh cell size, snappyHexMeshDict...
Regards,
Yann
surajkvs likes this.
Yann is online now   Reply With Quote
Old   May 5, 2022, 08:09
SURAJ
Hello Yann,
Thanks for the reply.
I have attached 3 pics. 1st is full geometry. The geometry contains two legs(downLeg and upLeg). The upLeg is shown in pic2. There are 12 small nozzles on upLeg surface. A few are visible from front view as shown in pic3.
| \\ / O peration | Version: v2112 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
backgroundMesh
xMin -2;
xMax 2;
yMin -5;
yMax 1.8;
zMin -2;
zMax 2;
xCells 100;
yCells 170;
zCells 100;
scale 1;
vertices
($:backgroundMesh.xMin $:backgroundMesh.yMin $:backgroundMesh.zMin)
($:backgroundMesh.xMax $:backgroundMesh.yMin $:backgroundMesh.zMin)
($:backgroundMesh.xMax $:backgroundMesh.yMax $:backgroundMesh.zMin)
($:backgroundMesh.xMin $:backgroundMesh.yMax $:backgroundMesh.zMin)
($:backgroundMesh.xMin $:backgroundMesh.yMin $:backgroundMesh.zMax)
($:backgroundMesh.xMax $:backgroundMesh.yMin $:backgroundMesh.zMax)
($:backgroundMesh.xMax $:backgroundMesh.yMax $:backgroundMesh.zMax)
($:backgroundMesh.xMin $:backgroundMesh.yMax $:backgroundMesh.zMax)
blocks
hex (0 1 2 3 4 5 6 7)
$:backgroundMesh.xCells
$:backgroundMesh.yCells
$:backgroundMesh.zCells
simpleGrading (1 1 1)
edges
boundary
mergePatchPairs
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap true;
addLayers true;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
mesh1.stl
type triSurfaceMesh;
name RH;
regions
laddleWalls {name laddleWalls;}
laddleFS {name laddleFS;}
vaccumBC {name vaccumBC;}
vaccumChambWalls {name vaccumChambWalls;}
//inletDown {name inletDown;}
nozzles {name nozzles;}
upLeg {name upLeg;}
downLeg {name downLeg;}
//snorkelOuterWalls {name snorkelOuterWalls;}
refinementCyl
type searchableCylinder;
point1 (-0.7 0 0);
point2 (-0.7 -1.750 0);
radius 0.3;
//type upLegCyl;
//min (-350 0 -350);
//max ( 8.0 0.7 2.5);
// Settings for the castellatedMesh generation.
castellatedMeshControls
// Refinement parameters
// If local number of cells is >= maxLocalCells on any processor
// switches from from refinement followed by balancing
// (current method) to (weighted) balancing before refinement.
maxLocalCells 10000000;
// Overall cell limit (approximately). Refinement will stop immediately
// upon reaching this number so a refinement level might not complete.
// Note that this is the number of cells before removing the part which
// is not 'visible' from the keepPoint. The final number of cells might
// actually be a lot less.
maxGlobalCells 20000000;
// The surface refinement loop might spend lots of iterations refining just a
// few cells. This setting will cause refinement to stop if <= minimumRefine
// are selected for refinement. Note: it will at least do one iteration
// (unless the number of cells to refine is 0)
minRefinementCells 10;
// Allow a certain level of imbalance during refining
// (since balancing is quite expensive)
// Expressed as fraction of perfect balance (= overall number of cells /
// nProcs). 0=balance always.
maxLoadUnbalance 0.10;
// Number of buffer layers between different levels.
// 1 means normal 2:1 refinement restriction, larger means slower
// refinement.
nCellsBetweenLevels 3;
// Explicit feature edge refinement
// Specifies a level for any cell intersected by its edges.
// This is a featureEdgeMesh, read from constant/triSurface for now.
features
file "mesh1.eMesh";
level 2;
// Surface based refinement
// Specifies two levels for every surface. The first is the minimum level,
// every cell intersecting a surface gets refined up to the minimum level.
// The second level is the maximum level. Cells that 'see' multiple
// intersections where the intersections make an
// angle > resolveFeatureAngle get refined up to the maximum level.
refinementSurfaces
RH
level (0 0);
regions
nozzles
level (8 8);
patchInfo
type patch;
/* inletDown
level (5 5);
patchInfo
type patch;
inletUp
level (5 5);
patchInfo
type patch;
vaccumBC
level (2 2);
patchInfo
type patch;
laddleFS
level (2 2);
patchInfo
type patch;
/*snorkelOuterWalls
level (1 1);
patchInfo
type wall;
vaccumChambWalls
level (2 2);
patchInfo
type wall;
laddleWalls
level (2 2);
patchInfo
type wall;
downLeg
level (2 2);
patchInfo
type wall;
upLeg
level (3 3);
patchInfo
type wall;
// Resolve sharp angles
resolveFeatureAngle 90;
// Region-wise refinement
// Specifies refinement level for cells in relation to a surface. One of
// three modes
// - distance. 'levels' specifies per distance to the surface the
// wanted refinement level. The distances need to be specified in
// descending order.
// - inside. 'levels' is only one entry and only the level is used. All
// cells inside the surface get refined up to the level. The surface
// needs to be closed for this to be possible.
// - outside. Same but cells outside.
refinementRegions
refinementCyl
mode inside;
levels ((1E15 3));
// Mesh selection
// After refinement patches get added for all refinementSurfaces and
// all cells intersecting the surfaces get put into these patches. The
// section reachable from the locationInMesh is kept.
// NOTE: This point should never be on a face, always inside a cell, even
// after refinement.
locationInMesh (0 0.3 0);
// Whether any faceZones (as specified in the refinementSurfaces)
// are only on the boundary of corresponding cellZones or also allow
// free-standing zone faces. Not used if there are no faceZones.
allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
//- Number of patch smoothing iterations before finding correspondence
// to surface
nSmoothPatch 3;
//- Relative distance for points to be attracted by surface feature point
// or edge. True distance is this factor times local
// maximum edge length.
tolerance 0.0002;
//- Number of mesh displacement relaxation iterations.
nSolveIter 30;
//- Maximum number of snapping relaxation iterations. Should stop
// before upon reaching a correct mesh.
nRelaxIter 5;
// Feature snapping
//- Number of feature edge snapping iterations.
// Leave out altogether to disable.
nFeatureSnapIter 20;
//- Detect (geometric only) features by sampling the surface
// (default=false).
implicitFeatureSnap false;
//- Use castellatedMeshControls::features (default = true)
explicitFeatureSnap true;
//- Detect points on multiple surfaces (only for explicitFeatureSnap)
multiRegionFeatureSnap false;
// Settings for the layer addition.
addLayersControls
// Are the thickness parameters below relative to the undistorted
// size of the refined cell outside layer (true) or absolute sizes (false).
relativeSizes true;
// Per final patch (so not geometry!) the layer information
layers
wall
nSurfaceLayers 3;
moldWalls
nSurfaceLayers 3;
// Expansion factor for layer mesh
expansionRatio 1.3;
// Wanted thickness of final added cell layer. If multiple layers
// is the thickness of the layer furthest away from the wall.
// Relative to undistorted size of cell outside layer.
// See relativeSizes parameter.
finalLayerThickness 0.03;
// Minimum thickness of cell layer. If for any reason layer
// cannot be above minThickness do not add layer.
minThickness 0.006;
// If points get not extruded do nGrow layers of connected faces that are
// also not grown. This helps convergence of the layer addition process
// close to features.
// Note: changed(corrected) w.r.t 1.7.x! (didn't do anything in 1.7.x)
nGrow 0;
// Advanced settings
// When not to extrude surface. 0 is flat surface, 90 is when two faces
// are perpendicular
featureAngle 60;
// At non-patched sides allow mesh to slip if extrusion direction makes
// angle larger than slipFeatureAngle.
slipFeatureAngle 30;
// Maximum number of snapping relaxation iterations. Should stop
nRelaxIter 3;
// Number of smoothing iterations of surface normals
nSmoothSurfaceNormals 1;
// Number of smoothing iterations of interior mesh movement direction
nSmoothNormals 3;
// Smooth layer thickness over surface patches
nSmoothThickness 10;
// Stop layer growth on highly warped cells
maxFaceThicknessRatio 0.5;
// Reduce layer growth where ratio thickness to medial
// distance is large
maxThicknessToMedialRatio 0.3;
// Angle used to pick up medial axis points
// Note: changed(corrected) w.r.t 1.7.x! 90 degrees corresponds to 130
// in 1.7.x.
minMedialAxisAngle 90;
// Create buffer region for new layer terminations
nBufferCellsNoExtrude 0;
// Overall max number of layer addition iterations. The mesher will exit
// if it reaches this number of iterations; possibly with an illegal
// mesh.
nLayerIter 50;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
#include "meshQualityDict"
// Advanced
//- Number of error distribution iterations
nSmoothScale 4;
//- Amount to scale back displacement at error points
errorReduction 0.75;
// Advanced
// Write flags
writeFlags
scalarLevels
layerSets
layerFields // write volScalarField for layer coverage
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1e-6;
Regards,
Suraj
Old   May 6, 2022, 03:35
Al Csc
al.csc is on a distinguished road
Run surfaceFeatureExtract and use that output for snappy. In alternative I would refine that area and use topoSet, to select the corresponding faces and use them as inlet for the nozzles. I guess with that low detail you don t care if the nozzles have a cylindrical or square section, as soon as the mass flux matches.
al.csc is offline   Reply With Quote
snappyhexmesh 3d
[Commercial meshers] Problems in meshing 2D axisymmetric nozzle wedge with Salome kim4545 OpenFOAM Meshing & Mesh Conversion 1 March 20, 2023 12:05
Nozzle meshing, critical convergence kovage STAR-CCM+ 0 March 28, 2022 05:36
[ICEM] 3D Nozzle meshing saadia ANSYS Meshing & Geometry 0 April 20, 2021 15:50
Meshing a nozzle parvaz747 Mesh Generation & Pre-Processing 3 June 17, 2013 12:40
Small Supersonic Nozzle Paal Main CFD Forum 3 November 25, 2003 05:59
