February 11, 2022, 02:18 |
snappy extrude snappy
Rep Power: 8 |
Snappy has 3 phases: refinement, snapping, layering. Can we use extrudemesh right after the refinement phase, and then proceed to snap and add layers?.
I think it would be great for 2D meshes. Mine at least take very long to snap, so if the snapping subdictionary can snap extruded stuff, it would run faster |
February 11, 2022, 20:48 |
Claudio Boezio
Rep Power: 7 |
In theory it should be possible. You would run snappyHexMesh the first time with only castellation true, then extrude the grid with extrudeMesh and finally run sHM again with castellation set to false and snap and addlayers to true. If you don't use the -overwrite option, you'll have to pay attention to move/copy the latest grid edit from any time folder to constant/, so that any subsequent utilities work on the correct polymesh.
In extrudeMeshDict I believe you'd have to specify constructFrom mesh in order to retain the cell refinement in direction of the extrusion. Otherwise only the patch will be extruded and on each cell layer there would be only 1 cell, thus loosing cell refinement in that direction previously done by sHM. |
snappyhesmesh |
[GMSH] extrude rotation from arbitrary OpenCASCADE center | crubio.abujas | Mesh Generation & Pre-Processing | 0 | February 2, 2022 13:44 |
Can't use the Extrude Translation | lamagavoragine | Pointwise & Gridgen | 3 | March 11, 2019 23:05 |
Error while running pisoFoam with snappy but ran smoothly without snappy in empty dm | faiazk | OpenFOAM Running, Solving & CFD | 0 | October 24, 2018 13:51 |
[Gmsh] 3D mesh using transfinite surface + extrude with layer? | CFD-Lover | OpenFOAM Meshing & Mesh Conversion | 0 | July 5, 2016 02:26 |
[Gmsh] Cannot get the right mesh from gmsh | JinBiao | OpenFOAM Meshing & Mesh Conversion | 2 | August 31, 2010 04:51 |
