January 13, 2022, 08:23 |
Separate FSI meshes
Merlin Williams
Rep Power: 4 |
I am trying to run an FSI simulation on solids4foam using a geometry and a mesh which I have already generated in Ansys meshing which is made up of one part, linked below. I have managed to use fluent3DMeshToFoam to transfer the whole mesh to openfoam and have checked the mesh and it checks out alright. However, for an FSI simulation, I am not sure if I will need to split the mesh into two parts so that I have the solid domain and the fluid domain and then import both of those to openfoam? Please can someone tell me if I need to split my mesh up into both fluid and solid domains then import it or if it is easier to just import the whole thing then specify the domains? Thank you Merlin Edit: Or is it possible to use the mesh which has both the solid and fluid domains, but when importing it to openfoam for the fluid domain to only specify the patches that relate to the fluid domain and so it just ignores the solid domain? Last edited by MFWilliams; January 13, 2022 at 09:46. |
January 14, 2022, 03:03 |
Hojatollah Gholami
Rep Power: 7 |
In ANSYS, you first can design your geometry and use two region as fluid and solid, then meshing togethers. But to import to openfoam, you need suppress each region and define boundary interface and save each mesh separately. for using solids4Foam solver, you need to import each mesh as fluid or solid in relative folders. |
January 14, 2022, 03:36 |
Merlin Williams
Rep Power: 4 |
Ok great thank you. So I can leave the mesh that I currently have but just supress the solid domain when I import fluid mesh to openfoam and supress fluid domain when I import solid domain?
January 14, 2022, 08:14 |
Hojatollah Gholami
Rep Power: 7 |
Yes,
Also, don't forget to define interface boundary for each regions. |
January 14, 2022, 08:36 |
Merlin Williams
Rep Power: 4 |
Amazing thank you very much.
Would you also mind hleping me create a time varying veloctity boundary condition? |
January 16, 2022, 03:48 |
Hojatollah Gholami
Rep Power: 7 |
I am not yet use time varying velocity. But you can use db().time().value() as time and modify available inlet velocity BC with your relation.
January 17, 2022, 02:18 |
Merlin Williams
Rep Power: 4 |
Ok thank you
domains, fsi mesh, import mesh |
2-way FSI of artery, Divergence issues in Ansys 19.1 | Frisii | ANSYS | 0 | October 2, 2020 05:36 |
Hex and Tet meshes - simplefoam comparison | danvica | OpenFOAM Running, Solving & CFD | 10 | January 4, 2013 01:18 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 04:08 |
Could you suggest some Useful FSI textbook? | BI CHANG | CFX | 0 | January 14, 2006 14:31 |
Large 3D tetrahedral meshes | Aldo Bonfiglioli | Main CFD Forum | 4 | August 27, 1999 03:33 |
