November 1, 2021, 20:55 |
cannot find MRF cellZone
Muhammad Ahyar
Rep Power: 6 |
hello i'm trying to build a simulation with MRF on it. but when i tried to run the solution command, i've got this error
on the other hand, i've declared the cellZone on my snappyHexMeshDict Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // castellatedMesh true; snap true; addLayers false; geometry { inlet.stl { type triSurfaceMesh; name inlet; } tank.stl { type triSurfaceMesh; name tank; } impeller { type triSurfaceMesh; file "impeller.stl"; } MRF { type searchableCylinder; point1 (0.0 0.0 -0.1); point2 (0.0 0.0 0.9); radius 0.4; } } castellatedMeshControls { maxLocalCells 100000; maxGlobalCells 2000000; minRefinementCells 0; nCellsBetweenLevels 2; maxLoadUnbalance 0.10; features ( { file "inlet.eMesh"; level 0; } { file "tank.eMesh"; level 0; } { file "impeller.eMesh"; level 0; } ); resolveFeatureAngle 30; refinementSurfaces { inlet { level (0 0); } tank { level (0 0); } impeller { level (0 0); } MRF { level (1 1); cellZones cellMRFzone; faceZones faceMRFzone; cellZoneInside inside; } } refinementRegions { MRF { mode inside; levels ((1E15 1)); } } locationInMesh (0.0 0.0 0.3); // Inside point allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { nSmoothPatch 3; tolerance 1.0; nSolveIter 300; nRelaxIter 10; nFeatureSnapIter 10; implicitFeatureSnap true; explicitFeatureSnap false; multiRegionFeatureSnap true; } // Settings for the layer addition. addLayersControls { relativeSizes true; layers { } expansionRatio 1.0; finalLayerThickness 0.3; minThickness 0.25; nGrow 0; featureAngle 30; nRelaxIter 5; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 10; maxFaceThicknessRatio 0.5; maxThicknessToMedialRatio 0.3; minMedianAxisAngle 90; nBufferCellsNoExtrude 0; nLayerIter 50; nRelaxedIter 20; } meshQualityControls { #include "meshQualityDict" relaxed { maxNonOrtho 75; } } writeFlags ( ); mergeTolerance 1E-6; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object MRFProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // MRFImpeller { cellZone cellMRFzone; active yes; // Fixed patches (by default they 'move' with the MRF zone) nonRotatingPatches (); origin (0.0 0.0 0.0); axis (0 1 0); omega constant 12.56; // ~120 RPM } // ************************************************************************* // thanks in advance |
November 2, 2021, 01:58 |
Niels Nielsen
Rep Power: 27 |
Hi
MRF { level (1 1); cellZones cellMRFzone; faceZones faceMRFzone; cellZoneInside inside; } Code:
MRF { level (1 1); cellZone cellMRFzone; faceZone faceMRFzone; cellZoneInside inside; }
Linnemann PS. I do not do personal support, so please post in the forums. |
November 2, 2021, 02:28 |
#3 | |
Muhammad Ahyar
Rep Power: 6 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[swak4Foam] swak4Foam compilation can't find -lOpenFOAM | BobR | OpenFOAM Community Contributions | 4 | August 10, 2015 14:49 |
[foam-extend.org] Installing foam-extend 3.1 on Ubuntu 14.04 | stephie | OpenFOAM Installation | 16 | April 23, 2015 16:18 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
Problem Building OF on Centos cluster (no admin rights) | CKH | OpenFOAM Installation | 5 | November 13, 2011 06:32 |
