[blockMesh] I think my solution is distorted by my mesh
Like Tree1Likes
  • 1 Post By allanZHONG
Old   October 14, 2021, 23:26
Question I think my solution is distorted by my mesh
Allan ZHONG
allanZHONG is on a distinguished road
I am simulating external flows around a simple building array using simpleFoam, and I am using a structured hexahedral mesh generated by blockMesh. I have to make the wall-adjacent mesh denser, and I am using the cell-to-cell expansion ratio of 1.1. When I am simulating using the coarser mesh (y+ > 30), the solution looks fine, and it does not show weird patterns. But, after I switched to the finer mesh (y+ = 7~9, same expansion ratio), I got weird patterns from my solution, and I think this has something to do with the mesh being too stretched, bu I cannot be sure as I've seen others getting perfect OK solutions with similar stretched meshes. Anyone who have seen this problem before? Maybe your words will help me get out of this difficult position.
The slice view of the x-y plane for my finer mesh is attached as below,
The same view for my solution is attached as below.
allanZHONG is offline   Reply With Quote
Old   October 14, 2021, 23:28
Default Sorry, I failed to insert the images
Allan ZHONG
Seems like the way i inserted the images is wrong, so I am simply uploading them as attachments now
Old   October 19, 2021, 10:15
Default The weird solution is just due to unconverged calculation
Allan ZHONG
Having let the calculation to proceed for a while, I found that these weird patterns on the solution disappeared.
guin likes this.
blockmesh, openfoam, structured hex mesh
Converging the solution aja1345 FLUENT 13 June 15, 2022 00:46
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[snappyHexMesh] non uniform mesh near the stl object vava10 OpenFOAM Meshing & Mesh Conversion 0 January 31, 2021 15:41
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
