[blockMesh] Parametrizing BlockMesh (preferably without m4)
Like Tree1Likes
  • 1 Post By GerhardHolzinger
Old   October 1, 2021, 05:19
Default Parametrizing BlockMesh (preferably without m4)
Dozer_94 is on a distinguished road
Hi everyone,
I have a tricky, maybe even impossible question.
The goal is to mesh a quarter (axisymmetric) cylinder with fixed length and radius L and R.
The cylinder wall is divided into N patches of equal length L/N (see the attached figure for N=5).
Right now I create vertices and blocks manually. You can imagine that if N becomes large, I can spend the entire day making a single mesh. Therefore, I'd like to parametrize N and let the script do it for me. The problem is that loops are not a thing in the BlockMeshDict (at least not to my knowing).
I know about m4 but the documentation is marginal. What is the best approach here?
Thanks in advance!
Dozer_94 is offline   Reply With Quote
Old   October 1, 2021, 05:28
Domenico Lahaye
dlahaye is on a distinguished road
Does this help: https://github.com/damogranlabs/classyBlocks
https://damogranlabs.com/2020/02/cla...for-blockmesh/
dlahaye is offline   Reply With Quote
Old   October 1, 2021, 08:55
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
If you only want to use variable parameters, and don't need the entire magic that Python-scripting has to offer, you can also use OpenFOAM's on-board tools, i.e., using variables in dictionaries, the code-stream magic.
A parametric blockMeshDict from the tutorials
dlahaye likes this.
GerhardHolzinger is offline   Reply With Quote
Old   October 4, 2021, 06:53
I downloaded the git and tried to run the "from_points" example, but python throws me a "raise AttributeError(f"Unknown edge type: {self.type}") on line 132 of primitives.py.
I installed and prioritized python 3.8 so not really sure where the error is originating from.
I am considering this as well:
radius 			0.0005;
Len 			0.001;
nSegments 		5.0;
radHalfAngle    #calc "degToRad($halfAngle)";
y               #calc "$radius*sin($radHalfAngle)";
minY            #calc "-1.0*$y";
z               #calc "$radius*cos($radHalfAngle)";
segmentLength	#calc "$Len / $nSegments";
codeStream
	std::array<float, $nSegments> lenarray;
	for (int i=1;i<$nSegments;i++)
		lenarray[i] = $segmentLength*i;
Passing variables like "nSegments" into the codestream works fine, but how exactly can you return variables or other data like "lenarray" back to the regular code?
blockmeshdict
[blockMesh] OpenFOAM blockMesh bus error BRH OpenFOAM Meshing & Mesh Conversion 0 April 12, 2021 12:02
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 20:15
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 09:37
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 12:59
