June 25, 2021, 10:06 |
Salome error, can't load library!
Rep Power: 5 |
I am trying to do the meshing with Salome but I get this error:
Salome ecxeption: Can't load meshersplugin library NETGENEngine.dll any ideas? |
February 17, 2023, 15:56 |
Salome is a chunk
Leonardo Lemos
Use Gmsh or another way to create your mesh. Salome's netgenengine doesn't work since 2022
June 13, 2023, 06:21 |
#3 | |
Franco
Rep Power: 7 |
where did you got this information? any solutions? thanks in advance EDIT: found the error, I installed the newer version of visual studio https://learn.microsoft.com/en-us/cp...-2019-and-2022 it solved the issue |
October 30, 2024, 06:46 |
PM
Just to confirm I had the same issue and was also fixed by upgrading Microsoft visual studio C++ to the latest version. Netgen is still supported.
undefined symbol - could not load library | Kosdalak | OpenFOAM Programming & Development | 19 | November 21, 2024 03:25 |
UDF library trying to load is not compiled for parallel use on the current platform | Arjunsajith | Fluent UDF and Scheme Programming | 15 | August 19, 2024 15:02 |
Error: The UDF library you are trying to load (libudf) is not compiled for 2d on the | gxu2 | Fluent UDF and Scheme Programming | 13 | August 10, 2018 18:38 |
decomposePar is missing a library | whk1992 | OpenFOAM Pre-Processing | 8 | March 7, 2015 08:53 |
Error: The UDF library you are trying to load is not compiled for 3ddp on the current | Whitemast | Fluent UDF and Scheme Programming | 0 | November 21, 2013 07:45 |
