[blockMesh] --> FOAM FATAL ERROR: face 0 in patch 2 does not have neighbour cell face: 4(0 3 10
Like Tree3Likes
  • 1 Post By otaolafr
  • 1 Post By olesen
  • 1 Post By olesen
Old   June 8, 2021, 07:12
Question --> FOAM FATAL ERROR: face 0 in patch 2 does not have neighbour cell face: 4(0 3 10
Ole
onesecto is on a distinguished road
this is my first Post and one of my first blockMeshDicts. I got this Error
face 0 in patch 2 does not have neighbour cell face: 4(0 3 10 9)
and i think i have Problems with most of the Patches.
blockMeshDict:
convertToMeters 1;
vertices
(0 0 0) //0
(0.15 0 0) //1
(0.15 1 0) //2
(0 1 0) //3
(0 0 0.1) //4
(0.15 0 0.1) //5
(0.15 1 0.1) //6
(0 1 0.1) //7
(0.15 0 0.05) //8 zwischen 1 und 5
(0 0 0.05) //9 zwischen 0 und 4
(0 1 0.05) //10 zwischen 3 und 7
(0.15 1 0.05) //11 zwischen 2 und 6
blocks
hex (0 1 2 3 11 10 9 8) (25 75 10) simpleGrading (1 10.7028 1)
hex (7 6 5 4 8 9 10 11) (25 75 10) simpleGrading (1 0.0934 1)
//hex (0 1 2 3 4 5 6 7) (25 75 10) simpleGrading (1 1 1)
edges
boundary // keyword
bottomWall
type wall;
faces ((4 5 6 7));
topWall
type wall;
faces ((0 1 2 3));
//Obere Häfte
/* top_inlet // patch name
type cyclic;
neighbourPatch top_outlet;
faces
(0 1 8 9)
top_outlet
type cyclic;
neighbourPatch top_inlet;
faces
(2 3 10 11)
top_side_left
type cyclic;
neighbourPatch top_side_right;
faces ((1 8 11 2));
top_side_right
type cyclic;
neighbourPatch top_side_left;
faces ((0 9 10 3));
//untere Hälfte
bot_inlet // patch name
type cyclic;
neighbourPatch bot_outlet;
faces
(5 4 9 8)
bot_outlet // patch name
type cyclic; // patch type for patch 1
neighbourPatch bot_inlet;
faces
(6 7 10 11) //(1 2 6 5)
I would be thankfull for your help.
onesecto is offline   Reply With Quote
Old   June 10, 2021, 13:01
Franco
otaolafr is on a distinguished road
Originally Posted by onesecto View Post
blockMeshDict:
convertToMeters 1;
vertices
(0 0 0) //0
(0.15 0 0) //1
(0.15 1 0) //2
(0 1 0) //3
(0 0 0.1) //4
(0.15 0 0.1) //5
(0.15 1 0.1) //6
(0 1 0.1) //7
blocks
edges
boundary // keyword
bottomWall
type wall;
faces ((4 5 6 7));
topWall
type wall;
faces ((0 1 2 3));
//Obere Häfte
type cyclic;
faces
(0 1 8 9)
top_outlet
type cyclic;
faces
(2 3 10 11)
top_side_left
type cyclic;
faces ((1 8 11 2));
top_side_right
type cyclic;
faces ((0 9 10 3));
//untere Hälfte
type cyclic;
faces
(5 4 9 8)
faces
please when you post a code/dictionary use the [CODE] feature in the forum, it makes way easier to read.
you have a problem in te boundary definition. If i were you, i would try this:
1.comment the boundaries dictionary
boundaries
2. use blockMesh if you do not get any error
3. run paraFoam -block
you can then trouble shoot your block mesh. you have a point brongly defined.
if the blockMesh still does not want to run comment one by one the different blocks.
best regards
using paraFoam
olesen likes this.
otaolafr is offline   Reply With Quote
Old   June 11, 2021, 05:30
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
boundaries
Exactly the way to do it but you also have the option of "blockMesh -write-vtk" to inspect the topology without requiring the special paraview reader plugin.
otaolafr likes this.
olesen is offline   Reply With Quote
Old   June 11, 2021, 05:49
Franco
did not known about this flag of blockMesh... nice thanks for the info.
I think the paraFoam way is a little bit better specially in a case when you trouble shoot, as it shows the number of the point next to the point.... that with the blockmesh flag path does not. but still quite nice!
best regards
Old   June 12, 2021, 15:17
Mark Olesen
best regards
At the right end of the paraview toolbar there is a "hover point" button. Click that and then can inspect the vertex numbers - without reliance on any additional plugins.
The point labels that the blockMesh plugin shows are generally OK, but even after several attempts to get them properly fixed, they still tend to be too persistent (sticky).
If you have a slightly more complex blockMesh, can view the corresponding vtk file with "shink elements" - quite effective during diagnostics since it also makes it easy to find "hidden" vertices.
blockmesh, cyclic
[blockMesh] Foam fatal error: neighbour cell face anu.raghun OpenFOAM Meshing & Mesh Conversion 2 June 26, 2019 12:53
steadyUniversalMRFFoam Tutorial fails in MixingPlane HenrikJohansson OpenFOAM Bugs 0 February 14, 2019 05:48
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 03:21
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
