[snappyHexMesh] Treating non connecting geometries as one region |
April 27, 2021, 08:10 |
Claudia
Rep Power: 5 |
Hello!
As you can see in the attachted foto, i have a tray filled with chocolate bars, that I want to mesh with snappyHexMesh and then use chtMultiRegionFoam. So in the end I want to have three regions: the tray, the chocolate and the air. The problem is, that the chocolate bars are not connected, so I don't know how to get them to be in one region. I tried putting all the chocolate bars into one stl file but I understand know that snappyHexMesh can't deal with that. So should I put all the bars in seperate stl files? How can I combine them into one Region then? Or is there a smarter way to do that? I have been struggeling with this for over a week, I would really appreciate your help! |
April 27, 2021, 08:59 |
Yann
Rep Power: 29 |
Hi Claudia,
What OpenFOAM version are you using and what is your current workflow to mesh this case? Yann |
April 27, 2021, 09:05 |
Claudia
Rep Power: 5 |
Hey,
I am using version 8. I created the geometry in inventor and exported the geometries as one step file to Salome. There I created a partition and exploded the partition again. After that I exported the stl files (tray.stl, chocolate.stl,...) to OF. Then: - blockMesh - surfaceFeatures - snappyHexMesh - splitMeshRegions |
April 27, 2021, 09:36 |
Yann
Rep Power: 29 |
I did not try this in OpenFOAM-8, however I think it's worth trying:
Let us know if it works for you. Yann |
April 27, 2021, 11:39 |
Claudia
Rep Power: 5 |
Thank you Yann!
Do I need to use topoSet to create the cellZones or is there a way to do it wothout topoSet? |
April 27, 2021, 12:06 |
Yann
Rep Power: 29 |
You can either use topoSet, or define it directly in snappyHexMeshDict in the refinementSurface section:
refinementSurfaces { sphere { level (2 2); cellZone sphere; cellZoneInside inside; // outside/insidePoint } } You can check some chtMultiRegionFoam tutorials such as "heatedDuct" to have a functional case using a similar syntax. Hope this helps, Yann |
April 30, 2021, 09:25 |
Claudia
Rep Power: 5 |
I finally did it! My problem was that i tried to define the air as cellZone in snappyHexMesh too, but its easier to define the air in the blockMesh and the rest in snappyHexMesh.
Thank you for your help! |
chtmultiregionfoam, multiregion, snappyhexmesh |
Can I use fvOptions to couple a solid region and a fluid region? | titanchao | OpenFOAM Running, Solving & CFD | 4 | January 14, 2022 08:55 |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 15:26 |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 16:53 |
chtMultiRegionFoam- too slow | sandymech1 | OpenFOAM Running, Solving & CFD | 4 | November 20, 2017 19:51 |
HeatSource BC to the whole region in chtMultiRegionHeater | xsa | OpenFOAM Running, Solving & CFD | 3 | November 7, 2016 06:07 |
