[mesh manipulation] How to convert cloud of data points to mesh?
Like Tree1Likes
  • 1 Post By sunagra27
Old   February 26, 2021, 07:07
Default How to convert cloud of data points to mesh?
Sunag R A
sunagra27 is on a distinguished road
Dear all,
I have a set of 3D data points that looks similar to sphere. I need these data points to be connected as a mesh so that it can be used for simulation.
I would like to know if we could covert a set of 3D data points (surface) to a mesh? Visually, in paraview, I could see by using Delaunay 3D filter. But since it is not smooth, I cannot use it for simulation purpose.
So, any leads would be appreciated if there is a way to convert a cloud of data points to surface mesh. Later, I can use this to create internal mesh. I am currently working for this in MeshLab software.
Thanks and Regards,
Sunag R A.
sourav90 likes this.
sunagra27 is offline   Reply With Quote
Old   April 22, 2021, 16:19
Sourav Mandal
sourav90 is on a distinguished road
Originally Posted by sunagra27 View Post
Dear all,
Thanks and Regards,
Sunag R A.
Hello Sunag,
Have you been able to found any solution? I am also looking for something like this: converting some Lagrangian particle data into Eulerian field (much like applying Delaunay2D or 3D filter in ParaView). But I presume this should be possible in OpenFOAM itself...
Anyone else here, tried to map particle data into a cell data field?
sourav90 is offline   Reply With Quote
delaunay, delaunay3d, mesh 2d to 3d, meshlab, stl
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 09:26
sampling data at specific points - using cloud type OpenFoam7.0 kerim OpenFOAM Post-Processing 0 August 19, 2020 09:38
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times vidyadhar ParaView 9 May 20, 2020 21:06
[snappyHexMesh] SHM Layer Addition Phase dickcruz OpenFOAM Meshing & Mesh Conversion 4 November 1, 2018 08:05
