[Technical] Using FluentMesh instead of AnsysFluentMesh for fluent3DMeshToFoam command |
December 12, 2020, 04:27 |
Farzad Faraji
Rep Power: 8 |
Dear fiends
As you know in we have two different tools for meshing in Ansys workbench; 1- AnsysFluentMesh(for automatic tetrahedral mesh) 2- FluentMesh (for automatic polyhedral and polyhedral-hexcore mesh) I have used AnsysFluentMesh tool previously and I easily import(.msh) my mesh to openfoam. Now, I need to use FluentMesh for generating polyhedron-hexcore mesh and I export .msh file, but when I want to import it to openfoam, it give me error; Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Dimension of grid: 3 Number of points: 55755 --> FOAM Warning : Found unknown block of type: "11" on line 17 Number of faces: 603915 Number of cells: 296366 PointGroup: 6 start: 0 end: 475. Reading points...done. PointGroup: 18 start: 476 end: 11660. Reading points...done. PointGroup: 114 start: 11661 end: 55754. Reading points...done. --> FOAM Warning : Found unknown block of type: "11" on line 55781 FaceGroup: 8 start: 0 end: 22365. Reading uniform faces...done. FaceGroup: 113 start: 22366 end: 603914. Reading uniform faces...done. CellGroup: 111 start: 0 end: 296365 type: 1 --> FOAM Warning : Found unknown block of type: "316" on line 660183 --> FOAM Warning : Found unknown block of type: "71" on line 660662 --> FOAM Warning : Found unknown block of type: "71" on line 664556 --> FOAM Warning : Found unknown block of type: "71" on line 668446 --> FOAM Warning : Found unknown block of type: "71" on line 672340 --> FOAM Warning : Found unknown block of type: "71" on line 676234 --> FOAM Warning : Found unknown block of type: "71" on line 680124 Zone: 111 name: solid type: fluid. Reading zone data...done. Zone: 113 name: interior--solid type: interior. Reading zone data...done. Zone: 8 name: wall type: wall. Reading zone data...done. Zone: 7 name: wall:feature.7 type: boundary-edge. Reading zone data...done. --> FOAM FATAL ERROR: Do not understand characters: [ on line 684058 From function virtual int yyFlexLexer::yylex() in file fluent3DMeshToFoam.L at line 747. FOAM exiting Thanks, Farzad |
March 3, 2021, 02:22 |
Kyfrankie
Rep Power: 6 |
I am also facing the same issue. I am curious is there any update?
June 3, 2023, 13:10 |
Rep Power: 4 |
Hello Farzad,
Did you find a solution to this problem? I managed to fix it by removing the '[' manually from the mesh file since it wasn't something that affected the mesh. However, when I do the conversion I get the following warning: Found unknown block of type: "11" Did you ever come across anything like this?` Best, Amir |
October 30, 2023, 13:15 |
Nilotpal Dhar
Rep Power: 4 |
It might because of the polyhedral cells
Edit: I have exported the mesh as .cas legacy file, unzipped it and converted to OF mesh which got rid of FOAM Warning : Found unknown block of type: "11" warning Last edited by ndhar; November 1, 2023 at 10:30. |
November 2, 2023, 12:27 |
Saeed Jamshidi
Rep Power: 8 |
ansysfluentmesh, fluent3dmeshtofoam, fluentmesh, openfoam |
UDF for inlet temperature and species concentration | haidory | Fluent UDF and Scheme Programming | 18 | September 1, 2019 05:57 |
[PyFoam] PyFoam 0.6.9 wrong path to gnuplot | klausb | OpenFOAM Community Contributions | 5 | March 15, 2018 15:28 |
8x icoFoam speed up with Cufflink CUDA solver library | kmooney | OpenFOAM Running, Solving & CFD | 42 | November 6, 2012 12:37 |
Install problem in linux | navaladi | OpenFOAM Installation | 11 | July 17, 2008 03:24 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 05:26 |
