[snappyHexMesh] mpirun -np 6 snappyHexMesh -overwrite -parallel FOAM FATAL ERROR |
September 24, 2020, 22:22 |
Taciana
Hello, I'm new here so I'm sorry if I'm in the wrong forum, if you can guide me it will be very good. Okay, I'm starting in OpenFoam and I've run the tutorial cases without much difficulty, but now I'm trying to run a particular case, where I will analyze the flow around a conical diffuser. I have the diffuser .stl file and would like to incorporate it into the control volume.
What I did: I copied the motorBike case and renamed and modified the files in the system folder, added the .stl file to the trisurface folder and configured the diffuser alignment on the control volume. After that, I executed the following commands: surfaceFeatureExtract blockMesh decomposePar so far without errors, so I ran: mpirun -np 6 snappyHexMesh -overwrite -parallel and he presented, ERROR.txt I don't know what I'm doing wrong, if any commands are missing. I await guidance and help |
September 25, 2020, 01:06 |
#2 | |
Rep Power: 16 |
Look at the error message - it tells you what is wrong. Quote:
Adjust the locationInMesh point to something within your domain and you will not see this error. Hope this helps. Cheers, Antimony |
September 25, 2020, 08:57 |
Taciana
I will adjust, thank you very much
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 03:21 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 06:34 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 10:31 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
