September 6, 2020, 11:52 |
How to remove boundary
Rep Power: 6 |
Hello everyone,
I couldn't find any compelling and easy step by step explanation for my issue. I have imported .msh mesh into OpenFoam using fluent3DMeshToFoam. Everything went fine but I have an unwanted wall boundary condition inside my domain which I want to delete or make it so it is 'invisible' for the flow. In Fluent I would just change the boundary type from 'wall' to 'internal' but I can't figure out how to deal with this problem in OpenFoam. Help would be much appreciated, thanks in advance. |
September 8, 2020, 07:14 |
anonymous
Rep Power: 14 |
Hi!
If it is a baffle so the faces are sharing the same points, you can use the mergeOrSplitBaffles (https://develop.openfoam.com/Develop...litBafflesDict) utility, if not, you can try the stitchMesh (https://develop.openfoam.com/Develop...stitchMeshDict) utility which will "stitch" the two side and your internal wall will "wanish". You can find some examples for them in the tutorials. |
mesh edit, remove wall |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 06:53 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 17, 2020 00:44 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 11:00 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
