[snappyHexMesh] Cfmesh vs snappyHexMesh
Like Tree5Likes
  • 2 Post By harsha_kulkarni
  • 3 Post By simrego
Old   August 29, 2020, 08:51
Default Cfmesh vs snappyHexMesh
harshawardhank
harsha_kulkarni is on a distinguished road
Hello friends,
Which one is better meshing method
snappyHexMesh or cfmesh
fumiya and Reptider like this.
harsha_kulkarni is offline   Reply With Quote
Old   September 6, 2020, 06:19
anonymous
simrego is on a distinguished road
Hi!
Both better than the other but differently.
cfMesh: Easy to use, really fast, easy BL insertion.
sHM: a bit harder to use, much more freedom, much more functionalities.
For a simple case I think cfMesh is the way to go. Easy to use, and really fast. Also it produces good quality meshes and you don't have to deal with the background mesh like in snappy.
If you have some more complex domain (multiple regions, baffles, etc), I think you should go with sHM.
(At least this is how I see the two mesher, but cfMesh has a non-free version (cfMesh+) which has some more functionalities but I have no experience with it.)
Kummi, thomas.zhang and BIRAJ like this.
simrego is offline   Reply With Quote
Old   November 30, 2020, 15:42
Mostafa
bikooo3878 is on a distinguished road
Originally Posted by simrego View Post
Hi!
This answer is exactly what I was looking for thank you
bikooo3878 is offline   Reply With Quote
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 07:01
[cfMesh] How to start using cfMesh with OpenFOAM v1706? Carno OpenFOAM Community Contributions 1 November 1, 2018 17:28
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 03:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 03:55
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 03:09
