[Gmsh] Boundary Layer Excluded Face in Gmsh
Like Tree2Likes
  • 1 Post By Flowkersma
Old   May 15, 2020, 13:55
Default Boundary Layer Excluded Face in Gmsh
doruk
cfdoruk is on a distinguished road
Hi everybody,
I'm trying to have boundary layer for a very simple geometry by using Gmsh. I can construct the layers; however, I want to exclude one of the faces from the boundary layer list. Although I tried ExcludedFaceList, it still produces layer there.
My surface and curve tags are shown in "Tags.png".
What I want to have is shown in "Desired.png".
What I get in Gmsh is shown in "Result.png".
The script is as follows:
// Gmsh project created on Fri May 15 18:00:20 2020
SetFactory("OpenCASCADE");
Point(1) = {0.5, 0.5, 0, 1.0};
Point(2) = {0, 1, 0, 1.0};
Point(3) = {0.5, 1, 0, 1.0};
Point(4) = {0, 0.5, 0, 1.0};
Line(1) = {2, 3};
Line(2) = {3, 1};
Line(3) = {1, 4};
Line(4) = {4, 2};
Curve Loop(1) = {1, 2, 3, 4};
Plane Surface(1) = {1};
Extrude {0, 0, 0.1} {
Surface{1}; Layers{5}; Recombine;
Field[1] = BoundaryLayer;
Field[1].AnisoMax = 1000;
Field[1].EdgesList = {1, 2, 3, 4};
Field[1].ExcludedFaceList = {4};
Field[1].IntersectMetrics = 0;
Field[1].Quads = 1;
Field[1].hfar = 0.75;
Field[1].hwall_n = 0.001;
Field[1].ratio = 1.300000;
Field[1].thickness = 0.025;
BoundaryLayer Field = 1;
Thank you.
cfdoruk is offline   Reply With Quote
Old   May 19, 2020, 06:01
Mikko
Flowkersma is on a distinguished road
Hi Doruk,
The boundary layers in GMSH are not working very well in 3D. So I would first create a 2D mesh with the boundary layer and then extrude that. Here is an example:
Rectangle(1) = {0, 0, 0, 1, 1, 0};
Field[1].EdgesList = {2, 3, 4};
Field[1].NodesList = {1, 2, 3, 4};
Field[1].hwall_n = 0.01;
Field[1].thickness = 0.1;
Field[1].ratio = 1.2;
Field[1].Quads = 1;
Extrude {0, 0, 0.1} { Surface{1}; Layers{10}; Recombine; }
Best, Mikko
cfdoruk likes this.
Flowkersma is offline   Reply With Quote
Old   May 19, 2020, 07:27
doruk
Hi Mikko,
This works, thank you.
Regards
Doruk
Old   March 3, 2022, 04:47
Arijit Saha
ari003 is on a distinguished road
Originally Posted by Flowkersma View Post
Hi Doruk,
Field[1].Quads = 1;
Best, Mikko
I have a small question and that is why you didnt include hfar or farfield size? Does it become redundant?
ari003 is offline   Reply With Quote
Old   March 7, 2022, 06:12
Mikko
Indeed it becomes redundant. You can calculate the number of cells and largest cell size from geometric series.
Old   March 7, 2022, 13:16
Arijit Saha
Thanks for your response. Maybe it is a very lame question to ask atm but is it that hfar is the last boundary cell or the very adjacent region outside the boundary layer?
boundary layer, gmsh, openfoam, prism layer
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
