[snappyHexMesh] prevent adjacent objects from merging together |
May 1, 2020, 14:18 |
MASc Student
Rep Power: 10 |
I have a handful of STL I'm trying to work into my mesh using snappyHexMesh.
Basically I'm using them to mesh to the surface of the STLs so the domain is cut out around these objects. Everything is working fine but when the objects are too close together, the surfaces get merged together. See below image. Screenshot from 2020-05-01 14-15-14.png Is there a setting in the snappyHexMeshDict I can vary to prevent this? Or would meshing one after another prevent this? I've ran surfaceFeatureExtract and am using the eMesh files for features snapping, and the stls as refinmentSurfaces. My dict is below: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // //https://cfd.direct/openfoam/user-guide/v7-snappyHexMesh/ castellatedMesh true; snap true; addLayers true; geometry { unit.stl //file { type triSurfaceMesh; name unit; //user defined name } unit1.stl //file { type triSurfaceMesh; name unit1; //user defined name } /* sphere1*/ /* {*/ /* type searchableSphere;*/ /* centre (5.0 -0.49 0.3825);*/ /* radius 0.15; */ /* }*/ /* */ /* sphere2*/ /* {*/ /* type searchableSphere;*/ /* centre (5.0 -0.49 0.3825);*/ /* radius 0.10; */ /* }*/ }; castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 500000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 5000000; // The surface refinement loop might spend lots of iterations // refining just a few cells. This setting will cause refinement // to stop if <= minimumRefine are selected for refinement. Note: // it will at least do one iteration (unless the number of cells // to refine is 0) minRefinementCells 0; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. nCellsBetweenLevels 2; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. features ( { file "unit.eMesh"; level 5; //0 forces to snap to edges } { file "unit1.eMesh"; level 5; //0 forces to snap to edges } ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that 'see' multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { unit { // Surface-wise min and max refinement level level (5 5); } unit1 { // Surface-wise min and max refinement level level (5 5); } } // Resolve sharp angles resolveFeatureAngle 30; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions { /* sphere1*/ /* {*/ /* mode inside; //distance*/ /* levels ((2 2)); //((x y) (x y)) level X within Y m*/ /* }*/ /* sphere2*/ /* {*/ /* mode inside; //distance*/ /* levels ((2 2)); //((x y) (x y)) level X within Y m*/ /* }*/ } // Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (1 -0.5 0.5); //inside = internal mesh, outside = external // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 10; //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 2; //- Number of mesh displacement relaxation iterations. nSolveIter 10; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 10; //- Highly experimental and wip: number of feature edge snapping // iterations. Leave out altogether to disable. // Of limited use in this case since faceZone faces not handled. nFeatureSnapIter 10; //- Detect (geometric only) features by sampling the surface // (default=false). implicitFeatureSnap false; //- Use castellatedMeshControls::features (default = true) explicitFeatureSnap true; //- Detect points on multiple surfaces (only for explicitFeatureSnap) multiRegionFeatureSnap true; } // Settings for the layer addition. addLayersControls { relativeSizes true; // Per final patch (so not geometry!) the layer information layers { unit { nSurfaceLayers 2; } } // Expansion factor for layer mesh expansionRatio 1; // Wanted thickness of final added cell layer. If multiple layers // is the thickness of the layer furthest away from the wall. // Relative to undistorted size of cell outside layer. finalLayerThickness 0.5; // Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. minThickness 0.01; // If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x) nGrow 0; // Advanced settings // When not to extrude surface. 0 is flat surface, 90 is when two faces // are perpendicular featureAngle 30; // Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 1; // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 3; // Smooth layer thickness over surface patches nSmoothThickness 10; // Stop layer growth on highly warped cells maxFaceThicknessRatio 0.5; // Reduce layer growth where ratio thickness to medial // distance is large maxThicknessToMedialRatio 0.3; // Angle used to pick up medial axis points // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x. minMedianAxisAngle 90; // Create buffer region for new layer terminations nBufferCellsNoExtrude 0; // Overall max number of layer addition iterations. The mesher will exit // if it reaches this number of iterations; possibly with an illegal // mesh. nLayerIter 50; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { #include "meshQualityDict" //- Number of error distribution iterations nSmoothScale 5; //- amount to scale back displacement at error points errorReduction 0.75; } // Advanced // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1e-6; // ************************************************************************* // Any suggestions appreciated. UPDATE - I've tried playing with the new SHM settings shown here: https://www.openfoam.com/releases/op...processing.php but don't seem to do what I want..fiddling around.... Last edited by New-to-CFD; May 1, 2020 at 15:32. |
April 4, 2022, 07:21 |
Ludovico
Rep Power: 5 |
Hi, i have same problem.
Did you solve the problem? |
snap to surface, snappyhexmesh |
Multiple Floating Objects with 6DoF in OF 2.3.0 | tyoung | OpenFOAM Running, Solving & CFD | 23 | June 11, 2024 01:13 |
Multiple floating objects using InterDyMFoam and sixDoFRigidBodyMotion solver | FloatingSolar | OpenFOAM Running, Solving & CFD | 4 | December 29, 2020 11:09 |
Update FOAM objects after new solver run | peterTr | OpenFOAM Programming & Development | 1 | May 11, 2017 16:26 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
[Other] mesh generation for sloping objects | yuyingyuni | ANSYS Meshing & Geometry | 0 | March 15, 2013 02:46 |
