[snappyHexMesh] some bad cells after snappyHexMesh |
April 29, 2020, 23:11 |
MASc Student
Rep Power: 10 |
hello everyone,
will try to frame this question as best as possible but I am relatively new to openfoam so please excuse me if I word things in correctly. Long story short - I have an stl of an object I am using to snap the mesh to, after completion, I end up with all these really weird very bad quality cells surrounding the object and don't know how to prevent these or fix them. See attached zip of my case folder. I am currently just running the following commands, trying to get a nice mesh before moving on. Code:
blockMesh topoSet -dict system/topoSetDict1 refineMesh -dict system/refineMeshDict1 topoSet -dict system/topoSetDict2 refineMesh -dict system/refineMeshDict2 surfaceFeatureExtract snappyHexMesh Please see the images showing the mesh after the second refinement, after snappy, and what the object looks like. I realize I could get better snapping to the unit but wanted to keep the mesh relatively coarse for now for testing. If I can get better snapping to the object without increase resolution/number of levels, please let me know how. Could someone please take a look and see if they can manage to fix the weirdness around my object? At first glance, I know my snapControls may be set excessively high, that was me just trying some stuff, but didn't seem to change the results. Using OFv1912. Any help is appreciated!! Thanks Screenshot from 2020-04-29 22-04-04.png Screenshot from 2020-04-29 22-05-49.png Screenshot from 2020-04-29 22-06-17.png Screenshot from 2020-04-29 22-06-51.png FlumeTesting.zip |
April 30, 2020, 03:44 |
Yann
Rep Power: 29 |
When visualizing the mesh in ParaView, have you tried checking the "crinkle clip" option ? (or crinkle slice if you're using the slice filter) Yann |
April 30, 2020, 18:21 |
#3 | |
MASc Student
Rep Power: 10 |
are you able to suggest what parameters in the sHMdict I can vary to make the mesh snap better to the edges extracted during the surfaceFeatureExtract step?? Without having to increase mesh resolution or number of levels in sHM? I feel like there' s a way to make it snap perfectly but I'm just missing it....? |
May 2, 2020, 18:10 |
Claudio Boezio
Rep Power: 7 |
I've experienced similar issues when I started using OpenFOAM and snappyHexMesh. It seemed that no matter how much I refined the mesh, its snapping quality didn't seem to improve, just the amount of cells increased. What I found out was that the input geometry (*.stl file) didn't had sufficient resolution. snappyHexMesh can only snap conforming to the input geometry, but not better. If you have a curved surface which is subdivided by trinagles or quadrilaterals, the snapped mesh also won't have a nice curvature. My suggestion to improve this, is to use input geometry with a mesh that is at least as fine as the intended mesh for the solution. Don't save on the *.stl or *.obj file size. Instead make it as fine as if you had to use it for producing a quality rendering. Hope this helps. Cheers |
May 7, 2020, 18:26 |
#5 | |
MASc Student
Rep Power: 10 |
I am able to get better snapping by increasing the levels for the feature edge refinement, using the eMesh file output from SurfaceFeatureExtract, but then the cells get so small it's not even worth the tiny bit of snapping improvement. I'll try playing with the actual stl mesh to see if I can get some improvement without having to refine the cells too much. |
May 7, 2020, 19:57 |
SHM problem
nicolas martinez poulsen
Hi everyone. I'm traying to modelate generate a "simple" canal with some blocks inside.
First generated the domain (canal) with blockMesh (no problem). After that i'm traying to incorporated the blocks inside using snappyHexMesh. I generate my .stl file with blocks, and previewd on para view. I serch in google and here, but I cant find anything, so i have to ask if someone can tell me that im doing wrong. My snapp file is this: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true; addLayers false; // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // geometry { Dientes.stl { type triSurfaceMesh; file "Dientes.stl" name Dientes; //patchInfo //{ // type walls; //} } }; castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 100000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 2000000; // The surface refinement loop might spend lots of iterations refining just a // few cells. This setting will cause refinement to stop if <= minimumRefine // are selected for refinement. Note: it will at least do one iteration // (unless the number of cells to refine is 0) minRefinementCells 0; // Allow a certain level of imbalance during refining // (since balancing is quite expensive) // Expressed as fraction of perfect balance (= overall number of cells / // nProcs). 0=balance always. maxLoadUnbalance 0.10; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. nCellsBetweenLevels 3; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. features ( { file "Dientes.eMesh"; level 2; } ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that 'see' multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { Dientes { // Surface-wise min and max refinement level level (2 2); // Optional specification of patch type (default is wall). No // constraint types (cyclic, symmetry) etc. are allowed. //patchInfo //{ // type wall; // inGroups (walls); //} } } // Resolve sharp angles resolveFeatureAngle 0; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions { //refinementBox // { // mode inside; // levels ((1E15 4)); //} } // Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (1 1 80); // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces false; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 3; //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 2.0; //- Number of mesh displacement relaxation iterations. nSolveIter 100; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; // Feature snapping //- Number of feature edge snapping iterations. // Leave out altogether to disable. nFeatureSnapIter 10; //- Detect (geometric only) features by sampling the surface // (default=false). implicitFeatureSnap false; //- Use castellatedMeshControls::features (default = true) explicitFeatureSnap true; //- Detect points on multiple surfaces (only for explicitFeatureSnap) multiRegionFeatureSnap false; } // Settings for the layer addition. addLayersControls { // Are the thickness parameters below relative to the undistorted // size of the refined cell outside layer (true) or absolute sizes (false). relativeSizes false; // prueba si es que con esto hacemos aparecer los dientes que estan sobre el punto de contacto con un mesh // Per final patch (so not geometry!) the layer information layers { Dientes { nSurfaceLayers 0; } } // Expansion factor for layer mesh expansionRatio 1.0; // Wanted thickness of final added cell layer. If multiple layers // is the thickness of the layer furthest away from the wall. // Relative to undistorted size of cell outside layer. // See relativeSizes parameter. finalLayerThickness 0.3; // Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. minThickness 0.1; // If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x) nGrow 0; // Advanced settings // When not to extrude surface. 0 is flat surface, 90 is when two faces // are perpendicular featureAngle 60; // At non-patched sides allow mesh to slip if extrusion direction makes // angle larger than slipFeatureAngle. slipFeatureAngle 30; // Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 3; // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 1; // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 3; // Smooth layer thickness over surface patches nSmoothThickness 10; // Stop layer growth on highly warped cells maxFaceThicknessRatio 0.5; // Reduce layer growth where ratio thickness to medial // distance is large maxThicknessToMedialRatio 0.3; // Angle used to pick up medial axis points // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x. minMedianAxisAngle 90; // Create buffer region for new layer terminations nBufferCellsNoExtrudegeometry { Dientes.stl { type triSurfaceMesh; file "Dientes.stl" name Dientes; //patchInfo //{ // type walls; //} } }; castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 100000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 2000000; // The surface refinement loop might spend lots of iterations refining just a // few cells. This setting will cause refinement to stop if <= minimumRefine // are selected for refinement. Note: it will at least do one iteration // (unless the number of cells to refine is 0) minRefinementCells 0; // Allow a certain level of imbalance during refining // (since balancing is quite expensive) // Expressed as fraction of perfect balance (= overall number of cells / // nProcs). 0=balance always. maxLoadUnbalance 0.10; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. nCellsBetweenLevels 3; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. features ( { file "Dientes.eMesh"; level 2; } ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that 'see' multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { Dientes { // Surface-wise min and max refinement level level (2 2); // Optional specification of patch type (default is wall). No // constraint types (cyclic, symmetry) etc. are allowed. //patchInfo //{ // type wall; // inGroups (walls); //} } } // Resolve sharp angles resolveFeatureAngle 0; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions { //refinementBox // { // mode inside; // levels ((1E15 4)); //} } // Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (1 1 80); // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces false; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 3; //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 2.0; //- Number of mesh displacement relaxation iterations. nSolveIter 100; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; // Feature snapping //- Number of feature edge snapping iterations. // Leave out altogether to disable. nFeatureSnapIter 10; //- Detect (geometric only) features by sampling the surface // (default=false). implicitFeatureSnap false; //- Use castellatedMeshControls::features (default = true) explicitFeatureSnap true; //- Detect points on multiple surfaces (only for explicitFeatureSnap) multiRegionFeatureSnap false; } 0; // Overall max number of layer addition iterations. The mesher will exit // if it reaches this number of iterations; possibly with an illegal // mesh. nLayerIter 50; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { #include "meshQualityDict" } // Advanced // Write flags writeFlags ( scalarLevels layerSets layerFields // write volScalarField for layer coverage ); // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1e-6; // ************************************************************************* // Regards |
May 7, 2020, 20:39 |
Complementing the above, the end of the SHM process shows the following message:
" Checking final mesh ... Checking faces in error : non-orthogonality > 65 degrees : 700 faces with face pyramid volume < 1e-13 : 0 faces with face-decomposition tet quality < 1e-15 : 0 faces with concavity > 80 degrees : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 faces with interpolation weights (0..1) < 0.05 : 68 faces with volume ratio of neighbour cells < 0.01 : 0 faces with face twist < 0.02 : 0 faces on cells with determinant < 0.001 : 0 Finished meshing with 768 illegal faces (concave, zero area or negative cell pyramid volume) Finished meshing in = 27.58 s. End " |
May 8, 2020, 16:20 |
#8 | |
MASc Student
Rep Power: 10 |
definitely increase resolveFeatureAngle to something higher...something like 30 typically works well for me but will depend on your geometry also, when in paraview after loading the case..scroll down in the properties tab until you see Mesh Regions and just show the ones pertaining to your objects. This will give you a better depiction as to whether they've meshed satisfactorily or not. |
April 19, 2021, 08:56 |
some bad cells after snappyHexMesh(2)
#9 |
Alfa
Rep Power: 5 |
Hi everyone!
I'm new to OpenFOAM and currently deepening more about snappyHexMesh. I have several questions regarding some bad cells after snappyHexMesh similar to what has been posted here by @New-to-CFD and would like to make sure if everything works accordingly. I'm also very sorry if I don't put all the details related to my case now. However, if more detail is needed then I'll provide the best I could. My case is a 3D flow around some obstacles with dimension 100x100x10 m with max expected final cell no. of 25-30 Mio. 1. I have completed the castellating and snapping phase (and will do the layer addition later). However some bad-looking cells look to appear similar to that posted by @New-to-CFD. Attached is the snapshot BEFORE and AFTER "crinkle clip" such as suggested by @Yann. Can someoene please confirm if my cells are visually OK? Attached is the snapshots. 2. I have checked on my snappyHexMesh log that all of the iteration successfully leads to "0" of "mesh in errors" e.g. tet quality, concaveness, skewness, etc. However, the final check mesh still shows "Failed 3 mesh checks" which are skewness (1 highly skew faces of 4.10024, I think it's fine since it's only one cell and the value is near the skewness threshold of 4 CMIIW), 273 face tets, and concave cells where the latter can be ignored according to some discussions in CFD community. Can someone advise what should be done or is it okay to have those? The checkMesh and snappyHexMesh log file as well as my snappyHexMeshDict are attached. 3. I have made sure that my geometry is fine. I used Autodesk Inventor and have checked it for an error with no error result. I exported STL with the high resolution. I also did surfaceCheck in OpenFOAM where everything is fine. Attached is the log files of surfaceCheck. Regarding to this, can someone also confirm if my STL is fine and no further checking is necessary? Am I missing something in order to provide good STL or should I perform another checking method? Thank you! Regards, Alfa |
mesh, openfoam, refinemesh, snappyhexmesh |
[blockMesh] Create internal faces as patch in blockMesh | m.delta68 | OpenFOAM Meshing & Mesh Conversion | 14 | July 12, 2018 15:43 |
[snappyHexMesh] snappyHexMesh does not remove internal cells | Manyway | OpenFOAM Meshing & Mesh Conversion | 1 | December 14, 2016 19:57 |
[snappyHexMesh] snappyHexMesh uses tet cells for internal mesh! | sasanghomi | OpenFOAM Meshing & Mesh Conversion | 2 | March 16, 2014 06:41 |
[ICEM] error analysis | despaired student | ANSYS Meshing & Geometry | 7 | June 27, 2012 12:57 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 15, 2003 00:19 |
