[blockMesh] Create an axisymmetric grid from a 2D blockMeshDict
Like Tree1Likes
  • 1 Post By dplamp
Old   April 20, 2020, 07:29
Default Create an axisymmetric grid from a 2D blockMeshDict
K
mkhm is on a distinguished road
Dear Foamers,
I have a 2 dimensional de laval nozzle. The meshing is done via the blockMeshDict. Now, I want to convert it to an axisymmetric one. So, instead of a symmetry PLANE, I would have a symmetry line and the front and back plane becomes of wedge type. I saw the following utility "makeAxialMesh" which does exactly what I want. However, the problem is that it is not available in OpenFOAM 4.x. Does anyone know any other alternatives ?
Thanks in advance for your help
mkhm is offline   Reply With Quote
Old   August 19, 2020, 04:43
dplamp is on a distinguished road
Here a working example of a wedge :
|  \\    /   O peration     | Version:  plus                                  |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;        // m
radius    2.5e-3;
length    80e-3;
halfWedgeAngle    2.5;    // degrees
// wedge coordinates :
hAR        #calc "degToRad($halfWedgeAngle)";    // half angle in rad
wx        #calc "$radius*cos($hAR)";
wyp        #calc "$radius*sin($hAR)";
wyn        #calc "-1.0*$wyp";
cs        #calc "cos($hAR)";
//#calc "Info<< $halfWedgeAngle << $cs << $wx";
//#calc "Info<< $wx << endl";
vertices
    (0 0 0)
    (1 0 0)
    (0 1 0)
    (0 0 1)
    (0 0 $length)    // 4
    ($wx $wyn $length)
    ($wx $wyn 0)
    ($wx $wyp 0)
    ($wx $wyp $length)
blocks
    hex (0 6 7 0 4 5 8 4) (50 1 200) simpleGrading (0.5 1 1)
edges
boundary
    inlet
        type patch;
        faces
            (0 7 6 0)
    outlet
        type patch;
        faces
            (4 5 8 4)
    wallPipe
        type wall;
        faces
            (5 6 7 8)
    front
        type wedge;
        faces
            (0 6 5 4)
    back
        type wedge;
        faces
            (0 4 8 7)
    axis
        type symmetry;
        faces
            (0 4 4 0)
mergePatchPairs
Goatow likes this.
dplamp is offline   Reply With Quote
axis-symmetric, mesh 2d, nozzleflow2d, openfaom, wedge
[GAMBIT] How to plot S pipe mariam.sara ANSYS Meshing & Geometry 36 November 7, 2013 16:22
Steps to create a quater O grid or Y grid brissyben ANSYS Meshing & Geometry 3 April 12, 2012 06:46
MapFields to New Grid For Extreme Grid Deformations due to Body Motion albcem OpenFOAM 0 May 5, 2009 15:17
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
