March 7, 2020, 11:28 |
gmshToFoam Error
Nathan
Rep Power: 6 |
When running gmshToFoam airfoil.msh I get the following error.
``` --> FOAM FATAL IO ERROR: Attempt to get back from bad stream file: IStringStream.sourceFile at line 0. From function bool Foam::Istream::getBack(Foam::token&) in file db/IOstreams/IOstreams/Istream.C at line 56. FOAM exiting ``` First few lines of airfoil.msh ``` $MeshFormat 4.1 0 8 $EndMeshFormat $PhysicalNames 8 2 1 "back" 2 2 "front" 2 3 "top" 2 4 "exit" 2 5 "bottom" 2 6 "inlet" 2 7 "aerofoil" 3 8 "internal" $EndPhysicalNames $Entities 158 15 7 1 1000 1 0.00224 0 0 1001 0.98935 0.00357 0 0 1002 0.9593699999999999 0.0076 0 0 1003 0.92939 0.01203 0 0 ``` I'm running OpenFoam 5 with gmsh 4.5.4. Does anyone know a solution to this? |
March 16, 2020, 07:10 |
Solution
Nathan
Rep Power: 6 |
So turns out this is a file formatting issue between gmsh and gmshToFoam. To fix you need to convert the output of your meshing to msh2.
In my case it I had to change $ gmsh airfoil.geo -3 -o airfoil.msh > /dev/nul to gmsh airfoil.geo -3 -o airfoil.msh -format msh2 > /dev/nul |
fatal error, gmsh 4.5.4, gmshtofoam |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
