[snappyHexMesh] Bad looking cells with CastelledMesh |
Rep Power: 6 ![]() |
Hello everybody, I'm struggling with some bad looking cells generated by the CastellatedMesh step of my snappyHexMeshDict file, cf. pictures. As you can see, some cells are extremely plane/crushed. I tried changing several parameters of my snappyHexMeshDict file, but the output doesn't change. This is my code:
FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap false; addLayers false; #include "include/inputVariables" //definition of input values offset 1; //offset x_positive #calc "3*$offset + $n_panel_x_dir*$x_panel"; x_negative #calc "-1*$offset"; y_positive #calc "0.5*$y_panel + $offset"; y_negative #calc "-1*$y_positive"; z_positive #calc "1.5*$offset"; // Geometry. Definition of all surfaces. All surfaces are of class // searchableSurface. // Surfaces are used // - to specify refinement for any mesh cell intersecting it // - to specify refinement for any mesh cell inside/outside/near // - to 'snap' the mesh boundary to the surface geometry { Panel_0 { type triSurfaceMesh; file "Panel_0.stl"; } Panel_1 { type triSurfaceMesh; file "Panel_1.stl"; } Panel_2 { type triSurfaceMesh; file "Panel_2.stl"; } Panel_3 { type triSurfaceMesh; file "Panel_3.stl"; } Panel_4 { type triSurfaceMesh; file "Panel_4.stl"; } Panel_5 { type triSurfaceMesh; file "Panel_5.stl"; } refinementBox { type searchableBox; min ($x_negative $y_negative 0); max ($x_positive $y_positive $z_positive); } }; // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 100000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. // maxGlobalCells 2000000; maxGlobalCells 4000000; // The surface refinement loop might spend lots of iterations refining just a // few cells. This setting will cause refinement to stop if <= minimumRefine // are selected for refinement. Note: it will at least do one iteration // (unless the number of cells to refine is 0) minRefinementCells 10; // Allow a certain level of imbalance during refining // (since balancing is quite expensive) // Expressed as fraction of perfect balance (= overall number of cells / // nProcs). 0=balance always. maxLoadUnbalance 0.10; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. //nCellsBetweenLevels 3; nCellsBetweenLevels 10; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. features ( { file "Panel_0.eMesh" "Panel_1.eMesh" "Panel_2.eMesh" "Panel_3.eMesh" "Panel_4.eMesh" "Panel_5.eMesh" ; level 2; } ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that 'see' multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { Panel_0 { // Surface-wise min and max refinement level level (2 4); // Optional specification of patch type (default is wall). No // constraint types (cyclic, symmetry) etc. are allowed. patchInfo { type wall; inGroups (Panel_PV); } } Panel_1 { level (2 4); patchInfo { type wall; inGroups (Panel_PV); } } Panel_2 { level (2 4); patchInfo { type wall; inGroups (Panel_PV); } } Panel_3 { level (2 4); patchInfo { type wall; inGroups (Panel_PV); } } Panel_4 { level (2 4); patchInfo { type wall; inGroups (Panel_PV); } } Panel_5 { level (2 4); patchInfo { type wall; inGroups (Panel_PV); } } } } // Resolve sharp angles resolveFeatureAngle 30; // resolveFeatureAngle 0; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions { refinementBox { mode inside; //levels ((1E15 2)); levels ((1E15 4)); } } // Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (0.1 0.1 0.9); // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces true; } Code:
Merging all points on surface that - are used by only two boundary faces and - make an angle with a cosine of more than 0.707107. Removing 2618 straight edge points ... Edge intersection testing: Number of edges : 22173899 Number of edges to retest : 17447 Number of intersected edges : 1085167 Undo iteration 0 ---------------- Checking faces in error : non-orthogonality > 65 degrees : 0 faces with face pyramid volume < 1e-13 : 0 faces with face-decomposition tet quality < 1e-15 : 0 faces with concavity > 80 degrees : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 faces with interpolation weights (0..1) < 0.02 : 0 faces with volume ratio of neighbour cells < 0.01 : 0 faces with face twist < 0.02 : 0 faces on cells with determinant < 0.001 : 0 Refined mesh : cells:7083129 faces:22173899 points:8009619 Cells per refinement level: 0 42210 1 42270 2 158288 3 838978 4 6001383 Writing mesh to time constant Wrote mesh in = 245.06 s. Mesh refined in = 2480.19 s. Checking final mesh ... Checking faces in error : non-orthogonality > 65 degrees : 0 faces with face pyramid volume < 1e-13 : 0 faces with face-decomposition tet quality < 1e-15 : 0 faces with concavity > 80 degrees : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 faces with interpolation weights (0..1) < 0.02 : 0 faces with volume ratio of neighbour cells < 0.01 : 0 faces with face twist < 0.02 : 0 faces on cells with determinant < 0.001 : 0 Finished meshing without any errors Finished meshing in = 2530.9 s. End Is there anything that I am missing? Which meshing parameters should I modify in order to solver this problem? Or should I change completely my approach? Thank you a lot in advance! |
Andreas P.
Rep Power: 9 ![]() |
I think these are visualization issues of paraview. Do not check the checkbox "Decompose polyhedra" in the properties of the foam-file that you load with paraview and check the crinkle slice checkbox in the slice properties in order to properly show a slice that just consists "complete" cells.
Thank you very much! You were right, checking "Use VTK Polyhedron" (in Paraview 5.4.0) in the properties of the foam-file and checking "Crinkle Slice" in the slice properties I have a nice visualization.
Have a nice day and thank you again for your kind help. |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
[blockMesh] Create internal faces as patch in blockMesh | m.delta68 | OpenFOAM Meshing & Mesh Conversion | 14 | July 12, 2018 14:43 |
snappyHexMesh in parallel - FOAM Fatal IO Error | mturcios777 | OpenFOAM Running, Solving & CFD | 4 | August 10, 2012 19:18 |
how to deal with bad quality cells? | phsieh2005 | OpenFOAM | 3 | July 20, 2011 09:35 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
