[blockMesh] creating blockMesh
Like Tree1Likes
  • 1 Post By Rasmusiwersen
Old   January 6, 2020, 11:24
Default creating blockMesh
PSander is on a distinguished road
I wrote the blockMeshDict and want to create now a blockMesh. During the process I get an error message. It says:
"In function ‘void Foam::codeStream_efa88c99f17594f6f3c82927a0fb16235 e07ee90(Foam::Ostream&, const Foam::dictionary&)’:
:1:34: error: ‘d_sl_y’ was not declared in this scope
/opt/openfoam7/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/codeStreamTemplate.o' failed
make: *** [Make/linux64GccDPInt32Opt/codeStreamTemplate.o] Error 1
--> FOAM FATAL IO ERROR:
Failed wmake "dynamicCode/_efa88c99f17594f6f3c82927a0fb16235e07ee90/platforms/linux64GccDPInt32Opt/lib/libcodeStream_efa88c99f17594f6f3c82927a0fb16235e07 ee90.so"
file: /home/philip/OpenFOAM/philip-7/test_playground/system/blockMeshDict from line 17 to line 189.
From function static void (* Foam::functionEntries::codeStream::getFunction(con st Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&)
in file db/dictionary/functionEntries/codeStream/codeStream.C at line 218.
FOAM exiting"
What I understand, is that "d_sl_y" is missing, but it is part of my blockMeshDict, as you can see in my code
//Surface_layer
d_sl_x $d_s3_x; // horizontal size of surface layer
d_sl_z $d_p1_l; // length of surface layer (z)
d_sl_y 1.5; // vertical size of surface layer
Is there any explanation, why I get this error?
Thank you for your help
PSander is offline   Reply With Quote
Old   January 7, 2020, 07:17
Rasmus Iwersen
Rasmusiwersen is on a distinguished road
FOAM exiting"
//Surface_layer
Since i don't know your blockMeshDict, your are a hundred percent sure that you are calling the variable efter defining it? Also, if you highlight the variable it should highlight everywhere else it is used in the script. This is just an easy way to ensure the format is the same in the file, i.e. that openfoam recognizes it as the same variable in the entire file.
If this is not the case, can you upload your blockMeshDict? A search on the "was not declared in this scope" error can be due to an error in the openfoam build. I guess this can be ruled out if I am able to run blockMesh without errors.
Best
/Rasmus
PSander likes this.
Rasmusiwersen is offline   Reply With Quote
Old   January 21, 2020, 15:08
Default missing declaration
I tried it in a new mesh, and get again an error about a missing scope. I checked it and can not figure out, why its not working. For me it looks fine, i could not find a missing $ or something similar.
Is there any other reason, why this error message could appear?
Thank you a lot!
Old   January 21, 2020, 15:10
Hey Rasmus,
could you be so kind and try my mesh? Thank you
Old   January 21, 2020, 22:13
Antimony is on a distinguished road
Your problem comes from this line:
d_ss_x 1; erweiterte Breite
You forgot to comment out the text after ;
So it should be:
d_ss_x 1; //erweiterte Breite
And it does not give you the $coo_p_x not defined error.
However, I think you still have other missing/incorrectly named variables that you have called while defining your vertices. Check that.
Hope this helps.
Cheers,
Antimony
Antimony is offline   Reply With Quote
blockmeshdict, blockmeshdict block mesh
[blockMesh] Wierd behaviour of blockMesh creating axis in wedge rcastilla OpenFOAM Meshing & Mesh Conversion 1 December 4, 2018 07:24
[blockMesh] Segmentation Fault when creating block mesh topography (blockMesh) jbrydg01 OpenFOAM Meshing & Mesh Conversion 2 May 11, 2017 06:37
[blockMesh] Error while creating blockMesh: Inconsistent point locations between block pair lpashwin OpenFOAM Meshing & Mesh Conversion 2 June 1, 2015 13:31
[blockMesh] Error while running blockMesh Harak OpenFOAM Meshing & Mesh Conversion 0 December 11, 2014 10:36
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
