[Other] gmshToFoam error
Like Tree2Likes
  • 2 Post By Pedro Felix
Old   November 12, 2019, 14:55
Default gmshToFoam error
Pedro Felix
Pedro Felix is on a distinguished road
Hi
I have a problem converting the mesh I created in gmsh. I created a tube with several cylinders inside. When I use the gmshToFoam command, the following error occurs:
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 7
\\/ M anipulation |
Build : 7-6ef561967074
Exec : gmshToFoam teste1.msh
Date : Nov 12 2019
Time : 15:32:18
Host :*******
PID : 7359
I/O : uncollated
Case : /home/diego/Documentos/teste1/pitzDaily
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Starting to read mesh format at line 2
Read format version 2.2 ascii 0
Starting to read physical names at line 5
Physical names:7
Surface 1 inlet
Surface 2 outlet
Surface 3 top
Surface 4 bottom
Surface 5 cylinders
Surface 6 frontandback
Volume 7 volume
Skipping tag $ParametricNodes at line 15
Starting to read cells at line 14441
Cells to be read:72492
Unhandled element 15 at line 14443
Unhandled element 15 at line 14444
Unhandled element 15 at line 14445
Unhandled element 15 at line 14446
Unhandled element 15 at line 14447
Unhandled element 15 at line 14448
Unhandled element 15 at line 14449
Unhandled element 1 at line 15926
Unhandled element 1 at line 15927
Unhandled element 1 at line 15928
Unhandled element 1 at line 15929
Unhandled element 1 at line 15930
--> FOAM FATAL ERROR:
75 not found in table. Valid entries: 0()
From function const T& Foam::HashTable<T, Key, Hash>:perator[](const Key&) const [with T = int; Key = int; Hash = Foam::Hash<int>]
in file /home/ubuntu/OpenFOAM/OpenFOAM-7/src/OpenFOAM/lnInclude/HashTableI.H at line 126.
FOAM exiting
if anyone can help me, i will be very grateful.
arashgmn and sourav90 like this.
Pedro Felix is offline   Reply With Quote
gmshtofoam
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
